Old 04-02-2011, 04:05 PM   #1
Leftlane2
Member#: 251904
2010 WRX 5 Door
SSM
Default High Oil Consumption Subaru TSB 02-115-11
From today's New York Times:
SUBARU - Owners of some 2010-11 models may complain of high oil consumption or see smoke coming from the exhaust. In T.S.B. 02-115-11 issued on Jan. 20, Subaru said the problem in 2010 Foresters and 2011 Legacy, Outback and Impreza models probably stems from faulty machining of the holes for the intake-valve guides. The cure requires replacement of the cylinder head.
Leftlane2 is offline   Reply With Quote
Old 04-02-2011, 06:19 PM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ouch... replace the entire head.
Old 04-02-2011, 10:13 PM   #3
rolling_death
Member#: 235872
05 WRX
I already saw in the last year, 2 current gen Legacies blowing quite a bit of blue smoke out of the exhaust on acceleration. So I guess there really is a problem after all. My mother's 2011 Impreza isn't using any oil thankfully.
rolling_death is offline   Reply With Quote
Old 04-03-2011, 12:07 AM   #4
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Dayyuummm. That sucks.
OrbitalEllipses is online now   Reply With Quote
Old 04-03-2011, 01:01 AM   #5
BigElm
Always under your radar!
Member#: 1568
Please provide a link, otherwise we'll have to close this.
BigElm is offline   Reply With Quote
Old 04-03-2011, 02:01 AM   #6
HB_Dad
Member#: 45190
2014 Impreza Sport L
My Tribeca's been in the dealer shop for two months now for warped cyclinder heads and it turns out the whole engine is now shot and is being replaced by the dealer with a brand-new one albeit very SLOWLY under warranty as a pre-existing condition since I had issues with the heads before! I wonder if this is part of the same issue the recall is all about?
HB_Dad is offline   Reply With Quote
Old 04-03-2011, 02:52 AM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Doubtful, EZ's have a different assembly line not to mention a completely different design.
Old 04-03-2011, 03:09 PM   #8
arghx7
Member#: 232940
It's true.
arghx7 is offline   Reply With Quote
Old 04-03-2011, 03:51 PM   #9
Supraru
Member#: 23313
99' 2.5Rs
black
Great now everyone and their mother will come in claiming their car has oil consumption trying to get a free head when they aren't in the affected range. lol
Supraru is offline   Reply With Quote
Old 04-03-2011, 06:00 PM   #10
banyan
Member#: 181013
Thumbs up
Originally Posted by arghx7 View Post
It's true.
Thanks for posting this (and the other one too)... It will be easy to talk to ***hats at the dealerships.
banyan is offline   Reply With Quote
Old 04-03-2011, 06:14 PM   #11
Supraru
Member#: 23313
99' 2.5Rs
black
That's odd. That engine is pretty damn stout. Only problem is sometimes you'll get misfires from carbon build up in the valves then they won't seat properly. I can tell you replacing valves or taking off the heads suck and techs loose their ass on them.
Old 04-03-2011, 09:59 PM   #12
arghx7
Member#: 232940
You're welcome. It's important to see the real TSB in order to prevent internet rumors and fear mongering.
Old 04-04-2011, 02:39 AM   #13
Jake1050
Member#: 135059
My Legacy is outside the VIN range by 4 units. This is good that my car may not experience this oil burning or bad if it does burn oil and they wont fix it because it falls outside the range.
Jake1050 is offline   Reply With Quote
Old 04-04-2011, 08:46 AM   #14
markbot
Member#: 240552
2011 Subaru WRX
Mine is within the VIN range. But 2.5k since my last service and the oil level is within spec. I planned on getting a change win 1k more, so I'll monitor it until then.
markbot is offline   Reply With Quote
Old 04-04-2011, 08:57 AM   #15
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
Thanks for posting this, mine's not in the VIN range, but had a nice cloud of smoke this morning....
jonklein611 is offline   Reply With Quote
Old 04-04-2011, 12:43 PM   #16
arghx7
Member#: 232940
The way I interpret the TSB, you must have a cylinder head within the serial # range. They go by the head serial #, not the VIN. Also, I'm not positive but I think that would only include non turbo engines. Look under "applicability" on page 1. Then the tech is going to inspect for excessive carbon deposits. Only if you have the head serial # and the excessive carbon deposits will you receive the warranty work.
I'm not sure how this will play out on the individual dealership level though.
Old 04-04-2011, 01:33 PM   #17
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
It's looking like only n/a models are affected which is good for me. Still sucks though
Your car was smoking this morning? While idling or driving? Was the motor warm or cold?
SWP n Gold is offline   Reply With Quote
Old 04-04-2011, 01:39 PM   #18
jonklein611
Member#: 117776
WR Blue Pearl
Motor was warm / hot. Came home, did some stuff (15 min or so), fired it back up and I saw some nice clouds of smoke come out the pipes. Also my exhaust tips have tons of carbon on them.
Old 04-04-2011, 01:51 PM   #19
Vossatron
Member#: 276634
2011 4dr WRX
SSM Whale Tail
Mine is within the VIN range but not within the cylinder head serial range... weird.
Vossatron is offline   Reply With Quote
Old 04-04-2011, 02:39 PM   #20
arghx7
Member#: 232940
They probably narrowed it down to a certain production batch of heads, hence the head serial # range. There may have been a couple different batches that could have been used in the VIN range. So even if you are in the affected VIN range, you may have gotten heads from a batch that didn't have the problem (hopefully).
Old 04-04-2011, 02:49 PM   #21
heavyD
Member#: 194216
2015 FST
If you don't have oil consumption why would you want a 'free' head? I would much rather nobody open up the engine if it's running fine.
heavyD is offline   Reply With Quote
Old 04-04-2011, 06:45 PM   #22
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Ouchie
ejicon is offline   Reply With Quote
Old 04-05-2011, 11:05 AM   #23
NateLS1
Member#: 132380
2004 WRX
rojo
People do that all the time. They want everything fixed before its broken / out of warranty.
NateLS1 is offline   Reply With Quote
Old 04-05-2011, 02:15 PM   #24
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
really.. Then the head gasket will go later on, from them messing with it.
Old 04-05-2011, 02:25 PM   #25
Supraru
Member#: 23313
99' 2.5Rs
black
Because even though people are not having consumption problems they will say they are. This way they dont have issues down the road. That is how it works.
No Oil Consumption Ever, Then Massive Oil Consumption - Where to Start? This Is Not Mike Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 48 12-30-2010 09:18 PM
High Oil Consumption on Legacy. SubbyOBS Service & Maintenance 1 02-15-2008 01:51 PM
Oil Consumption at High RPM spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-13-2005 06:16 AM
Oil Consumption pretty high. delo- Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-29-2004 03:40 PM
