Old 07-17-2002, 07:16 AM   #1
Bimmerman
Member#: 7932
2002 WRX Wagon
2000 BMW 323i
Question Need advice on 16" vs 17" wheels and tire width...
After taking the wagon to the track a couple weeks ago I realized that I need some new rubber. I plan to get Bridgestone S-03's, but I'm not sure if I should get 16" or 17" wheels. I always thought that 17s would provide better handling, but I have noticed that some people on the board have been buying 16s for racing and track days. Are 16s better for the track? Also, I've noticed that some people have had their 225 width tires rub when using wheels with a 48 offset on the wagons; if you have an offset of 50-53 could you use 225 tires without any danger of rubbing?
Thanks
Bimmerman is offline   Reply With Quote
Old 07-17-2002, 10:50 AM   #2
boxerT
Member#: 16311
2004 STi
WR Blue
The reasons why many people buy 16" wheels for auto-x or track days are many. They usually are:
1. Rims are cheaper and they are often the 2nd set of wheels/tires
2. 16" tires street or race are usually cheaper to replace.
3. There are more 16" race and street tires that would fit a WRX. Some examples are: 205/50/16, 215/45/16, 225/50/16, 245/45/16 (probably sedan only).
The problem: 16" wheel choices are much more limited than the 17" or 18". Hope this helps.
boxerT is offline   Reply With Quote
Old 07-17-2002, 11:44 AM   #3
scott_gunn
Member#: 4203
2009 WRX 5spd hatch
Platinum Silver Metallic
Another reason many are autocrossing with 16s is that 17 inch wheels would exclude people from racing in the stock class.
scott_gunn is offline   Reply With Quote
Old 07-18-2002, 06:10 PM   #4
Bimmerman
Member#: 7932
2002 WRX Wagon
2000 BMW 323i
Thanks for the replies. So people are basically trading off a little grip at the track for cheaper tires and wheels - 16 inch wheels aren't necessarily better? 17 inch wheels will typically improve the handling of the car, right?
Old 07-18-2002, 06:21 PM   #5
rkkwan
Member#: 5596
2010 Honda Fit Sport
I just picked up a set of '98 OEM 16" wheels, and am planning to put R-compounds on. Will take these to the track rather than my 18" S-03s.
Why 16"? To me - cost of tires, and weight of combo. Handling? Most R-compounds or race tires have very stiff sidewalls, even at 16". The improvement in handling and steering feel with 17" or 18" over 16" won't be as dramatic as with street tires.
-Ray
rkkwan is offline   Reply With Quote
Old 07-18-2002, 06:36 PM   #6
98kPa
Member#: 17379
Just an fyi... I run 235/45 on 17x8 and it rubs a bit on hard rights, soemtimes.
jason
98kPa is offline   Reply With Quote
Old 07-18-2002, 11:55 PM   #7
Miracle Worker
Member#: 1390
2000 2.5 RS Sedona
Red (Chicken Katcher)
lets not forget that the width isn't that much of a difference between them. maybe a fraction of a inch.
Miracle Worker is offline   Reply With Quote
Old 07-19-2002, 06:02 AM   #8
oldmansan
Member#: 17877
Midnight Pearl
Default Let's talk about weight.
A 16" wheel will be lighter. Typically, the tire will be too. So if you're interested in saving weight (especially rotational weight) go with the 16s. You can get 16 x 8/7.5/7 wheels that are real light (SSR Competitions come to my mind) and still give you a large contact patch. I will be the first to admit that 17, 18s or 19s LOOK better. But what are you after?
San
oldmansan is offline   Reply With Quote
Old 07-19-2002, 12:37 PM   #9
Chuck H
Member#: 20442
Typically, the car will corner better with 17 inch wheels, but you'll give up a slight amount of straight line acceleration and add a slight amount of braking distance because of the increased rotational inertia of the bigger wheels. In most cases, the cornering improvement outweights the negative factors.
But the other consideration is that going to 17 inch wheels will move you from a stock class to street touring at the very least.
Chuck H is offline   Reply With Quote
16" vs 17" for snow tires elgineddie Tire & Wheel 6 10-30-2008 02:22 PM
Pa: WTT Stock 16" wheels & Tires + Cash for 17" wheels and tires WRXPCT04 Private 'Wanted' Classifieds 0 04-26-2007 10:48 AM
16" vs 17" wheels and ride comfort edssooby Tire & Wheel 8 01-19-2005 11:19 AM
Great Deal on a light 17" Wheel and Tire B-Rex Interior & Exterior Modification 1 08-01-2004 10:54 PM
16" vs 17" wheels? gnildronde Brakes, Steering & Suspension 7 05-21-2002 11:58 PM
