Old 07-17-2002, 09:26 AM   #1
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
Default Opinion pleeezzee? Mr Exhaust Sys. or Custom Cat Back ?
Ok here's my dilema. I am torn between getting a full mrt exhaust system or custom SS cat back with a titanium muffler. The cat back would be 2.5" in diameter as opposed to the 2.25" , am not sure how this affects performance you may chime in on this too. It would also be cheaper right now (Money is an object need other parts you know ). I do have future plas to Supercharge the car hopefully early-mid next year whenever templar's SC is done.
Any $.02 ???? am beggining to develop a migraine over this !
Mr. Rogers is offline   Reply With Quote
Old 07-17-2002, 10:44 AM   #2
Section 8
Member#: 821
If you plan to supercharge, don't get the MRT. It is very good for a stock cammed NA car, but even with spicy cams it appears not to be the best solution due to the 2.25" pipe diameter. A supercharger will only be worse.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 07-17-2002, 12:26 PM   #3
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
so it would be better to do the 2.5" catback then. How would that affect performance until I can get an SC ? I have hard many different tales of the tape regarding how you'll lose more TQ and so forth ? any truth to this ?
Old 07-17-2002, 01:16 PM   #4
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Going with a 2.5 in exhaust vs a 2.25 in exhaust isn't going to have any real noticeable negative effects...I believe. You may loose a little off the low end and not quite rev up as quickly but I feel it won't be enough for you to notice...and if you put on a nice smooth flowing intake I doubt you will notice anything at all.
But I agree with Section 8...if you are going to SC I'd go with the larger 2.5 exhaust. I'd do head work as well, of course.
NC
Reciprocity is online now   Reply With Quote
Old 07-17-2002, 01:37 PM   #5
PGH'02RS
Member#: 17975
2005 911 C2
Slate Gray Metallic
custon bent mandrel is the way to go, in my opinion. Less $$, perfect fit, and you have your choice of any muffler to weld on to it. I would also have to concur with the 2.5" piping if you are planning on supercharging it. good luck
PGH'02RS is offline   Reply With Quote
Old 07-17-2002, 01:46 PM   #6
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
I would highly recommend the MRT Header and Cat section. Actually just the header section. I believe there would be better gains with a 2 in 1 out style cat then the 1 in 1 out design MRT has chosen. Beyond that the MRT header design is the absolute best design for even linear exhaust flow. A 2.5" cat back would probably be beneficial to even an NA EJ25. I think it was SCC that did direct comparison tests on multiple 4 cylinder cars comparing 2.25" cat-backs to 2.5" pipes. They found much better top end gains with gains down low similar to the 2.25" piped models.
Anyway whatever you do, supercharged or not, don't buy the MRT muffler. Its standard reversion type muffler that even sounds restrictive. Go buy a nice cheap 2.5" stainless muffler that allows the exhaust to flow more freely. I bought a stainless Powertech from Ebay for $80 + shipping. It looks/works/sounds great.
I have to confess that the MRT header design really smooths out the otherwise sputtery and aggressive sounding motorcycle like exhaust pulses. Thats OK it still sounds way better then any other 4 cylinder out there and makes more power then most of them with this exhaust
MY99 2.5GT is offline   Reply With Quote
Old 07-17-2002, 02:20 PM   #7
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
MY99 2.5GT : Thanks. I'll go with the Custom Cat Back first and look into an MRT header/Cat combo later since those thing are hard to find. I sent an email out to Brian @ lagnston Subaru but it'll probably be awhile.
and yeah I'll post pics of my exhaust (dual titanium tips HEE HEE
) in the exhaust thread so you can see. Now I just gotta look into resonators to shut that bad boy up
Old 07-17-2002, 02:22 PM   #8
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
PS drcrawford is the man !! I look for that guys exhaust threads every time I do a search LMAO I learned more about headers from reading his posts than anywhere else!
Old 07-17-2002, 03:37 PM   #9
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Wow...thanks Karlos! I really appreciate that. I've tried my best to pick up as much knowledge as possible from the posts here...so in a lot of ways I'm just restating a lot that's been said in the past. But I have learned a lot and even more importantly, had some first hand experiences.
Thanks!
NC
Old 07-17-2002, 04:14 PM   #10
Mr. Rogers
Member#: 17028
2002 2.5 TS wagon
dcrawford: No problem. I just ordered my muffler from Speed Pro 1. When it gets here and its installed hopefully with a week along with the intake I'll post some photos. I have yet to see a pic of a dual titanium (w/blue tint thing on the end) tip exhaust on here. It'll be interesting.
Old 07-17-2002, 04:34 PM   #11
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
A titanium exhaust should look and be SWEET. I can't wait to see the pics.
NC
WTB: Cobb 3" Cat Back Exhaust System or a quieter exhaust Yuman Private 'Wanted' Classifieds 13 02-05-2010 09:16 AM
WTB APEXi WS Noir Catback Exhaust or Perrin Cat-Back Stealth Sport System damnedhooligan SCIC Private Classifieds 13 01-24-2009 03:08 PM
Custom Cat-Back vs. Aftermarket System? Crashman287 Newbies & FAQs 9 01-19-2006 05:51 PM
some one please explain to me about a cat back system needsboost2005 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-20-2005 09:51 PM
Attn: Julian and/or those w/ MRT exhaust system jetfire67 Normally Aspirated Powertrain 3 08-02-2001 11:50 PM
