Old 11-02-2011, 01:42 AM   #176
gray_scoob_punk
Member#: 144318
2005 Impreza RSC
CGM
Originally Posted by gray_scoob_punk View Post
I updated and now I don't have access to my custom added vehicles.
figured it out. He moved the the Car data from the "My Programs" folder to the Virtual Dyno folder now under "AppData". C:\Users\username\AppData\Roaming\Virtual Dyno\Cars\Subaru\Impreza
gray_scoob_punk is offline   Reply With Quote
Old 11-02-2011, 03:13 AM   #177
dux10
Member#: 235338
2002 Faggin Wagon
srp
Originally Posted by dux10 View Post
Still didn't work.
When I had 1.1.3 I opened it up after you said you released 1.1.4 expecting it to update. When it didn't automatically update I uninstalled it and downloaded it off your site. That still didn't work since it says its version 1.1.3 still. I cleared the cache its still not right....
Originally Posted by bbarnhill View Post
That description doesnt really help me. "Honda Power curve"?
I cant tell from that if its the log or if VD has a problem.
the same problem i was having after the last update. i just tried it really quick with one log ajd it appeared fubar. im on my phone now but I'll try again in the morning and confirm whether its me or vd unless somebody else can verify before then.
sorry for heing vague i was super busy and irritated with homework. lol
dux10 is offline   Reply With Quote
Old 11-02-2011, 11:04 AM   #178
dux10
Member#: 235338
2002 Faggin Wagon
srp
nvm.... It was just me... Damnit i need a vacation!!
Old 11-02-2011, 12:14 PM   #179
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
What did you do?
You dont need a vacation, you need more work to stimulate your brain!!!
bbarnhill is offline   Reply With Quote
Old 11-02-2011, 01:33 PM   #180
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
Hey Brad, did you remove the functionality where you could hover over boost and afr points and it shows the data? That didnt seem to work for me when I reinstalled VD on my desktop a couple days ago.
D0nets is offline   Reply With Quote
Old 11-02-2011, 02:51 PM   #181
dux10
Member#: 235338
2002 Faggin Wagon
srp
What did you do?
Either a bad log or the wrong log. It worked fine today. lol
Old 11-02-2011, 08:25 PM   #182
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
VD worked or your brain worked? Just kidding.
Old 11-03-2011, 01:27 AM   #183
dux10
Member#: 235338
2002 Faggin Wagon
srp
VD tends to always work. My brain works for about 2hrs a day. lol
Old 11-03-2011, 04:19 AM   #184
petedotuk
Member#: 176029
Hi Brad,
Had a thought for another option..............
What about if we could enter custom set/data points?
i.e, AFR would be plotted based on the same RPM/LOAD Breakpoints that we have set on our ECU's.
That way we quickly see if a change is needed and in what cell.
petedotuk is offline   Reply With Quote
Old 11-03-2011, 06:05 AM   #185
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
pete: what do you mean custom data points? I dont understand. Maybe because its 450am and Im dead tired.
Old 11-03-2011, 09:49 AM   #186
dux10
Member#: 235338
2002 Faggin Wagon
srp
Tired? You just need more work to "stimulate your brain."
Old 11-03-2011, 10:07 AM   #187
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
Old 11-03-2011, 11:04 PM   #188
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
No I shouldnt have removed that. You have to click the show data points button.
Old 11-04-2011, 10:28 AM   #189
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
Ah I see it now. Thanks again man for all your work on VD.
[email protected]
Old 11-04-2011, 05:12 PM   #190
petedotuk
Member#: 176029
I mean that we can choose custom data points on the AFR so the AFR is plotted on the same RPM/Load sites as our ECU's.
Old 11-04-2011, 07:33 PM   #191
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
Use airboys spreadsheet for this. Also there is a new util called Acid Tune that does this. They both highlight cells in tables that are hit in a log.
Old 11-05-2011, 01:40 AM   #192
petedotuk
Member#: 176029
I use innovates log works for this feature, thought it would be a nice addition to VD!
Old 11-05-2011, 11:42 AM   #193
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
so you would need to load your tune to be able to highlight cells correct?
Old 11-05-2011, 03:00 PM   #194
petedotuk
Member#: 176029
Yes,
Basically a quick glance at the AFR plot will let us know exactly what cell in our tune requires an adjustment!
Old 11-05-2011, 11:12 PM   #195
Evo_Kid
Member#: 100218
04 AW STI
04 WW EVO 8 RS
Its called map tracing.
While it is good and fun to tune with, I dont like its accuracy. Since the maptracing uses the ROM table to display data, it only displays one number say in the 4000rpm/X.XX load cell. That one number will either be an average (most common) or the max/min number seen. Now since there is usually MANY, MANY data point between cell points ie 3600-4000rpm, and not ONE, I feel its better to look at charted data, so you can see all the data points. This way you can see little dip/bumps in afr/timing that you woudlnt see while using maptacing.
I think we need to get the graphing fixed and better, before we moving on to adding maptracing.
Evo_Kid is offline   Reply With Quote
Old 11-08-2011, 02:03 AM   #196
petedotuk
Member#: 176029
I will agree with you on the accuracy but only when in low load(which is why I always work off max) but when WOT (which is what our logs for VD are) I always have repeatable AFR's with Min/Max always within .1 of average so MAP tracing for me is worthwhile.
Maybe it is because I use a MAP based ECU and I always make sure my load matches my target boost.
Old 11-08-2011, 08:05 AM   #197
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
adding map specific features is sort of hard since I have to support so many different platforms. I would need to figure a way to add this feature for not just subarus but also GM, Mitsubishi, etc.
Old 11-11-2011, 04:23 AM   #198
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
bbarnhill, Thanks for your hard work and dedication, I truely enjoy your product!
punchjamesarnol is offline   Reply With Quote
Old 11-11-2011, 06:49 AM   #199
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
I can completely understand that, but one option would be to allow pasting of tables into the program, rather than having the program automatically break down the .hex. However there are already a few tools that do this. IMO it would be a bit of "scope creep".
Ive mentioned this to you in the past, but it would be cool to at least be able to add other parameters to the bottom graph (total timing, IDC, target boost, etc...)
Old 11-11-2011, 07:46 AM   #200
bbarnhill
Member#: 256281
2007 Shelby GT 500
Grey
i agree that the map tracing is a bit of feature creep.
The ability of adding other parameters to graph to the bottom graph is being worked on already. There is already another screen with a list of all the other PIDs listed and it graphs. I just havent decided if its a 'pro' version feature or not.
Log analyzer - check it out jmc9809 Engine Management & Tuning 42 11-04-2007 09:00 AM
New Log-Analyzer program comming soon! NavyBlueSubaru Engine Management & Tuning 69 03-24-2007 03:17 PM
U-LAME -- UTEC Log Analyzer and Map Editor WolfDrive Engine Management & Tuning 14 12-05-2005 11:01 PM
UTECA (new log analyzer software)... need beta testers WolfDrive Engine Management & Tuning 10 05-31-2005 02:42 PM
