Old 10-02-2012, 08:56 AM   #401
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
hahaha ... stage 2 is a tune and a downpipe? Nice. I knew they didnt matter much it just was irritating seeing .. Stage 2 ... Im going to be stage 2 by tomorrow. I just didnt know if there was something commonly accepted in the community as stages that people were usually following.
In every other words its stage 1 = tuned, stage 2 = very lightly modded, stage 3 is pretty much full bolt ons then.
bbarnhill is offline   Reply With Quote
Old 10-13-2012, 11:30 AM   #402
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Nice to see 1.2 is up and running, love the TQ/HP toggle option, now is easy to compare multiple runs at the crosspoint between TQ & HP.
Minor issue though, when hiding HP, the text legend hides as well, so if I want to save/print a TQ only plot I lose the text legend.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 10-13-2012, 04:47 PM   #403
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
Great catch. I just check and it happen to me too. Telling Brad right now. Thanks.
Boosted Tuning is offline   Reply With Quote
Old 10-13-2012, 07:13 PM   #404
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
yes the legend hides as it is attached to the HP curve ... hum
Old 10-14-2012, 05:49 PM   #405
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Just to report a back to back close correlation of VD vs an actual DynoJet @ TopSpeed in Atlanta.
Date: 29Sep12
Temperature: 74F (for both dyno and road runs).
Map: OTS Stage 2
HP/TQ
Virtual Dyno: 229/256
Dynojet: 228/260
Dynojet: 228/260
Old 10-14-2012, 06:27 PM   #406
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
^ Nice comparison.
Looks like the VD run could use some smoothing but great job.
Old 10-14-2012, 07:57 PM   #407
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Agreed
Edit:
on comparison. Very nice data, good work
wrxsubiemod is offline   Reply With Quote
Old 10-14-2012, 09:56 PM   #408
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
If i use smoothing then they differ no longer similar graphs.
Old 10-14-2012, 10:31 PM   #409
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
On another note, did you find the graph to be off from trying to determine you altitude, weight, temp or baro pressure?
I only ask because I'm sure many people use this and it sucks trying to guess altitude, baro, or crap in ones car if you know what I mean. Its a very good comparo
Old 10-14-2012, 10:35 PM   #410
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
Well the STD correction that your chart has is the not the best correction to use. Its inflated and out dated.
If you used SAE (the currently used correction), the numbers would be a lil lower and will probably match the correctly smoothed VD numbers. The curve should still be about the same.
Either way, it shows that VD reads very close to a real dynojet, if not right on.
Do you happen to have your dynojet run files?
Old 10-15-2012, 10:07 AM   #411
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Don't guess. Use wunderground.com to get the exact info for your Baro and temp
bswilmington is offline   Reply With Quote
Old 10-15-2012, 10:26 AM   #412
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
I downloaded an altimeter app but my local airport where they get the baro readings is lower in sea level and 10 miles away.
Its a good assumption for the most part and should get you in the ball park. Just wondering if these factors were an issue when setting up the test?
Edit: thanks for the link, just took a look at it and it shows that there's a closer weather station.
Old 10-15-2012, 11:34 AM   #413
SeeeeeYa
Member#: 129681
2017 FXT-T ES
SBM
I use an app (iPhone) that not only provides that data, it calculates Density Altitude. By adding the DA note to your logfile data you can more accurately compare numbers from different tunes on different days (more a self-tuner thing). While baro and temp are important, of course, DA is a finite number that, all things equal, will define performance potentials at any given time. I've watched my DA go to over 4000ft this summer and down to -600ft recently. Awareness of the current DA influences my logging decisions. The app is called "DragTimes" and has many more features than just the DA but DA was my main reason for getting the app.
As for filling out the boxes for each run... I have to change/fill each and every box every run as I have never been able to save a profile(?) that I can select instead. The data for my car is different than the data within VD, IOW. It's a pain but having the program with its limitations is better than not having it at all. I'm looking forward to future versions that does what this one promises... and a little better correlation between boost and torque would be good, too.
SeeeeeYa is offline   Reply With Quote
Old 10-15-2012, 11:37 AM   #414
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Originally Posted by Boosted Tuning View Post
.........Do you happen to have your dynojet run files?
Are you asking for TopSpeed dyno run files or the Cobb AP datalog road run files?
Old 10-15-2012, 01:26 PM   #415
Boosted Tuning
Member#: 286950
335i / WRX
EVO 8 RS
+1
I was asking for the dyno run files, so I (we) can see what the numbers are on SAE vs a VD chart with just a lil more smoothing.
Also, the correction used in VD is SAE.
Old 10-15-2012, 02:09 PM   #416
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
^I contacted Mark @TopSpeed for the actual DynoJet file.
However, the curve profile/shape of the Dynojet with the STD correction is the same as a previous Mustang Dyno running the same OTS Map and pretty much same mods as the latest Dynojet run, there is a 10% difference not fully attributed to difference in dynos and temps but also due to running a full Hayward & Scott 3" TBE and a CAI on DynoJet vs a free flow Panel filter and a "so called" 3" MadDad TBE which uses a 2.5" muffler on Mustang, so actually there is less than a 10% between the Mustang and DynoJet if the mods/temps have been the same.
Yes, my license plate at the Mustang dyno time was "Soccer Mom"
Mustang: 203/241
Dynojet: 228/260
Old 10-19-2012, 06:22 PM   #417
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
VD 1.2 is broken... Seems to be bugged out with Cobb datalogs. I sent a bug report, hope you got it. The logs I was trying to view, had no problems loading with 1.1.8.
Not to happy about the auto-update either. Uninstalled and putting 1.1.8 back.
*EDIT* Temporary solution:
Cobb V2 datalogs (AP-SUB-002) show time as "ṠṡTime". VD doesnt understand it. If I change it simply to "Time" my Cobb logs show correctly.
Black94Snake is offline   Reply With Quote
Old 10-19-2012, 07:19 PM   #418
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
its called a byte order mark ... those things are in files from time to time ... its encoding the text file in UTF-8 instead of ASCII. Thats not VDs fault but the settings on your computer and in the Cobb software. Those logs would not have worked with 1.1.8 either (Im pretty sure).
Old 10-19-2012, 08:31 PM   #419
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Actually, the files worked fine in 1.1.8... Sorry for trying to help fix a potential bug.
Old 10-19-2012, 09:36 PM   #420
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Thanks for the free software!
Old 10-19-2012, 09:50 PM   #421
DerekB707
Member#: 220114
07 2.5i EJ257 6MT
Rotated BW S200sx-56
Thank you.
DerekB707 is offline   Reply With Quote
Old 10-20-2012, 07:24 PM   #422
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Why be sorry ... I have a copy of 1.1.8 and am willing to try them in 1.1.8 if you like. I just know that its probably not going to work. Are you sure you didnt just reexport them in a different encoding maybe using a new version of your logging software. Im just trying to address this asap for you ... no need to think Im working against you.
Old 10-20-2012, 08:07 PM   #423
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
I haven't updated my accessport since it was installed. 1.1.8 worked fine for me after I put the AP on. I compared my newest map to my old OS overlays. Once 1.2 updated, I got labeling errors. I just figured that notifying you here would be fastest.
Old 10-21-2012, 10:16 AM   #424
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
I check this thread daily. Ill PM you my email address so you can send me the files directly.
Old 10-24-2012, 11:23 AM   #425
brian06wagon
Member#: 230392
2012 Sti sedan
heres mine 2012 sti,blouch dom 2.5,e85
brian06wagon is offline   Reply With Quote
Log analyzer - check it out jmc9809 Engine Management & Tuning 42 11-04-2007 09:00 AM
New Log-Analyzer program comming soon! NavyBlueSubaru Engine Management & Tuning 69 03-24-2007 03:17 PM
U-LAME -- UTEC Log Analyzer and Map Editor WolfDrive Engine Management & Tuning 14 12-05-2005 11:01 PM
UTECA (new log analyzer software)... need beta testers WolfDrive Engine Management & Tuning 10 05-31-2005 02:42 PM
