Old 04-22-2001, 11:02 AM   #1
sti2_5rs
Member#: 1578
2000 Impreza 2.5RS
Question Storage! what should i do?
My car is going to sit in the garage for 4 months , so should i disconnect the battery, or is there anything i should do?
Thanks!
sti2_5rs is offline   Reply With Quote
Old 04-22-2001, 11:44 AM   #2
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
Post
Ill drive it around for ya That way you wont have to prep it for storage
Tkacik is offline   Reply With Quote
Old 04-22-2001, 11:51 AM   #3
SkToBe
Ghost Mod
Member#: 1278
2001 RS
Post
Remove the airbox from the throttle body, put a plastic bag over the inlet with rubber bands. This prevents moisture. Also, add some fuel stabilizer to the gas tank. You might also want to put the car up on 4 jack stands. Put some baking soda on a plate and put in the car (prevents mildew). Will it be in a covered and locked garage? If yes, crack a window and use a car cover (even if stored inside). Disconnect and remove the battery.
SkToBe is offline   Reply With Quote
02 WRX. 105K service. What should I do and how much should I pay? st000 Bay Area Impreza Club Forum -- BAIC 6 10-12-2008 04:34 AM
while installing my up pipe i did something bad. what is it and what should i do Yakshii Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-15-2008 01:13 AM
Trespassers... What are they doing? What should I do? markman Off-Topic 102 04-08-2008 01:42 PM
Help...what could be wrong & what should I do? ted dibiase Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-05-2006 09:55 PM
What should I do? What would you do? WiredWRX Southern California Impreza Club Forum -- SCIC 14 08-01-2004 06:08 PM
