Old 05-02-2012, 10:20 AM   #276
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
This is from the RomRaider download page:
Moved the Fast Poll checkbox to a selection item in the Settings menu (selected by default). The polling state is reported in the queries/sec status display.
I'm very curious to see your results with fast polling on vs. off. I haven't had a chance to try it yet.
xluben is offline   Reply With Quote
Old 05-02-2012, 11:41 AM   #277
Dartholomew
Member#: 208771
2009 WRX
I've noticed this as well, and I think it depends on whether the junk data affects the good data.
I've actually gone through a RR log and deleted rows where the RPM goes down. I recall it not making much difference in the graph, I suspect because in the end, you're still left with (2000rpm @ 0:00" -> 6000rpm @ 6.0") regardless of what's in the middle, and VD doesn't show as much of a taper in the HP towards the end.
FWIW, I log regularly with RR and standalone, and the results are very similar (you may notice a lot of peaks/valleys in the RR logs but if you're reasonably honest about catching outliers, the smoothing brings it inline with standalone results). Just from what I remember...
Dartholomew is offline   Reply With Quote
Old 05-02-2012, 11:55 AM   #278
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Brad just informed me that Virtual Dyno already throws out points were RPM goes down, so that's why you don't see a difference.
Old 05-02-2012, 12:15 PM   #279
dux10
Member#: 235338
2002 Faggin Wagon
srp
I did several weeks ago and sent the results to brad.
If you set the smoothing factor to "0" in VD you can sometimes see crazy spikes (sometimes as high as 900hp on a car that makes ~320whp). With these spikes, it makes the final numbers really high with normal smoothing.
With fast polling turned off, you do not get these spikes and therefore more normal numbers....
dux10 is offline   Reply With Quote
Old 05-02-2012, 12:18 PM   #280
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Yep, some of my fast polling logs spike up to like 2,000HP with smoothing turned off. It's good that you confirmed that turning fast polling off seems to fix the problem.
Old 05-02-2012, 01:29 PM   #281
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
I will do some pulls tomorrow. I did a 50-100mph video and it was only 4.8sec . I guess I was down in power or something. My car should be a little faster it weight 500lbs less and it should make more power .
Old 05-02-2012, 01:35 PM   #282
dux10
Member#: 235338
2002 Faggin Wagon
srp
Only problem is, I now have to do two pulls: one for data (petter resolution with fast polling means more data to look at) and a second one for dyno readout...
I'm suprised you guys with 32bit ECU's are having similar issues. I know the 2-3 32bit cars I've done in the last month were ok in VD. I just assumed that since the ecu sends data much slower than the 16bit's the errors would be less apparent.
Old 05-02-2012, 01:44 PM   #283
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Yeah, it definitely should be. Either that or you're entering something into the dyno programs incorrectly and you really have less power? That's another reason I like 50-100mph. More real-world. Road dyno's rely on accurate info from the user for accurate results. 50-100mph just tells you who is faster from one speed to another.
You have a way bigger turbo and same or higher boost and a light car though. I would expect you to be faster! Do you have two shifts? I think I only have to do one shift between 50 and 100mph. I can even do it reasonably quickly with no shifts, but the lag at the beginning makes a hair slower than with the shift.
Yeah, that is a bummer. I'm trying to think of a good way for the software to work around the bad data, but I don't know if it will pan out, or if Brad will want to code it into the program. It seems like it would be possible, but it is kind of stupid that the program has to be modified to work around a crappy data output form the car
Old 05-02-2012, 01:57 PM   #284
juanmedina
Member#: 133146
07 FPgreen 7.37@95
I shifted once from second to third. I know my parameters for the road dyno are correct since I had the car corner weight. The only bad thing is that it was 90*F.
Old 05-02-2012, 01:58 PM   #285
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Yeah, yours should do it much faster than mine!
Old 05-03-2012, 12:29 AM   #286
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
... but its not crappy data from the car its crappy recording of data ... the time should be stamped when the RPM value is returned not before the request is made.
bbarnhill is offline   Reply With Quote
Old 05-03-2012, 12:33 AM   #287
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
How did you come to this conclusion? The time stamp goes up steadily with each data point. The rpm does not. This tells me that the ECU is outputting incorrect or erratic data. If it was a bad time stamp the rpm would go up consistently and the time would jump around. Does anyone have any fast polling COBB AP Subaru logs? Do they do the same thing?
Old 05-03-2012, 09:20 AM   #288
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Not necessarily. ECUs dont have to respond immediately when a request is made. This is in all of their designs. You request a pid and when they get around to it they respond. So you can NOT say time is linear all the time. It must be timestamped when the response returns as this would be the only accurate way of recording time and RPM and getting them to correlate. The delays will be in milliseconds but the faster the sample rate is the more pronounced the problem in the graphed data. In excel graph Time on the X axis and RPM on the Y axis and see what I mean. Its not big humps but the small humps will cause be time spikes in VD as that calculation for power is very sensitive. Does that help?
Old 05-03-2012, 09:31 AM   #289
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
That make sense, but I would assume (maybe incorrectly?) that the ECU would at least respond to the request in the same order that they receive them. If that's the case, then there is no reason that the RPM's would go down from one data point to the next.
In the situation you're describing, you could get erratic RPM data (would not correlate properly with time), but it should still always be sequential (assuming the ECU responds first in, first out). The only way it would not be sequential is if the RPM data is junk.
I'm no software engineer, so correct me if I'm wrong.
Old 05-03-2012, 09:05 PM   #290
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
well who knows how RR is sending them too. The polling may be multithreaded in the application(RR) and RR be putting them in order incorrectly due to mishandling of threads. Who knows it could be either one. Both are very plausible.
Here is the RR thread on it:
http://www.romraider.com/forum/viewt...ea771&start=30
Old 05-03-2012, 09:27 PM   #291
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
so what version of VD is the most accurate/reliable now? logs from AP, 32-bit ECU.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 05-04-2012, 10:38 AM   #292
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
??? all of them ??? 1.1.8 just corrects a smoothing bug that over flattens the graph.
http://www.mazdaspeedforums.org/foru...-close-110718/
Thats just one comparison that has been done ... there are more throughout the message boards out there. They all come to the same conclusion ... "its pretty darn close"
Old 05-04-2012, 12:22 PM   #293
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Here's how my logs compared to the two times that I was on an actual Dynojet.
20G XTR 27psi - Fast Polling RomRaider Log
  • Actual Dynojet: 462WHP / 492WTQ
  • Airboy Excel File: 438WHP / 460WTQ
  • Virtual Dyno 1.1.7: 501WHP / 520WTQ
  • Virtual Dyno 1.1.8: 520WHP / 514WTQ
VF52 21psi - Normal Polling RomRaider Log
  • Actual Dynojet: 340WHP / 369WTQ
  • Airboy Excel File: 326WHP / 348WTQ
  • Virtual Dyno 1.1.7: 338WHP / 381WTQ
  • Virtual Dyno 1.1.8: 351WHP / 38WTQ
Old 05-04-2012, 01:47 PM   #294
dux10
Member#: 235338
2002 Faggin Wagon
srp
Xluben, do a slow poll and see where it slots in on your current setup?
Old 05-04-2012, 02:20 PM   #295
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Yeah, it's on my to-do list, but my laptop doesn't like logging very much.
Old 05-04-2012, 02:34 PM   #296
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Here is VD and pull done on innvotive dyno today on dynojet. This is buddies car that I tuned and he had dyno pulls done. I believe he still has the old logger with non fast poll but Ill double check shortly. The VD dyno is weather and pressure corrected and it was done in 3rd gear. The dyno pulls was done in 4th VD in 3rd
VD 328hp/331trq
Real dyno 317hp/307tq
VD-3rd gear pull
Real dyno 4th gear pull using dynojet correction
bswilmington is offline   Reply With Quote
Old 05-04-2012, 02:37 PM   #297
Dartholomew
Member#: 208771
2009 WRX
Here's another test: does anybody have a pull from a CAN-line log? Does that present the same up/down rpm as fast polling, or is it both faster AND cleaner?
Old 05-04-2012, 02:38 PM   #298
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
That's a Mustang dyno printout. And it must be a SUPER high reading Mustang if it nearly matches Virtual Dyno 1.1.8 on Dynojet mode! Either that or something else is going on... I would have expected the VD on that setting to read 15-20% higher than the Mustang dyno.
Old 05-04-2012, 02:51 PM   #299
bswilmington
Member#: 217563
Are you sure it's mustang? Not saying your not right but I looked up which one it was and they said its dyno dynamics or dynojet readout, customers choice. But I agree I would expect VD on dynojet to be 15% higher than mustang.
link to page http://www.wrxmodders.com/forums/viewtopic.php?t=13751
Old 05-04-2012, 02:55 PM   #300
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Maybe I'm wrong, but that looks like a Mustang printout to me.
Log analyzer - check it out jmc9809 Engine Management & Tuning 42 11-04-2007 10:00 AM
New Log-Analyzer program comming soon! NavyBlueSubaru Engine Management & Tuning 69 03-24-2007 04:17 PM
U-LAME -- UTEC Log Analyzer and Map Editor WolfDrive Engine Management & Tuning 14 12-06-2005 12:01 AM
UTECA (new log analyzer software)... need beta testers WolfDrive Engine Management & Tuning 10 05-31-2005 03:42 PM
