Old 03-29-2011, 09:33 AM   #1
snookey318
Member#: 278129
2011 WRX
Default 2011 WRX shifting question
Hi Everyone
I picked up my new dark metallic grey WRX last week and i am really impressed with the handling and solid feel of the car. I have already hit the magical 1000 mile mark and have a newbie question about shifting. Is it detrimental to the cars "glass tranny" if i quickly release the clutch after shifting to second gear and then give it full throttle? If i do this you can feel the car jerk - Basically i am trying to determine if dropping the clutch quickly (not 1st gear and not shifting fast) and rowing thru the gears can hurt this transmission? Obviously it only does this when i am seeing what the car can do but i wanted to be cautious after reading a few transmission threads.
I drove this way in my 2006 Ralliart with no issues but the fast engagement of the clutch while moving in the WRX seems a little more harsh.
Please let me know your thoughts.
Thanks!
snookey318 is offline   Reply With Quote
Old 03-29-2011, 09:38 AM   #2
chapstien
Member#: 68284
1988 Corolla SR5
0-points
Yeah that's not good for any car, and there's no real benefit.
chapstien is offline   Reply With Quote
Old 03-29-2011, 10:19 AM   #3
Subsoniq
Member#: 274969
2011 Impreza WRX
WR Blue Mica
I dont get it? You cant shift hard in these cars? How do you autox if you have to baby the clutch? I havent autox yet, but in my challenger i've dragged, and i pop the clutch out shifting every gear?
Subsoniq is offline   Reply With Quote
Old 03-29-2011, 10:24 AM   #4
snookey318
Member#: 278129
2011 WRX
If i didn't release the clutch quickly and then get on the gas i would have to slip the clutch if i wanted fast times - that seems like unnecessary wear no? Remember i am talking about shifting into second gear and higher. I understand releasing clutch quickly in first is a bad thing with any car, especially AWD
Again sorry for the newb comments. I am trying to determine the best way to drive this car fast without hurting any of the components.
Old 03-29-2011, 10:38 AM   #5
Ferno
Member#: 250218
2002 Impreza WRX
World Rally Blue
The car doesn't have a 'glass tranny', if you're shifting at high RPM then yes it will jerk a bit but that's how it is with any car I've ever driven. Obviously this isn't "good" for the transmission, but who in the hell babies their car 100% of the time? Not me.
Ferno is offline   Reply With Quote
Old 03-29-2011, 11:31 AM   #6
chapstien
Member#: 68284
1988 Corolla SR5
0-points
If you're making the car jerk, you're not being smooth, and could induce over steer. There is a fine line between jumping it and engaging it smoothly without slipping.
Old 03-29-2011, 12:36 PM   #7
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
This. There's about a 1,000 RPM difference between 1st and 2nd at any given speed. Sounds like you're rushing it a bit too much.
As far as auto x goes, you should only have 1 gear change from 1st to 2nd, then 2nd or 3rd for the rest of the track.
jonklein611 is offline   Reply With Quote
Old 03-29-2011, 12:40 PM   #8
muede
Member#: 263856
2011 WRX
I have a 2011 WRX sedan, and occasionally do the same thing. I kind of assumed it's bad for the trans, but I paid for extended warranty so why not haha.
muede is offline   Reply With Quote
Old 03-29-2011, 12:44 PM   #9
snookey318
Member#: 278129
2011 WRX
Just to be clear- I am talking about doing a 5-60 run with full throttle. Seeing what the new car can do. If i am driving normal i can shift very smooth. The question is whether popping the clutch quickly after shifting to 2nd (or 3rd...) is going to wear my gear set or car out sooner.
I wouldnt think so but being cautious
Thank you for everyone's input
Cheers
Old 03-29-2011, 01:02 PM   #10
Maudlin
Member#: 206124
2011 WRX 4-door
Satin Pearl White
Cheers
You can shift fast without the bucking. You may need to release the clutch quicker or slower depending on which way u r doing it incorrectly. But it should feel like a smooth transition no matter what speed or rpm.
Maudlin is offline   Reply With Quote
Old 03-29-2011, 01:04 PM   #11
jonklein611
Member#: 117776
WR Blue Pearl
Cheers
Popping the clutch (assuming your foot is completely off the gas) will do no harm, and assuming you're slotting the gear in and dropping the clutch at the perfect point shouldn't do major harm to the car. The jerkyness is telling me you don't quite have it down yet.
Old 03-29-2011, 02:20 PM   #12
snookey318
Member#: 278129
2011 WRX
I guess the jerkiness i am describing when going all out thru the gears is the clutch being released and making hard contact with the flywheel? Its not so much the car rocking back and forth but more then clutch mass engaging quickly on the fly.
Like I mentioned earlier, my older ralliart could do this all day with no ill effects but the WRX seems to be a little more violent. Worried it might take a gear after awhile.....
Much appreciated
Old 03-29-2011, 03:37 PM   #13
Rablo88
Member#: 267513
2011 Impreza WRX
Spark Silver Metallic
Challenger is a RWD car lol meant for that, you cant just pop the clutch on an awd and expect it to burn out like a 400hp rwd car.
Rablo88 is offline   Reply With Quote
Old 03-29-2011, 04:41 PM   #14
everdying55
Member#: 112651
2011 Corn Fed WRX
DGM Hatch
This.
It seems to me that you don't quite have the timing down on your new car. I bought my 2011 WRX in Febuary and eventhough I have driven manual before, I had to get used to the car. Every new car has a learning curve, whether it's your 1st manual car of 5th.
everdying55 is offline   Reply With Quote
Old 02-15-2012, 08:53 PM   #15
ScoobTube5210
Member#: 310417
2011 Impreza WRX
Satin White Pearl 5-door
Hi Everyone
Thanks!
I think i know what you mean. When shifting the rpms seem to "hang" for a split second after putting the clutch in, and then they drop very slowly. I have to wait almost a second to smoothly engage the clutch from 1st to 2nd. Ive read that it is the drive by wire holding the throttle slightly open to allow for any extra fuel (im assuming in the injection ports) to burn for better emissions. it is absolutely not me keeping my foot on the gas when putting the clutch in. anyways its super annoying and makes trying to accelerate quickly but not WOT (shifting between 3500 and 5000) very slow and difficult to pull off smoothly. Ive heard that the Cobb AP eliminates this but i dont know if it is confirmed. I really want to get one to see if it fixes that issue...plus some more power wouldnt hurt
ScoobTube5210 is offline   Reply With Quote
Old 02-15-2012, 09:03 PM   #16
curiousfish
Member#: 89283
2008 WRX Premium
SSM
^^^ a Cobb tune, or any protune would make the driving experience a bit more like cable throttle.... but when getting off throttle to shift between gears, the older cars still have the RPM's drop faster. (that's my comparison between 2010 STi, 2008 WRX, 2005 WRX, 2002 WRX).
I know thread is old, but if ppl are dropping the clutch between gears, there is a lot of transmission shock, and the drive shaft is probably hitting the rear diff. Please read transmission faq and educate yourself on why Subaru's cant be shifted like Honda's or Toyota's.
curiousfish is offline   Reply With Quote
shifting issue with 2011 wrx loudninja Newbies & FAQs 27 08-11-2012 11:21 PM
2011 WRX Bluetooth questions cwapface Car Audio, Video & Security 5 12-09-2011 12:02 PM
2011 WRX Intake Question 2011_Black_WRX General Community 94 07-15-2011 10:05 PM
Question about adding 2011 STI spoiler to 2011 WRX l337person Interior & Exterior Modification 13 03-14-2011 01:58 PM
2011 WRX Stereo Questions TheRedWRX Car Audio, Video & Security 4 03-13-2011 05:22 PM
