Old 03-21-2013, 09:11 AM   #476
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Virtual Dyno (or any "road dyno" software") cannot be used on logs from actual dyno pulls. The road dyno calculates power based on acceleration over time, and it relies completely on the correct vehicle weight. During the dyno pull the motor is simply spinning some rollers. It is not actually moving the car forward. So the fact that your dyno numbers are somewhat close only tells you that the dyno probably simulates the car's weight fairly closely, but the logs from the dyno really should not be plotted or reviewed with Virtual Dyno for power comparisons.
xluben is offline   Reply With Quote
Old 03-25-2013, 11:11 AM   #477
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Virtual Dyno also takes into account the HP lost to drag. On the dyno you eliminate these factors and will it will throw the numbers off when running those logs through Virtual Dyno.
Also you are using non-real world conditions ... these will always produce slightly different results in a pristine environment. Virtual Dyno will be close to those numbers but the curve may be slightly different from differing conditions. Virtual Dyno will give you numbers from the real world vs the ideal world.
bbarnhill is offline   Reply With Quote
Old 04-09-2013, 02:52 AM   #478
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Thanks again for the Software.
This tune was done by my buddy. I just got accesstuner and am in way over my head, but I'll learn slowly overtime.
breaksOFTEN is offline   Reply With Quote
Old 04-13-2013, 04:17 PM   #479
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
No problem breaksOFTEN ... glad its helping the community out and lowering peoples dependence on dynos.
Old 04-13-2013, 04:27 PM   #480
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
I can't wait to get my cobra back on the road, so I can see if this program works with my Binary Editor.
Black94Snake is offline   Reply With Quote
Old 04-14-2013, 09:03 AM   #481
Larimer
Member#: 205191
2006 Saab 9-2X Aero
Can't seem to download it using firefox. I'll try IE and see if that's the issue.
Larimer is offline   Reply With Quote
Old 04-14-2013, 03:58 PM   #482
SpongeBobSquarePants
Member#: 296048
2011 STI
Blurple
link to the software is broken. I would love to try this.
SpongeBobSquarePants is offline   Reply With Quote
Old 04-15-2013, 05:48 PM   #483
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
What do you mean the link to the software is broken? Its working for me right now. Im getting to the website just fine and able to install it here at work. Is there a link I dont know about? Go to www.virtualdyno.net
EDIT: The original page is no longer used. Ill try to get it to forward you to the new website for virtual dyno. It has its own domain now. http://www.virtualdyno.net
Old 04-18-2013, 10:25 AM   #484
Member#: 296048
2011 STI
Blurple
Worked now. Thanks!
Old 04-23-2013, 09:02 PM   #485
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
awesome ... that was my mistake not taking the old page with broken links down Now it just forwards you to the new page. I figured it was time to give VD its own domain (virtualdyno.net).
Old 04-24-2013, 06:43 AM   #486
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Brad, are you considering the capability of averaging runs?
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 04-24-2013, 11:26 PM   #487
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
That would be a great feature
simon021 is offline   Reply With Quote
Old 04-26-2013, 07:13 PM   #488
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Im considering it but Im trying to come up with a way to 1. make it accurate before I get flamed for that and make it usable on the user interface. I may just make a check box to include in averaging and the ones that are checked get included.
Ive really been torn on this subject as to if it would work and not hurt its reputation for being accurate.
Old 04-26-2013, 08:58 PM   #489
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Just put it in the options. And once you say yes to average then it can show up like another log file on dyno screen. That was you could even toggle it off/on without having to go back to options. If you think it will make less of the software, put a disclaimer about it.
I think it would be good thing to atleast experiment with and if it doesn't work out to be useful then scrap it later
bswilmington is offline   Reply With Quote
Old 04-26-2013, 09:12 PM   #490
simon021
Member#: 157532
2002 MY03 EJ207 E85
In my humble opinion, with proper usage it will actually INCREASE the accuracy. Take a log up the road then another log back the other direction. The average could potentially be more accurate than either run individually because of many different variables such as small bumps in the road, very slight inclinations, wind, etc.
Of course if you are taking logs on a runway with zero wind this may not apply :-P
Old 04-27-2013, 07:32 AM   #491
sub666
Member#: 38052
I would like to see an option to overlay other parameters, like timing and torque on one graph. Instead of the separate graph option. This way you can easily see where what actual timing had effect, instead of going through the raw data. I hope you find this useful.
sub666 is offline   Reply With Quote
Old 04-27-2013, 11:11 AM   #492
simon021
Member#: 157532
2002 MY03 EJ207 E85
You can just add the hp and tq numbers to the raw data pop up graph to see it overlayed. There are check boxes for the hp and tq in the raw data window if I remember right
Old 04-27-2013, 01:25 PM   #493
sub666
Member#: 38052
I mean overlayed with other runs, the same as you overlay the different power runs over each other.
Old 04-27-2013, 01:39 PM   #494
simon021
Member#: 157532
2002 MY03 EJ207 E85
Ahh ok.
Old 04-29-2013, 06:36 PM   #495
lj8915
Member#: 329252
2012 Subaru WRX
Any instructions on how to use this? Didn't see anything in the OP.
Also, what are you guys putting for the weight of your car (2012 wrx)?
lj8915 is offline   Reply With Quote
Old 04-29-2013, 06:44 PM   #496
lj8915
Member#: 329252
2012 Subaru WRX
I have a cobb AP by the way.
Old 05-01-2013, 03:07 AM   #497
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
seems easy to average runs but its not as easy as it seems when implementing it. Ive tried tackling this before ... maybe trying again will prove successful. Got another project in the works so Im having to split time between the two. Keep the faith my friends.
Old 05-22-2013, 02:36 PM   #498
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Brad, I just discovered this software and cannot describe how impressed I am by it. This is the first freeware I have used that I feel deserves a donation. It's just a little but I hope it helps. Thank you for putting all this work in and never having pop ups asking for donations, just a simple button is perfect. Please keep with it as best as you can
Respect from a fellow Kansas City engineer. If I see your Shelby around the city I'll buy you a beer
Justin
JSchell1309 is offline   Reply With Quote
Old 06-01-2013, 12:37 PM   #499
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Justin ... where do you work here in KC as an engineer? Ill meet up with ya for lunch or something sometime to talk shop if you dont care to be seen with a Mustang guy.
Old 06-21-2013, 04:08 PM   #500
SubaruWrxNewb
Member#: 236017
I have no experience with VD and I would really like to use it on my STi. Is there some sort of walk through on how to use it and what I need? I have an AcessPort and a laptop. Which programs, cables, etc... will I need? I'll also need to know how to use those programs.
Thanks.
SubaruWrxNewb is offline   Reply With Quote
Log analyzer - check it out jmc9809 Engine Management & Tuning 42 11-04-2007 10:00 AM
New Log-Analyzer program comming soon! NavyBlueSubaru Engine Management & Tuning 69 03-24-2007 04:17 PM
U-LAME -- UTEC Log Analyzer and Map Editor WolfDrive Engine Management & Tuning 14 12-06-2005 12:01 AM
UTECA (new log analyzer software)... need beta testers WolfDrive Engine Management & Tuning 10 05-31-2005 03:42 PM
