Old 05-15-2001, 11:12 PM   #1
Brood
Member#: 3886
2011 STi Sedan
Mancream White
Post How important is a 15,000 mile service?
I'm approaching 15,000 miles and I was just wondering what exactly is involved if you take your car to the dealership for their 15,000 mile service. It's 300 bucks at my dealer and I was wondering if it's even something I should have done there. Thanks for any input.
Brood is offline   Reply With Quote
Old 05-16-2001, 01:21 AM   #2
ivbdn
Member#: 2736
2001 Impreza 2.5RS
Post
I had that done a few months back. Basically, they check up on almost everything on the car, lube it up, and tighten your e-brake (which I think is a good thing). Your maintenance manual should be able to tell you. Hope this helps.
ivbdn is offline   Reply With Quote
Old 05-16-2001, 06:56 AM   #3
Matt
Allergic to turbos
Member#: 181
2009 Forester
'09 ImprezaGT '04Frontier
Exclamation
I blew by 15k and didn't think too much about it. I did take it to my local place and have them take a look at it. They said all I need is the fuel injection cleaned.
Sounds like some BS...especially for $300 !
Matt is offline   Reply With Quote
Old 05-16-2001, 07:35 AM   #4
mad-dog999
Member#: 4347
2006 2.5i Wagon
Lightbulb
An ounce of prevention is worth a pound of cure.
I must admit that $300 sounds a bit too much, considering what they do. According to MySubaru.com:
Replace: Engine oil
Replace: Engine oil filter
Inspect: Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Perform: Inspect brake lines and check operation of parking and service brake system
Inspect: Clutch operation
Inspect: Steering and suspension
You could probably get it done at a local mechanic for around half that. As long as you save the bill, they can't deny warranty coverage.
mad-dog999 is offline   Reply With Quote
Old 05-16-2001, 08:25 AM   #5
Skylab
Member#: 4263
Lightbulb
For $300 I'll inspect anyone's Scooby, detail it, and take the owner out to lunch!
Skylab is offline   Reply With Quote
Old 05-16-2001, 08:40 AM   #6
Poseidon
Member#: 4864
2004 WRX
Post
There was a really good article on Edmunds.com about differences between "Required Service" and "Suggested Service." Your owner's manual and the manufacturer will tell you what the required services are, but most dealers will perform "suggested" services unless you specifically request only the required service. What they perform and how much they charge will vary quite a bit from dealer to dealer.
Are the suggested services a good idea? Depends. Do you plan to keep your car for more than five years? If so, you might want to consider some of the extras your dealer performs. Things like engine and coolant flushes can certainly extend the life of your engine. It's a good idea, though, to know ahead of time what they are planning to do. There may be several things you can do yourself for much cheaper (nobody should have to pay to have their fluids topped off).
Jordan
Poseidon is offline   Reply With Quote
Old 05-16-2001, 09:23 AM   #7
BradWRX
Member#: 5500
2002 WRX Aspen White
2004 Corvette Z06
Post
All good comments above. It's you first 15k and the car is new. I say do an oil/filter change and inspect the rest yourself. It's not hard and anyone that stays on top of one's condition of the car, on a ongoing basis will know if there is a problem or not (i.e. brakes, clutch, steering, suspension etc.).
If you want just wait until the 30k service intervals for the dealer. Even then you can do most of the work yourself or use a trustworthy independent. It seems the 60k is the only major service that you may want to take it to the dealer.
BradWRX is offline   Reply With Quote
Likely cost of 15,000 mile service? bruticus Service & Maintenance 22 10-24-2003 08:12 AM
$110 for a 15,000 mile service at Stohlman WRXVT Mid Atlantic Impreza Club -- MAIC 5 06-04-2003 11:09 PM
15,000 mile service poll afeinman Service & Maintenance 3 11-07-2002 07:16 PM
15,000 mile service jhonas Service & Maintenance 0 08-24-2002 07:50 PM
