Old 07-17-2002, 02:20 AM   #1
Mako
Member#: 5770
2000 Legacy Outback
Green with Stromung & CAI
Lightbulb Idea for cheap power upgrade!
Has anyone looked into if the exhaust for an H6 Outback will fit into the hangers of a regular OB?
I was at a dealership today checking out exhausts on OBs on the lot, since I have a two-outlet Stromung and want to put a hitch on. It won't clear the dual tips. Well, I was checking out an H6 single tip exhaust and that thing is burly. It is DEFINITELY bigger tubing than a regular OB...probably at least 2.5" and maybe bigger? At least as big as the 2.5" piping on my Stromung. It appears that it will bolt up in place, even with that funky add-on welded to the side of the canister.
Anyone tried this? If it works, I bet it would give a nice power increase for relatively cheap, compared to a Stromung for example.
Any thoughts? Part number?
Mako
Mako is offline   Reply With Quote
Old 07-17-2002, 08:51 AM   #2
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
I bet you are going to pay alot unless you can find a wrecked H6. You would be better of having one custom made to match.
Price for OEM 95-99 2.5 exhaust
Header-$179.30
CC-w/o Calif. emissions-$515.98, w/Calif. emissions-$559.48
Center Pipe-$246.23
Muffler-$219.00
Total- w/o Calif. emissions-$1,160.51
w/Calif. emissions-$1,204.01
No telling how much they want for the H6 stuff.
HIHO is offline   Reply With Quote
Old 07-17-2002, 10:26 AM   #3
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
I can see it hurting performance, actually. From what I've read, the H6 engines use a variable flow muffler which decreases backpressure by use of a valve in the muffler. If it's mechanically actuated, then it opens by means of exhaust pressure. A 2.5L engine (or 2.2L or whatever) will put out less exhaust gas for a given rpm which might destroy any gains made by the system on the 3.0L engine (I'm not sure of this).
If the exhaust is activated by the ecu, you'll DEFINITELY have problems
Jason
2.5GT is offline   Reply With Quote
Old 07-18-2002, 04:43 AM   #4
Velocity
Member#: 2205
1998 Legacy L Wagon
Deep Sapphire Blue
Like it was pointed out, more often than not, an exhaust upgrade won't do jack if you don't have to ability to push a large amount of air thru it in the first place.
Velocity is offline   Reply With Quote
Ideas for more power with same turbo, engine scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-06-2005 12:01 AM
Idea for low cost upgrade - what do you think? Mr Ludecrs Car Audio, Video & Security 1 04-09-2004 03:25 PM
Ideas for Cheap, Dirt, with snow capability, back up set of tires? Kostamojen Brakes, Steering & Suspension 28 03-13-2003 03:57 PM
Old idea for cheap exhaust. DiscoStu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 02-11-2003 08:52 PM
Any ideas for more power? Subleg4 General Community 1 11-16-2002 01:01 PM
