Welcome to the North American Subaru Impreza Owners Club Thursday July 31, 2014
Old 03-29-2011, 10:27 AM   #1
vicious_fishes
Member#: 158864
2003 GD w/EZ30D swap
Default what oil are you guys running in your 5 speeds?
about to make the move to straight cut gears. should i stick with my motul gear 300?
vicious_fishes is offline   Reply With Quote
Old 03-29-2011, 12:19 PM   #2
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Gear 300 should be fine, makes my short list for racing gearbox oils.
1. Motul Gear 300 75w-90
2. AMSOIL Severe Gear 75w-90
3. SOA Go EXTRA-S 75w-90 (light duty/autocross)
JamesWilson2 is offline   Reply With Quote
Old 03-29-2011, 04:09 PM   #3
Back Road Runner
Member#: 60082
2004 Forester STI
You can't really go wrong with #1 or #2. #3 is a petroleum based oil, so the folks living in colder climates who see sub-freezing temperatures may opt to shy away from it for winter use or at least expect poor shifting and double clutching till some heat gets into it. Above a certain viscosity, these trannies stop shifting work crap.
If you're serious about driving, an option would be a higher capacity rear diff cover.
http://www.perrinperformance.com/pro...ry=68&model=33
Heat is the main cause of oil break down, and with the low capacity of the rear diff, it is the first to ramp up in heat. I will say it takes a LOT to get to a bad state in the first place, but I'm just tossing the idea out there.
Any particular reason for the straight cut gears versus sticking to helical?
Old 03-29-2011, 09:31 PM   #4
AZP Installs
Member#: 40160
Having been road racing subies since the 90s, we've found the Amsoil 80w90 to be great gear/diff fluid for the 5MTs. On the 02-03 WRX the Extra S will help get rid of some of the problems associated with them but running straight gears you won't have those issues.
I would go with the Amsoil or the Motul, both great choices.
-mike
AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | T-1 Certified Amsoil Dealer
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 03-29-2011, 10:16 PM   #5
wrxlad
Member#: 103317
Swepco 201...not cheap but definitely race proven.
wrxlad is offline   Reply With Quote
Old 03-29-2011, 10:44 PM   #6
bhhamblin
n00b Moderator
Member#: 99397
13 STI, 83 DR30
93 R32 GTS-T, 93 R32 GTR
Which brand straight cuts.
Andrewtech recommends to use straight Redline lightweight shockproof if you are using PPG. That is what I run.
bhhamblin is offline   Reply With Quote
Old 03-29-2011, 11:31 PM   #7
okiedude
Member#: 37736
2003 WRX Race Wagon
This has worked great for me in two different stock 03 five speeds and an RA close ratio box since 2004. That is over aprox. 7500 track miles and not a single problem, except freshening a couple of syncros. HP range has been 275 to 340 WHP.
Plus it's Smurf Blue!
okiedude is offline   Reply With Quote
Old 03-30-2011, 12:31 AM   #8
bhhamblin
n00b Moderator
Member#: 99397
13 STI, 83 DR30
Ive been using it in my PPG box for road racing making ~520whp. I change it every 2 outings.
Old 03-30-2011, 06:39 AM   #9
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
lw shockproof for me also. ran it in my stock 02 gearbox and had no issues. changed to ra gears for better ratios and still run it with no issues. for ppg, i would do what andrewtech recommends
rjrutzky is offline   Reply With Quote
Old 03-30-2011, 07:24 AM   #10
vicious_fishes
Member#: 158864
-mike
PPG straight cuts. simply because i scored a 'box with the car nice & cheap
consensus seems to be motul 300 or redline LW shockproof from what i can tell.
Old 03-30-2011, 07:43 AM   #11
Jard
In the silly seat
Member#: 34935
SPB- 2013 Smugmobile
and DADCORE
I really did not like Motul 300 in my RallyCross car. Shifting was notchy with occasional grinds.
Switched to LW Shockproof and that went away.
Jard is online now   Reply With Quote
Old 03-30-2011, 12:51 PM   #12
rallynutdon
Member#: 24568
1993 Impreza, WRX
drive train, Open class
How frequently do you guys change your trans oil?
rallynutdon is offline   Reply With Quote
Old 03-30-2011, 02:00 PM   #13
RB5 Clone
Member#: 30909
RA East Open Class
Champs 07-08-09
on the Open Cass car, we do teh trans oil every 2 or 3 events
on the RS race car it was more like 2x per season due to lower trans stresses
RB5 Clone is offline   Reply With Quote
Old 03-30-2011, 05:04 PM   #14
vicious_fishes
Member#: 158864
fair enough. reckon i'll try it out & see how i like it.
thanks guys.
Old 03-30-2011, 07:07 PM   #15
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
2x per season for me, rear diff 1x per season.
Old 03-30-2011, 08:23 PM   #16
garageGT
Member#: 80524
We run Neo 75w90HD since 2007 on the straight cut dogbox, and its been happy so far..
garageGT is offline   Reply With Quote
Old 03-30-2011, 10:50 PM   #17
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Been running Shockproof SLW in my RS since 2001 with many track days and countless autocrosses. Car has 280K on it now.
Patrick L is offline   Reply With Quote
Old 03-31-2011, 11:59 AM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Straight cut or helical is totally irrelevant when it comes to gear oil. What does matter though is synchronized or dog engagement. If it's synchronized, use Mobil 1 Delvac. If it's dog bog, it's still a great oil, though the Redline would be a good choice as well. I do NOT like Redline in synchronized gearboxes on racecars.
Old 03-31-2011, 01:47 PM   #19
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
my 5-speeds loved redline shockproof...I'd run heavy in the summer time.
Old 03-31-2011, 07:40 PM   #20
2005wrxowner
Member#: 217455
2005 wrx
blue wrc
Default gears
hypoy C gear oil. castrol i think...
2005wrxowner is offline   Reply With Quote
Old 03-31-2011, 09:11 PM   #21
skimobile
Member#: 92114
03 WRX (Neon Blue)
in"Special Ed." Run Group
I use 1 part Motul Gear 300 and the balance of fill up with Redline LW Shockproof.
skimobile is offline   Reply With Quote
Old 03-31-2011, 09:14 PM   #22
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
In my DD RL LW shockproof, in the rallycar RL 75/90NS. They don't like it the other way around.
Rally car gets gear oil swapped every 3 events (that includes a practice day)
REDrum is offline   Reply With Quote
What program are you guys running to log your cars? breathinez AccessPort 22 08-09-2006 09:57 AM
cobb stage 2 sti's what are you guys running in the 1/4 mpower22 Engine Management & Tuning 8 08-10-2004 02:29 AM
what tires are you guys running here in vancouver?? superhero Vancouver Impreza Club Forum -- VIC 35 05-29-2003 02:31 PM
What struts are you guys running on your springs? ImPrEzZzZZA Brakes, Steering & Suspension 8 07-14-2002 11:40 AM
For those with 17" rims, what tires are you guys running in snows? malelee21 Brakes, Steering & Suspension 15 10-24-2001 06:33 PM
