Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 03-30-2011, 01:25 PM   #1
silverongold
Member#: 132599
02 impreza wrx
Default fuel pressure regulator test?
does any one know an easy way to test a fuel pressure regulator to see if it is bad?
silverongold is offline   Reply With Quote
Old 03-30-2011, 01:38 PM   #2
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Put on another known working one.
car_cursed is online now   Reply With Quote
Old 03-30-2011, 01:40 PM   #3
silverongold
Member#: 132599
02 impreza wrx
does any one around have one from a 2002 wrx that they would be willing to let me try?
Old 07-10-2011, 02:37 PM   #4
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Bad answer.
Put fuel pressure gauge on the car and check base pressure, should be around 35-38psi, then unplug vaccum hose going to the regulator and pressure should rise to 43psi. If its adjustable then someone may have set base pressure higher. If these are correct, but you still think there is problem then put gauge where you can read it going down the road and the regulator should add 1 pound fuel pressure to 1 pound of boost over fuel pressure with the regulator unpluged.
So if you have unpluged pressure of 43psi and you run 20psi of boost, then at peak boost you should have 63 psi of fuel pressure.
bswilmington is offline   Reply With Quote
Old 07-10-2011, 04:39 PM   #5
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Yeah double post Sunday.
Old 07-10-2011, 04:40 PM   #6
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
The ****? Why bump a 4 month old thread?
Old 07-10-2011, 07:24 PM   #7
bswilmington
Member#: 217563
In case someone is searching on how to test a FPR.
I posted the real way to test it instead of "install a new one" or in case the guy needs to know in the future. Is that a good enough reason?
Old 07-18-2011, 07:35 AM   #8
Buurma
Member#: 258394
2001 GC8
Pear black
good enough for me.
i thought the pressure at idle was 42 psi? but anyway my fuel trims are super high and the car runs very lean. so something is bad for sure.
Buurma is offline   Reply With Quote
Old 07-18-2011, 09:05 AM   #9
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
Originally Posted by Buurma View Post
good enough for me.
If I remember correctly, my car idles at 38 PSI with a stock unadjusted/unmolested FPR.
axelthrasher is offline   Reply With Quote
Old 07-18-2011, 12:22 PM   #10
Buurma
Member#: 258394
2001 GC8
Pear black
sweet i'm trying to diagnose a tired fuel pump over a bad fuel pressure regulator.
new fuel filter. lean under boosht. super high fuel trims. like +15 for short and long term
new o2 also. chassis has 180k on it.
Fuel pressure regulator - how to test ? goixiz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-29-2010 03:55 PM
BDL fuel rails and fuel pressure regulator living4surf Engine/Power/Exhaust 2 09-29-2007 09:38 AM
Fuel Pressure Regulator testing Scooby_Rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-06-2007 01:05 PM
Fuel Pressure Regulator and/or Fuel Rails? mav1c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-19-2003 03:23 PM
SVX Fuel Pressure Regulator Solved Idle Pressure Problem the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 23 11-05-2001 09:20 PM
