Old 08-29-2012, 09:55 AM   #376
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
yes updates are auto to prevent fragmentation
bbarnhill is offline   Reply With Quote
Old 08-29-2012, 09:59 AM   #377
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
any idea when 1.2 will be up and running?
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 08-29-2012, 12:28 PM   #378
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here's a fun plot I made of all the changes I've made to my car:
It's nice to be able to see it all laid out like that!
xluben is offline   Reply With Quote
Old 08-29-2012, 02:05 PM   #379
SeeeeeYa
Member#: 129681
2017 FXT-T ES
SBM/SBL
Wow. It would be nice, though probably not appropriate here I guess, to have a short synopsis and comparative statement on each iteration. I've promised myself I'm stopping at Stg2+ this time, but a little vicarious modding is still fun.
What's great is how VD allows us to easily create such comparisons.
SeeeeeYa is offline   Reply With Quote
Old 08-29-2012, 02:31 PM   #380
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I have thoughts scattered around in various places, but I should really do a summary at some point. VD has been a very fun program along the way!
Old 08-29-2012, 03:17 PM   #381
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
you forgot to account for temps and vehicle weight (1/4, 1/2, full tank of gas) at the time of the log, you can add temps to show in the notes on the chart. Very nice plot indeed, this is why I love VD !
ver 1.2 will allow to toggle off HP so multiple logs in one chart will be easier to digest.
Old 08-30-2012, 09:41 AM   #382
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Nice!!! First chart Ive seen of someone using so many graphs. Glad it supports 10 at a time :P
Old 09-04-2012, 09:48 PM   #383
kaczmarz
Member#: 307624
2008 WRX Hatch
325/347, 380XT, 8 cm2
Don't you think guys that peak torque is always too much to the right compared to the peak boost?
Shouldn't they be almost the same?
Aren't they getting even more apart as you increase smoothing?
On Airboy, with smoothing 1, I'm getting those peaks much closer to each other.
kaczmarz is offline   Reply With Quote
Old 09-08-2012, 12:13 PM   #384
litowrx
Member#: 132418
2004 EJ207
Newbie here, where can I read a how too? I'm about to have my car e-tuned. I would like to have a stock baseline! can I find it in this thread?
litowrx is offline   Reply With Quote
Old 09-08-2012, 12:24 PM   #385
paulpat
Member#: 237145
02 WRX
12 FXT
Seriously just log it. I don't think I'll find a plot here. Do what I wanted to do before I etuned and get a base line. Your car is different and special so why compare to others? Your going to have to find out how to do this anyways. And do me a favor post your stock run some where. I could never find stock pulls. If I would have done it again I would have made a thread in the power proven section for the stock tune. Hint hint.
paulpat is offline   Reply With Quote
Old 09-08-2012, 04:46 PM   #386
litowrx
Member#: 132418
2004 EJ207
Any tips? Just a 3rd/4th gear pull data logging with romraider? WOT? then just drop the file on the VD right?
Old 09-08-2012, 07:15 PM   #387
climbhigh09
Member#: 254163
2011 WRX 20GXTR
3rd. 2k to redline.
climbhigh09 is offline   Reply With Quote
Old 09-13-2012, 09:21 AM   #388
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Any reason VD would cut a log from a full 7k pull to a 6600 one? The excel file is fine, but chart stops early.
Zee Biker is offline   Reply With Quote
Old 09-13-2012, 09:22 AM   #389
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Does the excel file show 100% throttle position all the way to 7k? How many data points are between 6.6k and 7k?
Old 09-22-2012, 04:34 PM   #390
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Brad, how is 1.2 coming alone? Would be nice to be able to select a temperature for all logs instead of having to check SAE and input the temp for each run in the Air temp field. So under the Profiles menu I would add a temp input.
It would also be nice to be able to add text box comments to the chart and arrows, if you need beta users please count me in.
Old 09-22-2012, 05:49 PM   #391
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Me too
Black94Snake is offline   Reply With Quote
Old 09-22-2012, 10:32 PM   #392
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
All great ideas.
Brad okay'd me to give a couple suby users (preferable tuners/experienced self tuners) the beta file. PM me.
Boosted Tuning is offline   Reply With Quote
Old 09-23-2012, 02:16 AM   #393
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
wow cool works with vipec logs!
found a bug, boost doesn't convert to PSI from KPA.
Bariga is offline   Reply With Quote
Old 09-29-2012, 06:56 AM   #394
sub666
Member#: 38052
Why do I have to import the csv first into excel, and seperate the colums by ; then save it as csv and then it will work in VD, is there a faster way, all my region settings are set to US, evoscan logs works right away.
sub666 is offline   Reply With Quote
Old 09-29-2012, 09:13 AM   #395
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Sub666 thats got to be a side effect of the logger you are using formating the logs that way.
Old 09-30-2012, 08:42 AM   #396
sub666
Member#: 38052
I am using romraider logger, can someone confirm this is normal behavior for romraider.
Old 09-30-2012, 03:12 PM   #397
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
You should not have to modify the RomRaider logs in anyway for them to work.
Old 09-30-2012, 10:54 PM   #398
gurusan
Member#: 258165
2006 WRX Wagon
Awesome program. Thanks for your hard work!
Here is my 06 wrx wagon, short ram, tbe, and XPT stage 2
gurusan is offline   Reply With Quote
Old 10-01-2012, 09:51 AM   #399
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
I see this all too often in the subaru world ... what is the definition of Stage 1,2,3?
Old 10-01-2012, 11:09 AM   #400
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
They're just made up by manufacturer's to sell parts packages. Generally...
Stage 1 is a just a tune.
Stage 2 is a tune and a downpipe.
Stage 3 is sometimes considered a new turbo. Stage 2 or 2+ is often considered anything up to a new turbo.
They really don't mean much.
Log analyzer - check it out jmc9809 Engine Management & Tuning 42 11-04-2007 10:00 AM
New Log-Analyzer program comming soon! NavyBlueSubaru Engine Management & Tuning 69 03-24-2007 04:17 PM
U-LAME -- UTEC Log Analyzer and Map Editor WolfDrive Engine Management & Tuning 14 12-06-2005 12:01 AM
UTECA (new log analyzer software)... need beta testers WolfDrive Engine Management & Tuning 10 05-31-2005 03:42 PM
