#101 |
Member#: 167827
Vehicle:2004 STi WRB |
You get what you are paying for I guess. If you want to drop over $2k on a fuel system go for it. There are a lot of people that have had great success with these and at a price point you can't beat. Im not giving up just yet.
#102 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
If you're trying to run a 1200cc+ injector on pump gas...then you're asking for poor performance.
If you're not going to run e85 99% of the time then choose a different route like meth or race gas. The erratic swings in fuel trims are due to the non linear flow of big injectors at low ipw. |
#103 | |
Member#: 193014
Vehicle:02 WRX WRB, 05 STI FPGreen E85 400+whp |
#104 | |
Member#: 212154
South East
Vehicle:02 bugeye, manley ej257, pt5857, MBP on E85 |
My precision 1250cc idle like stock on 93 no problem. No non linear flow when fueling is graphed out. Never a missfire. Granted these are low impedance injectors. I've also ran the ford motorsports 1600cc low impedance injectors without issue. And they are one of the cheapest made low impedance injector you can get. I would never try and run a large high impedance injector. If your going to run a big injector it should be a low impedance (peak and hold) injector. At least if your looking for a decent idle quality. Yes, its a bitch cause you have to wire in an injector driver. But the benifits are well worth the trouble. And the dead times of a peak and hold injector are half what high impedance injectors are. |
#105 | |
Member#: 36033
SCIC
better go over here and start a debate
http://forums.nasioc.com/forums/show....php?t=2287355 Quote:
#106 | |
Member#: 212154
South East
#107 |
Member#: 36033
SCIC
I don't think he said to anything about running it on a stock Honda ecu....he just said lots of cheap Honda guys buy them
#108 |
Member#: 152576
SWIC
Vehicle:2006 STI 10.8@ 129 www.Mayhemtuning.com |
#109 |
Member#: 80649
South East
Vehicle:2000 2.5 Auto-X RSTi What's A Head Gasket? |
Anyone have 1200cc top feed EV14's and willing to share latency and other specs? I've got a slight stumble at idle and when lifting off the gas on mine and wanted to start digging into it.
#110 | |
Member#: 170439
Vehicle:I <3 Lamp |
#111 | |
Member#: 212154
South East
. But only for a minute.. |
#112 |
Member#: 36033
SCIC
I've never personally tried them, but how
Come no limit says they are worse and not to bother with them? And if the latencies are half of high imp Inj then the min ipw parameter in the ecu is going to become a hassle isn't it? |
#113 |
Member#: 212154
South East
I'm not sure why he would say that unless its his experience trying to tune them with resistors. I've personally not needed to tune on anything with larger than 1600cc injectors. I guess if you were trying to run the 2000cc it might. Get one of the rr guys to make a def for min ipw on whatever rom your working with. Then you could lower it.
#114 | |
Member#: 193014
Just a little extra load such as a/c compressor running smooths it out nicely Light weight flywheel ftl...... |
#115 |
Member#: 132587
Vehicle:2006 JrTuned STi E85 GT3582r/10.83@126mph |
I hope I'm not another victim of these injectors. Been working with my tuner and we are having a hell of a time getting it to run right. It will idle fine one minute and cruise fine but once you try to transition from cruise to idle the car either does or barely runs at 3-500rpm while running rich as hell.
#116 | |
Member#: 193014
#117 |
Member#: 132587
1200cc sidefeed. E85.
I just want it to idle. If I can get it to run without dying thats all I want at this point. |
#118 |
Member#: 36033
SCIC
Your going to drive yourself nuts trying to run a big sidefeed.
I suggest going top feed.... |
#119 | |
Member#: 193014
#120 |
Member#: 132587
It is in the plans but as for now...I just want to get it running/driving. What can be done? I don't care about idle quality as much as I just want it to recover from cruising and return to idle without dying...
#121 | |
Member#: 193014
Still worth a shot |
#122 |
Member#: 132587
Thanks for the tip. What kind of problems were you experiencing prior to changing the latency?
#123 | |
Member#: 193014
#124 |
Member#: 132587
So it would just die? Or stumble really hard at 3-400rpm?
Would it get really rich while trying to stumple/run as it tried to recover? |
#125 | |
Member#: 193014
| Thread Tools | |
| Display Modes | |
| Five O Motorsports Injectors | apsdsmracer | Car Part Reviews | 164 | 02-14-2013 04:08 PM |
| The 2.0 vf34 that did, now a built 2.0/2.5? hta green on e85 | karlknaupp | Proven Power Bragging | 674 | 08-06-2012 10:49 PM |
| 555 Motorsports June Tuning Trip (June 19-22) | Benchmark Tuning | MWSOC Vendor Classifieds | 35 | 07-14-2008 10:21 PM |
| 555 Motorsports Chicago Tuning Trip & Dyno Day #'s | Benchmark Tuning | Proven Power Bragging | 11 | 07-13-2008 01:48 PM |
| Primitive Motorsports/Cobb Tuning/JC Sports??? | Kevin Thomas | General Forum Archive | 24 | 10-01-2000 06:54 PM |
