Old 03-29-2011, 11:44 PM   #1
2Tone04
Member#: 262842
2004 WRX Impreza
Blue/Black
News Propane conversion kit
Has anyone attempted/completed a propane conversion kit on a WRX/STI? I am looking for specific data on pro's/con's....Can anyone help??
2Tone04 is offline   Reply With Quote
Old 03-30-2011, 12:08 AM   #2
infinite012
Member#: 74392
2015 Forester
What?
infinite012 is offline   Reply With Quote
Old 03-30-2011, 12:13 AM   #3
trollarc
Member#: 255667
2004 Impreza Wrx STI
I dont think you can use regular injectors for propane because it is a gas. I dont think the injectors seal well enough. So if you were going to do that, you'd probably have to setup a pressure regulator system and individual nozzles instead of injectors. IMO such a conversion would be impractical (they do it on some ford trucks though so it is possible that I am wrong).
trollarc is offline   Reply With Quote
Old 03-30-2011, 12:19 AM   #4
farside
Member#: 49323
2000 Outback Sport
two tone is hot
There was a company that would convert any car to propane use and have it certified. I'd see them post on Honda-tech once in awhile. Might try searching there.
farside is offline   Reply With Quote
Old 03-30-2011, 12:25 AM   #5
Mikebravo
Member#: 275630
2016 WRX
Spark Silver
I doubt they would do it on a turbo car
Mikebravo is offline   Reply With Quote
Old 03-30-2011, 12:28 AM   #6
SupDooD
Member#: 180410
This can't be real lol
SupDooD is offline   Reply With Quote
Old 03-30-2011, 12:30 AM   #7
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Do this with an older car. Why would you do this with an STi?
They're already being slain by 16 year olds, we don't need you to be Dr. Josef Mengele and do funky experiments.
Smoke is offline   Reply With Quote
Old 03-30-2011, 12:33 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I would think that tuning would be an interesting process.....
Old 03-30-2011, 12:57 AM   #9
The Duke
Member#: 264877
This **** ain't no diesel son.
The Duke is offline   Reply With Quote
Old 03-30-2011, 01:37 AM   #10
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
ibHankHill
XanRules is offline   Reply With Quote
Old 03-30-2011, 02:58 AM   #11
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Get a Volkswagen Jetta Diesel and add a Vegetable Oil kit. I have been told you can buy pre prepared vegetable oil for like $1.25 to fill a moderate size tank.
Propane is kinda $$ and this would be a full conversion vs the fryer oil kit that aids to your fuel system.
But if you really are all gun ho on doing the Propane, I would NOT do it on a WRX/STi. Turbocharge, sensitive to tune....vs a Honda
subaru_steve is offline   Reply With Quote
Old 03-30-2011, 03:20 AM   #12
Seventh
Member#: 263223
2011 WRX 5dr
SWP, 332ti
The vegetable oil conversions are overrated IMO. I've installed several Elsbett veg oil conversion kits on VW's, two tanks is the preferred method, one for veg, one for diesel with a big switching valve plumbed in between the two tanks and supply/return lines to the engine, so you can warm the car up on diesel then change to veg oil on the fly via dash mounted switch. The veg oil needs to be preheated quite a bit before the engine likes to run on it, BIG heating elements and filter assemblies are required. And unless you have some kind of "connection," the average person pays more per gallon for veg oil vs. diesel.
IIRC Dr. Chaos has been experimenting with a liquid propane setup for his 2.2l Bimmaru, you could try contacting him.
http://forums.nasioc.com/forums/show...ght=bmw+subaru
Seventh is offline   Reply With Quote
Old 03-30-2011, 03:53 AM   #13
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
OK, I'll bite...
I'm guessing you're asking about this for ecological and/or economical mpg reasons but could there possible be and power gained from fueling on propane?
From a practical standpoint though I imagine getting this to work would be a nightmare, you'd first have fine some way to get the propane into the engine as fuel injector are designed for liquid not gas, and then to tune the car to run safely, I can't imagine there are many tuners out there with experience with tuning for propane fuel.
OUScooby is offline   Reply With Quote
Old 03-30-2011, 07:28 AM   #14
Dzhedaj
Member#: 244552
MY05 Impreza WRX
WR Blue
We have a lot of propane/buthane converted cars, including Subaru (and turbo).
You basically have a gas tank in your boot, e.g. instead of your spare wheel.
Then you have injectors drilled into your intake manifold.
The whole system hooks up to your ECU and does not need any modifications.
Latest LPG systems also inject compressed gas directly into the cylinder, so as it expands it cools the air (you all know what that means).
Generally mileage and power loss is considered to be around 5%.
There are quite a few manufacturers of such equipment in Europe, like Lovato, Landirenzo (both Italian).
Benefits? First it's cheap. When 1 liter (1/4 galon) of gasoline costs almost $2 and LPG costs less than $1.
Second - it's ecological, LPG is a byproduct of gasoline production and burns much much cleaner.
Third - LPG has an octane rating of ~100, so with proper adjustment you could run more boost.
The downsides - LPG burns "dry" and has impact on valves in Subaru. That is not the case in most other cars, they run >200k miles on LPG just perfectly.
Dzhedaj is offline   Reply With Quote
Old 03-30-2011, 12:18 PM   #15
abgusaf
Member#: 143122
07 WRB STi
in the werks
Just curious, but what does this have anything to do with interior & exterior modification?
abgusaf is offline   Reply With Quote
Old 03-30-2011, 01:03 PM   #16
mneste8718
Member#: 51562
2004 WRX Sedan PSM
EJ205 [email protected] 300whp
too bad LPG isn't really available in the states or I would have switched a long time ago...
makes me wonder why it isn't. Doesn't the US have plenty of natural gas on US soil? Instead we get the peanut factory, "dis ain't no diesel son"
Ignoring the fact that a good percentage of cars in Europe and Canada run on LPG. I think Ohio has started to have it more available too.
mneste8718 is offline   Reply With Quote
Old 03-30-2011, 10:28 PM   #17
D3F0
Member#: 265799
1988 Subaru RX TURBO
This reminds me of what I am thinking of I like the idea of HHO injection for more MPG check out my thready on it the gas goes right into the intake from a fuel cell and after a couple miner adjustments with Oxygen sensors and stuff like that big gains are possible. One Subaru guy on the forum I have in my thread got six more miles to the gallon and more power.
D3F0 is offline   Reply With Quote
Old 03-30-2011, 10:38 PM   #18
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
LPG is available at alot of places but not dispensed readily for automotive use but for heating.
Propane injection used to be somewhat of a popular as a power adder in the early 90s in the 3000gt TT crowd. There are some writeups and reviews on 3si.org. The scene has died out since there are safer ways to introduce more octane into your fueling ,than have a tank of high pressure flamable gas in the car.
fastnoypi is offline   Reply With Quote
Old 03-31-2011, 12:36 AM   #19
infinite012
Member#: 74392
2015 Forester
OH! LPG! Ok, yeah that's where I thought this thread was headed.
I have nothing to add. Just wanted to make a snarky remark.
Old 03-31-2011, 12:55 AM   #20
iommichild
Member#: 194990
2008 OBS
Steel Silver/Spark Silver
When i was in peru, almost everybody ran LPG in their cars. there were conversion places all over the place. Peru is a pretty much dirt poor country, so if they can do it, I'm sure you can get it done.
iommichild is offline   Reply With Quote
Old 03-31-2011, 01:04 AM   #21
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
There are also more turbo diesels out there, might want to consider that, but where do you reliably buy propane and/or diesel these days!?
JavaBot is offline   Reply With Quote
Old 03-31-2011, 08:22 AM   #22
Dzhedaj
Member#: 244552
MY05 Impreza WRX
WR Blue
Don't mix up natural gas and propane/buthane.
First is even cleaner to burn, but has to be stored in a compressed in very very high pressure.
LPG is not excavated, it's a byproduct of fuel production from oil. It is stored in a liquid form in relatively low pressure.
Driving with a tank high pressure gas? Aren't you afraid to drive with a tank of low pressure gas highly flammable gas (fuel vapor that is)?
Old 03-31-2011, 08:35 AM   #23
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Indeed.
Old 03-31-2011, 10:28 AM   #24
mneste8718
Member#: 51562
2004 WRX Sedan PSM
yea I worked out an HHO cell and it got me 39MPG on the hwy once heh. I still need to figure out a better casing for it. Also, you might want to watch out on using sodium or potassium hydroxide because it will eat aluminum over time, even if it is just in the vapors with the HHO.
Old 03-31-2011, 10:34 AM   #25
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Sweet... the Outback would have integrated twin Coleman burners in the engine bay for camping and picnic weekends
iBrite HID Conversion Kits - 10% OFF ANY HID KIT - Sonic Motor April Sale Sonic Motor Exterior/Styling 12 04-30-2010 08:58 PM
HID Conversion kit ckc Interior & Exterior Modification 10 10-03-2001 09:09 AM
FS: Read drum to disc conversion kit... subaruwrx Southern California Impreza Club Forum -- SCIC 1 02-05-2001 10:28 PM
fs: blue light conversion kit for dash and heater controls bttune2.5rs New England Impreza Club Forum -- NESIC 8 01-26-2001 08:09 AM
Best price on headlight conversion kit? scootr Interior & Exterior Modification 2 11-08-2000 07:24 AM
