Notices
Old 09-25-2011, 09:13 PM   #151
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
1.1.3 released. Should fix the permission issues people have been having and a few other issues. I added a few small features. Hope everyone likes it, just start up Virtual Dyno and it should update itself.
bbarnhill is offline   Reply With Quote
Old 09-26-2011, 10:33 AM   #152
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Will I be able to edit gear ratios for the 02 wrx sedan with this version?
Subian is offline   Reply With Quote
Old 09-26-2011, 11:27 AM   #153
dux10
Member#: 235338
2002 Faggin Wagon
srp
Tried it with several logs and it was WAY OFF!!!!!
41hp and 34tq? And on top of that, the graph doesn't even look close to the right shape.
Uninstalled and re-installed same problem. Can I have 1.1.2 back plz???? I need it for a customers car later today....
dux10 is offline   Reply With Quote
Old 09-26-2011, 11:59 AM   #154
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
I just looked at the Time Converter code and its a problem with the way RomRaider has swapped time formats. I've handled this in the past and somehow a bug just showed up in that code. I just fixed it and will release 1.1.4 as an emergency release to fix that.
Old 09-26-2011, 12:52 PM   #155
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
I just released 1.1.4 to fix this issue. Please forgive me
Old 09-26-2011, 12:53 PM   #156
dux10
Member#: 235338
2002 Faggin Wagon
srp
Awesome! Gonna test it in 2min!
Old 09-26-2011, 12:59 PM   #157
dux10
Member#: 235338
2002 Faggin Wagon
srp
uhhh... I download and install it and it says version 1.1.3 still and the same problem keeps happening?????
Old 09-26-2011, 01:01 PM   #158
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
if it says 1.1.3 it should update itself ... might want to clear your web browsers cache before clicking download. Google Chrome was doing that to me yesterday.
I just downloaded it from the site and installed it and it was 1.1.4 and it worked fine with the different rom raider logs Ive got.
Old 09-26-2011, 01:08 PM   #159
dux10
Member#: 235338
2002 Faggin Wagon
srp
Still didn't work.
When I had 1.1.3 I opened it up after you said you released 1.1.4 expecting it to update. When it didn't automatically update I uninstalled it and downloaded it off your site. That still didn't work since it says its version 1.1.3 still. I cleared the cache its still not right....
Old 09-26-2011, 01:14 PM   #160
dux10
Member#: 235338
2002 Faggin Wagon
srp
nvm... I got 1.1.4 now. Its all better. ThanX!!!!!
Old 09-26-2011, 01:57 PM   #161
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Glad its working. Sorry about that problem. I don't know what caused that bug to just start showing up.
Old 09-26-2011, 03:06 PM   #162
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Any fix for this? Or is there a way I can edit the ratios myself?
Old 09-26-2011, 05:01 PM   #163
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
You can edit any vehicle you want by copying one of the XML files in the Cars directory (C:\users\<username>\AppData\Roaming\Virtual Dyno\Cars) to a folder in the Cars directory called Custom and modify it there. Then when the cars data is updated it wont over write anything you put in the Custom subfolder.
Old 09-27-2011, 09:14 AM   #164
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Will I have to create a new profile after doing this? How will virtual dyno know to select the custom xml over the normal one in the car folder?
Old 09-27-2011, 09:33 AM   #165
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
You can put SUBIANS CAR or whatever in the XML to distinguish your car from the others and it will show up in the car list.
Old 09-27-2011, 11:50 AM   #166
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I have a copy of the file in the customs folder and in the wrx folder, the custom folder doesn't show up on the pull down menu, and both files are nowhere to be found?
Old 10-22-2011, 06:42 PM   #167
05slprWRX
Member#: 243742
2005 WRX323whp290wtq
bremboed,meth addict.SOLD
anyone use this with the accesport logging feature? everytime i try to use it i load my log up and hit view log results and it just opens up microsoft EXCEL how to i actually graph the log on the VD
05slprWRX is offline   Reply With Quote
Old 10-23-2011, 01:06 AM   #168
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Recent and final tuning work vf22, roughly 21ish psi.
Old 10-23-2011, 11:36 AM   #169
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
Subian what is the full folder path to where you are putting the custom xml? May be in the old spot. I think Ill add an option on the menu to take you to the right place in explorer.
Old 10-24-2011, 10:03 AM   #170
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I think I got it figured out, but I had to edit the 02-5 wrx sedan XML. The "custom" XML wouldn't show up on the list. Also, can you only have 1 profile at a time?
Old 10-24-2011, 10:08 AM   #171
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
no you can have as many profiles as you want. Im going to look into the custom xmls right now and see if they work here.
Old 10-29-2011, 11:51 AM   #172
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
Subscribed as I have been using this software for a while.
rek888v2 is offline   Reply With Quote
Old 11-01-2011, 07:32 PM   #173
dux10
Member#: 235338
2002 Faggin Wagon
srp
I just updated to 1.1.5 and I'm getting the same stupid problem as before. Awkward power/torque numbers. It looks like a honda power curve..... Plz fix...
Old 11-01-2011, 11:09 PM   #174
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
That description doesnt really help me. "Honda Power curve"?
I cant tell from that if its the log or if VD has a problem.
Old 11-01-2011, 11:48 PM   #175
gray_scoob_punk
Member#: 144318
2005 Impreza RSC
CGM
I updated and now I don't have access to my custom added vehicles.
gray_scoob_punk is offline   Reply With Quote
Log analyzer - check it out jmc9809 Engine Management & Tuning 42 11-04-2007 09:00 AM
New Log-Analyzer program comming soon! NavyBlueSubaru Engine Management & Tuning 69 03-24-2007 03:17 PM
U-LAME -- UTEC Log Analyzer and Map Editor WolfDrive Engine Management & Tuning 14 12-05-2005 11:01 PM
UTECA (new log analyzer software)... need beta testers WolfDrive Engine Management & Tuning 10 05-31-2005 02:42 PM
