Old 05-04-2012, 02:00 PM   #301
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Originally Posted by xluben View Post
Maybe I'm wrong, but that looks like a Mustang printout to me.
I dont disagree with you about that, looks like one to me also.
But this car is tuned to 19psi tapering to 15psi and is relative safe tune as I didnt push timing so I would highly doubt this car would make this power level on true reading mustang.
Edit:confirmed it was dynojet corrects used
bswilmington is offline   Reply With Quote
Old 05-04-2012, 04:16 PM   #302
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
+12345
Old 05-04-2012, 04:30 PM   #303
bswilmington
Member#: 217563
Originally Posted by juanmedina
+12345
I edited orginial post, guy said they stated it was on dynojet setting.
Old 05-04-2012, 05:35 PM   #304
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The Virtual Dyno plot is on the Dynojet setting. It says right at the top.
The actual dyno plot is from a Mustang. That is how all Mustang printouts look.
xluben is offline   Reply With Quote
Old 05-04-2012, 06:32 PM   #305
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Did 4 logs today 2 non fast pulling 2 with it on
the ones with it on I made 45-50 more WHP then the ones with it off
410 and 408 with it off
458 and 462 with it on
renosubby is offline   Reply With Quote
Old 05-04-2012, 07:09 PM   #306
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Wow! Great test! That change would put my Virtual Dyno numbers nearly spot on with my actual Dynojet numbers! I guess the official recommendation will just have to be to turn off fast polling for all Virtual Dyno logs.
BTW, do you really trap 129mph and only make 400WHP on Virtual Dyno. That doesn't seem right. I'd guess you would have to be well over 500HP on Virtual Dyno for that trap speed.
Old 05-04-2012, 07:17 PM   #307
Evo_Kid
Member#: 100218
04 AW STI
04 WW EVO 8 RS
Can someone please tell me what version of RR started having the two types of polling? I cant find the option in my settings menu.
TIA
Evo_Kid is offline   Reply With Quote
Old 05-04-2012, 07:17 PM   #308
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I think it's been like a year.
Old 05-04-2012, 07:19 PM   #309
Evo_Kid
Member#: 100218
04 AW STI
04 WW EVO 8 RS
Version number?
Im on RomRaider0.5.3BetaRC7 or RC10
Old 05-04-2012, 07:22 PM   #310
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Update to the latest version. That will have it.
Old 05-04-2012, 07:29 PM   #311
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
TIA
I dont use rom raider. I use a program called ECU edit. there is a check box is you want to use fast polling
Old 05-04-2012, 07:30 PM   #312
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
no 129 was around 475 WHP on E85. The test I did was my pump gas tune at 21.5 psi that a low to mid 120 trap
These were done one the VD setting as well
Old 05-04-2012, 08:31 PM   #313
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
RR fast polling causes weird numbers for HP and TQ. They both get put through the same logic to create the HP and TQ numbers so there has to be something different in how they are logged. Ive noticed some really big spikes and time and RPM not correlating in fast polling logs. Id hold off on trusting fast polling when tuning and using Virtual Dyno. It just seems flaky to me.
bbarnhill is offline   Reply With Quote
Old 05-04-2012, 08:33 PM   #314
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
renosuby just showed that ECU Edit fast polling does the same thing.
Old 05-05-2012, 03:12 AM   #315
Evo_Kid
Member#: 100218
04 AW STI
04 WW EVO 8 RS
I have also notice that the "Smooth Time & RPM" option in VD affect the numbers. Having it unclicked makes the numbers higher.
Old 05-06-2012, 12:03 PM   #316
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Its due to that option smoothing time and rpm prior to power calculation. Ant smoothing lowers peak power but gets rid of error. So you have to balance it like on a real dyno. Spikes are anomalies and you can usually tell by looking at a graph if more smoothing is needed or there is some abnormal spike
Old 05-06-2012, 12:21 PM   #317
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
I want to use VD for pre vs post upgrades comparisons, what smoothing factors / parameters should I select?
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 05-06-2012, 12:53 PM   #318
bswilmington
Member#: 217563
For your comparison make sure to use non fast polling as power level isn't correct on fast polling.
When using smoothing start from 1 ( 0 is always to wavey) and keep increasing smoothing until the humps get smaller. You don't want to over smooth as it will alter shape of graph to much. Dyno should have some small curves or ripples to it unless it just really smooth pull.
When using non fast polling I typically use 3-4 smoothing but it just depends on the humps in graph.
Old 05-06-2012, 01:12 PM   #319
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
thx, does AP login feature spit non fast pollling data?
Old 05-06-2012, 01:17 PM   #320
bswilmington
Member#: 217563
I'm not sure I use openecu/romraider but I'm sure someone will answer you.
Old 05-26-2012, 04:35 AM   #321
DisoDisp
Member#: 187648
2007 WRX
can't get this software to work, no matter what I've tried.
Manually gone through the .xml file, added my log parameters to the appropriate columns etc. (RomRaider logs)
Keep on getting "No wide open TPS data found", even though my TPS log shows over 100.
or:
E111 Column 'Throttle Plate Opening Angle (4-byte)* (%)' does not belong to the table 3rdgearlog.csv.
And E106: Imput string was not in a correct format.
even though it does....
Any ideas on how to get this to work.
DisoDisp is offline   Reply With Quote
Old 05-26-2012, 06:03 AM   #322
DisoDisp
Member#: 187648
2007 WRX
fixed it, changed system regional settings to English (American) and it all works as it should, appraently us metric folk are SOL
Old 05-26-2012, 06:40 AM   #323
ppayer38
Member#: 234407
04 Self-tooned
STi
So I swapped wheels on my car and now my graph looks totally different?
No other adjustments to the car other than the wheels...
Anybody else ever had this it just a fluke thing
ppayer38 is offline   Reply With Quote
Old 05-26-2012, 09:39 AM   #324
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
are your tires a different size? Are the wheels lighter? Was the second test run under the same environmental conditions as the first? Did you set the ambient temp and tire size correctly for the graphing?
Black94Snake is offline   Reply With Quote
Old 05-26-2012, 01:37 PM   #325
Evo_Kid
Member#: 100218
04 AW STI
04 WW EVO 8 RS
There an option for metric in Virtual dynos options
Log analyzer - check it out jmc9809 Engine Management & Tuning 42 11-04-2007 09:00 AM
New Log-Analyzer program comming soon! NavyBlueSubaru Engine Management & Tuning 69 03-24-2007 03:17 PM
U-LAME -- UTEC Log Analyzer and Map Editor WolfDrive Engine Management & Tuning 14 12-05-2005 11:01 PM
UTECA (new log analyzer software)... need beta testers WolfDrive Engine Management & Tuning 10 05-31-2005 02:42 PM
