Old 04-05-2012, 03:01 PM   #251
Evo_Kid
Member#: 100218
04 AW STI
04 WW EVO 8 RS
Me and brad are exploring this issue.
The smoothing algorithm was incorrect before and is correct now and what we think happened, is that the incorrect smoothing algorithm forced us to run a higher dyno CF to duplicate dynojet numbers. Now that the smoothing algorithm is correct, the dyno CF is too high and we are reviewing/testing lowering it.
Also, one thing to note, is that the new smoothing algorithm smooths less per setting, so to you will have to run more or double the smoothing you used to run on the old smoothing algorithm.
Evo_Kid is offline   Reply With Quote
Old 04-05-2012, 03:47 PM   #252
dux10
Member#: 235338
2002 Faggin Wagon
srp
I noticed this as well. I went from 6-12 smoothing and gotta better results. This plus altering the correction factor made it better, but not something I wanna be experimenting with while tuning.... lol
i'm assuming the 32bit results were better due to less data captures per second...
dux10 is offline   Reply With Quote
Old 04-06-2012, 03:01 AM   #253
dux10
Member#: 235338
2002 Faggin Wagon
srp
any more news/updates? i hate to say it, but I've temporarily stopped using it and have been relying more on airboy:-( and I'm one of the biggest advocates for the software....
Old 04-06-2012, 07:59 AM   #254
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Im on top of this ... Im trying to analyze the data and the more dyno pulls someone has with logs on the same day ... the better and more accurate I can be. Anyone got any? Dont worry Ill get this looked into asap.
bbarnhill is offline   Reply With Quote
Old 04-19-2012, 01:05 PM   #256
ppayer38
Member#: 234407
04 Self-tooned
STi
This has probably been covered already but how can I get my AFR to trace out with Boost?
I know and can use the other separate graphs but even thoughs dont have any other numbers other than RPM and without hitting each data point it makes it complicated to read the data...
Can somebody help me out with this? Log problem or am I just missing something simple haha
Donation will be coming shorty
ppayer38 is offline   Reply With Quote
Old 04-19-2012, 06:01 PM   #257
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Open Virtual Dyno, Select file> Options.
A "Virtual Dyno Settings" window will appear with three tabs
Graph | Dyno | Columns and Profiles
Select Colums and Profiles
Put check next to AFR
Open your latest datalog and copy the name of the column that shows your WB02, and paste it into the space next to AFR
Example: My computer shows
AFR : AEM UEGO Wideband [9600 baud] (AFR Gasoline)
Hit "SAVE" and load a good datalog!
Black94Snake is offline   Reply With Quote
Old 04-19-2012, 09:03 PM   #258
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
yeah I am getting higher number with the latest version
Old 04-20-2012, 01:22 AM   #259
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Atleast you are getting numbers. Mine has quit working. Loads but doesn't show up on screen
Problem has been reported, hopefully he figured it out
bswilmington is offline   Reply With Quote
Old 04-20-2012, 09:17 AM   #260
dux10
Member#: 235338
2002 Faggin Wagon
srp
^^^ start task manager then right click "virtual dyno" in the task manager and click "maximize"
I have to do this from time to time as well with learning view.
Old 04-20-2012, 09:30 AM   #261
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
You can right click it on the task bar too....
Old 04-20-2012, 11:13 AM   #262
bswilmington
Member#: 217563
I'll try those shortly. Thanks for input
Edit: screen maximazer in control panel fixed the problem. Thanks for the help
Old 04-21-2012, 11:00 AM   #263
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
really? Wonder how I can reproduce this bug. Interesting that you all found a work around. Now to find the problem These are the bugs that haunt me at night.
Old 04-21-2012, 11:02 AM   #264
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
@juanmedina: yes your numbers will be higher (peak) as the smoothing algorithm was OVER smoothing by compound smoothing more and more as it traversed the graph.
I need some dyno plots from a dynojet and a log from the same car on the street if anyone has any. This will help me compare and reanalyze the correction factors for dyno jet plots.
Old 04-23-2012, 03:11 PM   #265
dux10
Member#: 235338
2002 Faggin Wagon
srp
^^^^ somebody get him these please....... lol
Old 04-30-2012, 12:24 PM   #266
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I had been e-mailing Brad about the high reading issues, but I never got back to him after getting on the dyno. I seem to have issues even on version 1.1.7. I have found that the older non-fast polling RomRaider logs are very accurate, but the new ones (fast polling) seem to read really high.
Dynojet: 462WHP / 492WTQ
Virtual Dyno: 501WHP / 520WTQ
The shape of the plots looks nearly identical. The numbers are just skewed upwards for the Virtual Dyno. I did the same type of comparison when I was on the stock turbo and E85. Using non-fast polling RomRaider and comparing to the same Dynojet I got the following. Very close.
Dynojet: 340WHP / 369WTQ
Virtual Dyno: 338WHP / 381WTQ
xluben is offline   Reply With Quote
Old 04-30-2012, 12:43 PM   #267
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
hope this is sorted out I do not want to go back to Airboy !
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 04-30-2012, 07:46 PM   #268
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
You sure thats correct ... cause if any should have an issue 1.1.8 should. 1.1.7 was exactly the same as 1.1.1 even just cosmetic changes. 1.1.8 is the one that I fixed the smoothing algorithm. That 1.1.7 graph would show the same values as 1.1.6 and before. Double check your car choice and make sure the weight is correct.
Old 04-30-2012, 07:47 PM   #269
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
dont start a riot yet
Old 05-01-2012, 08:10 AM   #270
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I've been e-mailing Brad, but here's what I had sent him a while back:
I tried out the Beta (1.1.8). I plotted the logs with the same settings as the 1.1.7 version and got slightly different numbers. Two of the logs went up by about 15-20hp with the beta version (one was fast polling and one wasn't), and one of the logs went down by 5hp (fast polling). I compared them both to plots created with the Airboy spreadsheet. The two Virtual Dyno plots have identical settings between the two (same weight, etc. and smoothing at 6). The Airboy plot uses a smoothing of 6 for the green line (slower data rate) and a smoothing of 16 for the red and blue lines (fast polling). The shape of the curve between all the plots look nearly identical, and they are all reasonably smooth, but the peak numbers just vary quite a bit.
Peak HP Numbers:
Airboy.........VD1.1.7......VD1.1.8.....Dynojet... RomRaider
326HP.........338HP.........351HP........339HP.... ..Non-Fast Polling
366HP.........415HP.........410HP........NA....... ...Fast Polling
438HP.........501HP.........520HP........462HP.... ..Fast Polling
% Difference vs. Airboy:
3.70%........7.70%
13.40%......12.00%
14.40%......18.70%
As I've mentioned to Brad, I think 1.1.8 does read higher in most cases. But I think the bigger difference seems to be my old logs vs. my newer logs, and I think that is from fast polling on RomRaider. The erratic numbers that RomRaider spits out (rpm's go up and down, etc) throw off the smoothing. Anyone want to try fast polling vs. non-fast polling (and possibly vs. COBB AP)? I would be curious to see how the data rate changes the numbers.
Old 05-01-2012, 08:32 AM   #271
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
I don't quite catch the drift with the Normal logging vs. Fast Polling. For sure Fast polling is the way to go.
I'm on a different ECU but also supported by VD and I am running 50 Hz refresh rates which is much faster than Fast Polling on OE ECUs. However I see no differences between running say 25Hz and 50Hz. Hell, next time I'll try 100Hz to see if that makes a difference. I have no Dynojet unfortunately to compare to.
I have a Dynapack and I will do some tests to see how it compares. Perhaps we could get a Dynapack algorythm setup eh?
Cheers,
Jasper.
jkopinga is offline   Reply With Quote
Old 05-01-2012, 08:37 AM   #272
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It's not necessarily the rate that the data comes out in, it's the fact that the ECU outputs junk data on fast polling. If you look at the data against time, the RPM's actually go up and sometimes go down. Obviously your RPM's should not be going down during a WOT pull, and this screws up the calculation.
There isn't really any algorithm for the correction factor. You just multiply the "Virtual Dyno" number by a percentage. Dynojet is 9% higher and Mustang is 5% lower.
Old 05-01-2012, 08:38 AM   #273
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Oh I know that fast polling is way wrong ... I dont know what they do different with those logs but they have big spikes in the data where the RPM doesnt correlate to the Time very well. Ive posted on their forum about it but they dont answer. Do not use fast polling to get power logs for now.
Old 05-01-2012, 08:44 AM   #274
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
You sure that the RPM wobbles are not due to slipping wheels, slack in the drivetrain, etc. ? I sometimes DO see some RPM bounce but have to agree mostly it is very linear. However as I mentioned I am on a Standalone and surely willl be different than OE.
Cheers,
Jasper.
Old 05-02-2012, 09:10 AM   #275
juanmedina
Member#: 133146
how do you turn off fast polling?
Using the same log I make the following:
VD 1.1.8 525whp dynojet
Airboy 447whp
Ed Eqtuning road dyno 423whp
Log analyzer - check it out jmc9809 Engine Management & Tuning 42 11-04-2007 09:00 AM
New Log-Analyzer program comming soon! NavyBlueSubaru Engine Management & Tuning 69 03-24-2007 03:17 PM
U-LAME -- UTEC Log Analyzer and Map Editor WolfDrive Engine Management & Tuning 14 12-05-2005 11:01 PM
UTECA (new log analyzer software)... need beta testers WolfDrive Engine Management & Tuning 10 05-31-2005 02:42 PM
