Old 05-26-2012, 05:42 PM   #326
ppayer38
Member#: 234407
04 Self-tooned
STi
Originally Posted by Black94Snake
are your tires a different size? Are the wheels lighter? Was the second test run under the same environmental conditions as the first? Did you set the ambient temp and tire size correctly for the graphing?
Yes the tires are different...
Runs where back to back under the same day...
All settings where correct.
Weirdest thing I've seen, and I out my stock set back on and the graph went back to the same as before haha
ppayer38 is offline   Reply With Quote
Old 05-27-2012, 06:07 AM   #327
DisoDisp
Member#: 187648
2007 WRX
Originally Posted by Evo_Kid View Post
There an option for metric in Virtual dynos options
Yes, but it doesn't change the metric notation for the original .csv file.
i.e. metric uses , instead of . and ; instead of ,
Hence when I try to open a metric .csv file (in excel) now that the regional settings are set to English (American) it gets all jumbled, and make no sense.
standard .csvs open right up, and vice versa.
DisoDisp is offline   Reply With Quote
Old 05-27-2012, 01:34 PM   #328
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
yes this metric notation in csv is retarded since its a COMMA seperated values file. Metric values dont adhere to COMMAS seperating values.
I havent fixed this yet and its a pain in the rear to fix really. Ill see if I can find a way to detect this because some regions use part of the metric notation and not all of it and that throws a monkey wrench in the mix.
Kinda dealing with exwife issues at the moment and trying to find time to develop on this Stupid exwife.
bbarnhill is offline   Reply With Quote
Old 05-27-2012, 01:47 PM   #329
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
sorry about your issues, your software though makes lives of us more enjoyable and help us divert our issues concentrating on car projects instead.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 07-17-2012, 02:37 AM   #330
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
hahaha ... for some reason I just read this. That cracked me up.
I just realized that Ill be going to the big Evo meet here in Kansas City in a couple of months and I dont have a nice shirt to wear. Anyone got any suggestions? Ive often wondered why I dont have a Cobb tshirt
Old 07-17-2012, 08:28 AM   #331
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Make Virtual Dyno shirts!
xluben is offline   Reply With Quote
Old 07-17-2012, 08:53 AM   #332
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
I would if I could find someone to make them pretty reasonable.
Old 07-17-2012, 09:14 AM   #333
ppayer38
Member#: 234407
04 Self-tooned
STi
Come up with a logo and I've got a friend who does it... I'll get you a price if you get me a logo in Jpeg or EPS format
Old 07-18-2012, 08:56 AM   #334
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
send me a PM with your email and I can email you a logo.
Old 08-01-2012, 08:19 PM   #335
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Hey Brad, love your program, it would be cool to be able to average back to back runs. I have 6 logs same day taken within minutes of each other and would like to average'em out.
Old 08-01-2012, 08:48 PM   #336
paulpat
Member#: 237145
02 WRX
12 FXT
Interested in this. Average them out in excel? Wait... Will that work? Will averaging even work? some of these formulas and stuff might not be best to average them....
paulpat is offline   Reply With Quote
Old 08-02-2012, 12:06 AM   #337
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
I am talking about a feature on VD to curve fit several runs to produce a single curve.
Old 08-02-2012, 11:21 PM   #338
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
does anyone know a good way to do this? Its a little more complex math than just shoving the runs data together and using that to graph with. I dont think that will work as the differences between points matters and that would screw that balance up pretty good.
Also the same time wouldnt have the same rpm on both runs so they wouldnt fit together good. There has to be some good curve fitting algorithms out there.
Old 08-03-2012, 10:02 AM   #339
dux10
Member#: 235338
2002 Faggin Wagon
srp
Airboy's works well?
dux10 is offline   Reply With Quote
Old 08-04-2012, 10:13 AM   #340
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I'm trying to save custom gear ratios for my gearset, but they seem to get overwritten whenever I start VD. Any ideas? I'm saving them to the "02-05 wrx sedan".
Subian is offline   Reply With Quote
Old 08-04-2012, 12:19 PM   #341
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here are my results using Virtual Dyno vs. the actual Dynojet at MAPerformance. I have two different setups that I've had dyno'd at MAP. The first was with the stock VF52 (on E85) and the second one was the 20G XTR (on E85). Here is more info on the 20G XTR setup if anyone is interested.
http://forums.nasioc.com/forums/show....php?t=2338819
2011 WRX - VF52 - E85:
Dynojet (MAPerformance): 339WHP
Virtual Dyno (Dynojet): 338WHP
2011 WRX - 20GXTR - E85:
Dynojet (MAPerformance): 462WHP
Virtual Dyno (Dynojet): 463WHP
The peak horsepower results are VERY close! The peak torque is different by about 5%, but the overall curves (both power and torque) look very similar. The main issues I see with people posting Virtual Dyno results are the following:
  • Fast Polling turned on when logging
  • Road is not flat
  • Data is not entered correctly (weight, tire size, etc.)
  • Improper smoothing
  • Improper trimming
As long as you give Virtual Dyno good data, it will produce good results. While dyno numbers don't mean much, I've found it to be very useful to track the changes I've made to my car. I find that it's definitely more useful than the old "butt dyno".
Old 08-05-2012, 02:42 PM   #342
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
1.1.9 has been released ... Enjoy!!!
Old 08-05-2012, 08:18 PM   #343
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Here is what I am talking about, be nice to be able to curve fit a bunch of runs, these were taken within the same hour, same road and temperature.
Old 08-06-2012, 12:34 AM   #344
Evo_Kid
Member#: 100218
04 AW STI
04 WW EVO 8 RS
Can someone please check if the new version fixed the power difference between fast polling and non fast polling?
I may have, but then again, it may have not.
Evo_Kid is offline   Reply With Quote
Old 08-06-2012, 01:10 AM   #345
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
fast polling is broken in RR not in VD.
Old 08-06-2012, 11:14 AM   #346
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Since TQ is more important than HP, is there a way to remove HP from the chart?
Or change the TQ line style to solid and HP to dotted. As you can see in the chart post #343 @5,250 rpm there is a lot going on and would like to remove HP to improve legibility.
I understand the calculation of averaging curves would be a daunting task.
Old 08-06-2012, 07:09 PM   #347
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
hum ... so is this something that should be for all runs (ex. turn off all HP and turn off all TQ, or per run) Per run would require more clicking but it adds more granularity. So give me some feedback on which one is better.
Old 08-06-2012, 07:37 PM   #348
1QUIKV6
Member#: 9427
2006 WRX STi
Agree with the "turn off HP" option. In the name of simplicity I'd just make it a single check box that applies to all runs but either way works. It would just be good to have the option to declutter when tuning for best torque.
1QUIKV6 is offline   Reply With Quote
Old 08-06-2012, 10:18 PM   #349
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^+1
Brad, as far as Turn off HP/TQ for ALL or EACH run I'll leave it up to you, whichever requires less coding.
Other suggestions:
Add Chart Title field.
Add ability to draw lines, circles, comments on the chart body.
Old 08-07-2012, 08:40 AM   #350
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
As long as we're throwing out suggestions...
I think chart title would be a very good one. I would also like to be able to set the X and Y axis scale manually. Then you can have two different plots that are on the same scale, even if the HP/TQ and/or RPM aren't in the same range.
Another nit picky one would be able to choose the size and/or aspect ratio that the charts saves as. Having it basically just take a screenshot works OK, but it ends up with some people having square charts vs. some that are long and thin, etc. I think having a visually consistent (default) output would be a good thing (but you could leave the option to change the resolution or aspect ratio).
Log analyzer - check it out jmc9809 Engine Management & Tuning 42 11-04-2007 09:00 AM
New Log-Analyzer program comming soon! NavyBlueSubaru Engine Management & Tuning 69 03-24-2007 03:17 PM
U-LAME -- UTEC Log Analyzer and Map Editor WolfDrive Engine Management & Tuning 14 12-05-2005 11:01 PM
UTECA (new log analyzer software)... need beta testers WolfDrive Engine Management & Tuning 10 05-31-2005 02:42 PM
