Old 02-26-2012, 01:29 AM   #226
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
@slowdriver: right on brother
bbarnhill is offline   Reply With Quote
Old 02-26-2012, 08:27 AM   #227
slowdriver
RIP
Member#: 220196
Logged a car with known dynapack numbers of 236/265 on my special stretch of road and the HP was spot on, TQ was 10 down. Tire was 25", 250lbs of total weight added between me, laptop and junk in the trunk.
The only "issue" is that this road, which is a one way on ramp to the interstate, is a *slight* incline, perhaps a 20ft climb over the course of 1/2 mile. Yes, its a long on ramp. I can do WOT and run out 1-2-3 before actually merging onto the interstate.
I cant my boost to show in the AFR chart, but I have not researched that problem yet.
slowdriver is offline   Reply With Quote
Old 02-26-2012, 09:43 AM   #228
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
ummm what was the problem ... the road?
send me a log and ill find out why the boost isnt showing. Probably a missing column in my definition file
Old 02-26-2012, 09:47 AM   #229
slowdriver
RIP
Member#: 220196
No, I think the road is "good enough" since it was spot on for HP and TQ was only 10 down.
The problem is the boost wont show in the lower chart with the AFR but it comes up in "graph other data"
What name should the boost column be in? I can just change that, its not a big deal.
Old 02-26-2012, 11:47 AM   #230
slowdriver
RIP
Member#: 220196
Sent you 3 logs. I was looking thru my archived logs and looking at what a few cars might be making (and my guesses were close to correct!) and I had a few display boost while others did not. I think its a naming issue.
Old 02-26-2012, 06:50 PM   #231
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Can anyone confirm that the BOOST column is a stock column name and not a modified column name? (In RomRaider logs of course)
Old 02-26-2012, 06:53 PM   #232
slowdriver
RIP
Member#: 220196
It is most defiantly ***NOT*** as that column in the log I sent you I had forgotten that I renamed it in an effort to see if VD would make it show up in the lower chart along with AFR.
MY FAULT!
(I also emailed you that fact in response to the email you responded to after i sent you said logs)
Old 02-26-2012, 07:03 PM   #233
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
The boost column is gonna be hard...there's like 6 different variations of "boost" u can log
Old 02-26-2012, 07:07 PM   #234
slowdriver
RIP
Member#: 220196
Yep, that was the problem I ran into. The two logs that had manifold relative pressure (direct) (sea level) corrected *4 byte or something like that was not translating into that second chart.
but it would show under "graph other data" or whatever it was called.
The "boost" column I renamed in a log file just to see what was up.
Old 03-21-2012, 06:57 PM   #235
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
I sent 1.1.8 beta 11 to the beta tester last night. He will get back to me by the weekend and Ill hopefully get good news and release that to you guys this weekend. No promises just making sure you know that Im still pushing to get 1.1.8 out as it fixes a lot of bugs I hope.
Old 03-21-2012, 07:58 PM   #236
Bill in Mtl
Member#: 188357
2016 WRX 6MT
Great - thanks for the update, which gets updated first,
facebook or NASIOC
Regards,
Bill in Mtl is offline   Reply With Quote
Old 03-21-2012, 10:08 PM   #237
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
whoops i knew i left a site out ... going to update facebook now
Old 03-21-2012, 10:09 PM   #238
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
wait a second .... I already updated facebook as soon as the update was pushed out ... man I dont even remember posting that on facebook. It was late after a LOOOOONG day yesterday.
Old 03-25-2012, 03:35 PM   #239
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Default Virtual Dyno 1.1.8
1.1.8 has been released. Come and get it!!!
Here is a list of the changes:
- Fixed a bug allowing the display values popup on graph other columns to draw offscreen
- Fixed UI bug that left selected profiles blue when another profile was selected
- Fixed miscoloring of smoothing options on run specific context menu
- Fixed UI bug where was border showing on both sides between HPTQ graph and AFRBoost graph
- Fixed delay when profile is selected till the time the menu is hidden
- Fixed incorrect loading of smoothing factor from saved settings file
- Fixed a bug when writing columnnames.xml on update that caused the invalid root element error
- Added dropdown to select profile from bottom of screen where active profile is displayed
- Added check for file in use when loading columnnames.xml as it may still be updating
- Added trimming of commonly trimmed char from column names when looking for column
- Added EcuTek log support
- Added LS2Edit log support (.LOG only)
- Added Link G4 log support (after running the llc2csv converter only)
- Added UV Scan log support
- Added more time formats to be compatible varying time formats
- Added setting to allow toggling smoothing time in case of unsmooth time signal
- Revamped the settings window to be a window instead of a panel
- Persist all settings across program in a common settings object instead of reading form settings screen
- Moved all updating to the splash screen so updates are done before loading the application
- Replaced most typeof comparisons with the 'is' keyword
- Removed system serial number and install id as it caused instability with the UAC
- Removed application manifests that elevated security and disabled drag and drop with UAC on
- All update versions come from the webservice instead of direct web xml reads
- Column updates are now through the webservice
- Cancel zoom button is always visible but disabled when graph is not zoomed
Old 03-30-2012, 03:11 PM   #240
Xtreme.
Member#: 292380
Thanks for this app. Will give it a try tonight
Xtreme. is offline   Reply With Quote
Old 03-31-2012, 10:03 AM   #241
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
You are mighty welcome. Hope you find it useful.
Old 04-02-2012, 03:26 PM   #242
dux10
Member#: 235338
2002 Faggin Wagon
srp
Brad, same logs used in 1.1.7 and again in 1.1.8 gave different numbers. I'm gonna double check that before I send you the logs, but have you heard this complaint yet?
dux10 is offline   Reply With Quote
Old 04-02-2012, 04:45 PM   #243
Evo_Kid
Member#: 100218
04 AW STI
04 WW EVO 8 RS
I believe Brad made the smoothing algorithm better and this can slightly affect numbers. But now the numbers are more accurate now.
Evo_Kid is offline   Reply With Quote
Old 04-02-2012, 07:19 PM   #244
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
The smoothing algorithm has been modified as it was exponentially (compound) smoothing before. It would smooth more as the log progressed as it was using the value already smoothed for the average for the next point. This meant that the first value was compound smoothed before leading to exponential smoothing. This was completely wrong. This is the source of the power differences in 1.1.7 and 1.1.8 Just because your numbers dont match a previous version doesnt mean its wrong. Virtual Dyno has bugs in it as does all software (thats an hour long debate there) ... and I removed one and this caused the smoothing to change a bit.
Does that help?
Old 04-04-2012, 03:31 AM   #245
Xtreme.
Member#: 292380
I just gave this app a shot tonight, and I am very impressed man! Good job and keep up the good work!
Old 04-04-2012, 11:31 AM   #246
dux10
Member#: 235338
2002 Faggin Wagon
srp
Does that help?
it makes sense, but the older numbers were more inline with what I typically expect from certain setups. Now, the numbers are a fair bit higher and I feel uncomfortable making claims/telling customers output based on these numbers vs the old (while they're just numbers, the old numbers were repeatedly proven to be within 3% of an actual dyno)
Some of us catch enough flack as it is: http://forums.nasioc.com/forums/show....php?t=2283307
Old 04-04-2012, 03:11 PM   #247
Evo_Kid
Member#: 100218
04 AW STI
04 WW EVO 8 RS
Mmmm, Others have reported that the new smoothing made the numbers go down a lil bit from previous version.
Old 04-04-2012, 04:05 PM   #248
dux10
Member#: 235338
2002 Faggin Wagon
srp
nope. they went up. 10-15 on my cars in the 310-350 range.... Haven't tried any other logs.
I may post examples later tonight.
Old 04-04-2012, 08:10 PM   #249
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Ive got a base log that I know was done right before a dynojet run and its still at 701 as it was before the smoothing modification. It may be due to the log not being exponentially smoothed later in the log like it was before and as a result requires more smoothing than before. Let me know if this is characteristic to what you are seeing.
Old 04-05-2012, 09:51 AM   #250
dux10
Member#: 235338
2002 Faggin Wagon
srp
I found something really odd- the 16bit cars are getting higher numbers since the update, but the 32bit cars are staying the same.
20g on a two liter 19psi vs 21psi old:
20g on a two liter 19psi vs 21psi new:
16g on a two liter old:
16g on a two liter new:
2005 STI tuned various setups old:
2005 STI tuned various setups new:
My 16 bit cars want the old version back plz..... I feel uncomfortable using the program with the new numbers...
EDIT: if I change the correction factor from 1.09 to 1.07 I get old numbers again. Still don't like it though....
Log analyzer - check it out jmc9809 Engine Management & Tuning 42 11-04-2007 09:00 AM
New Log-Analyzer program comming soon! NavyBlueSubaru Engine Management & Tuning 69 03-24-2007 03:17 PM
U-LAME -- UTEC Log Analyzer and Map Editor WolfDrive Engine Management & Tuning 14 12-05-2005 11:01 PM
UTECA (new log analyzer software)... need beta testers WolfDrive Engine Management & Tuning 10 05-31-2005 02:42 PM
