Old 07-17-2002, 01:09 PM   #1
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Default Impreza Wheel Info Collection
< Disclaimer: I don't claim to be a wheel expert. Anything not correct in this post will surely be corrected in subsequent posts by other users, and where appropriate, I will correct this main post. If you have a correction to make, please try to be sure your correction is ... correct. "The Honda tuner down the road told me once that..." is not trustworthy information all the time >
Please add qualified good information to this thread! Some of this information may seem very fundamental and common sense, but there's a lot in here I learned for the first time this past year. Perhaps someone else will.
* General Information *
* A thread about rotational inertia.
* The TireRack Wheel Tech pages (VERY informative -- read it all!)
* The TireRack Tire Tech pages (also VERY informative -- read it all!)
* Ravensblade Impreza is RIFE with information. Spend a good hour there, especially in the FAQ section.
* Wheel and Tyre Bible by Chris Longhurst. Tons of great information.
* Wayne Chin's Impreza Wheel Chart
* Wheels / Rims *
GENERAL: On Weight
Simply put, relative to stock and with regard to performance, heavier wheels are worse than stock and lighter wheels are better. This is a no-brainer. Some people cannot notice a difference in their car's power when fitted with wheels 5lbs (each) heavier than stock. That some cannot notice, or do not care, does not negate physics. If you don't care, then so be it. It's your car. Read the thread about rotational inertia if you care to know some more (linked above in the 'General Information' section).
See the note in the Tires section below as well.
GENERAL: "Ideal" Offsets According to Rim Width for Imprezas
6.5" --> +55ish
7.0" --> +53ish
7.5" --> +50ish
Notes:
* Long-term wheel bearing issues (and possibly other issues) may occur when the vehicle is fitted with wheels having an improper offset.
IMPREZA (all years?) Lug Info
Lug Pattern: 5 x 100
Lug Thread: 12 x 1.25
Lug Torque: 67-70 ft/lbs
Notes:
* Using an improper lug nut thread pitch can result in destroyed lugs and/or lug nuts.
* Exceeding the owner manual's torque specs can strip a lug, the nut, or break the lug completely off. Use a proper tool (one with a configureable maximum setting, like a torque wrench).
* Tighten the lugs with the wheel on the ground and in a 5-point star pattern as if you were drawning it with a pencil.
* Check the lugs' tightness after the first 20-50 miles or so.
MY02 US IMPREZA: Rims
Weight: 16.5 pounds
Width: 6.5"
Offset: +55 or +53 (both have been reported, oddly enough...)
MY00/MY01 US IMPREZA: Rims
Weight: 16.5 pounds?
Width: 7"
Offset: +53
Color: Silver
MY99 US IMPREZA: Rims
Weight: 17 pounds
Width: 7"
Offset: +53
Color: Silver
MY98 US IMPREZA: Rims
Weight: 17 pounds
Width: 7"
Offset: +53
Color: Gold
... more info to come.
* Tires *
GENERAL: Plus/Aftermarket Sizing
Tire Size Calculator
GENERAL: Tire Rubbing
Due to the rear flared fenders in the MY02 WRX sedan when compared to the MY02 WRX Wagon, wagons may have aftermarket wheel fitment issues that the sedans do not (specifics to come...).
GENERAL: On Weight
As you increase rim size (while ideally maintaining OEM overall wheel diameter), realize that you are increasing the tire's distance from the center of your rim. Due to your rims being rotational mass, you will want to keep your tires as lightweight as possible if you are concerned with performance. Spinning a 1lb weight 8 inches from the center of a rim requires less work than spinning that same weight 9 inches from the center of a rim.
MY02 US WRX: Tires
Make: Bridgestone
Model: Potenza RE92
jblaine is offline   Reply With Quote
Old 07-31-2002, 07:52 PM   #2
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Guys, help me out...
I'd like pre-02 Impreza rim and tire specs if you have them. I looked around for that huge wheel specs list/link and cannot find it.
Please state the following, and I will update the post above with the info:
Piece: (Rim or tire)
Year:
Piece model: (Ex: Potenza RE92. Does not apply to some pieces obviously)
Weight:
Width:
Color:
EDIT: Also, if you know about older Impreza lug pattern/sizing, please comment as well (see top post).
Old 07-31-2002, 11:17 PM   #3
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
No point reinventing the wheel. (pardon the pun)
Here's a large list with most of the subaru wheel weights and lots of aftermarket ones as well...
http://wac.addr.com/auto/obs/wheels.html
AllWheelDrift is offline   Reply With Quote
Old 08-01-2002, 08:51 AM   #4
ConeMasher
Member#: 2135
Yeah but the provided link is rather out of date (no Rotas listed, etc). Perhaps combining forces could yield an even more comprehensive library of information...
-- ConeMasher
ConeMasher is offline   Reply With Quote
Old 08-01-2002, 09:00 AM   #5
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Thanks for the link AllWheelDrift. I don't think I'm reinventing the wheel per se. Wayne's wheel information also is not listed in the 'FAQs and Threads of Interest' sticky in this forum. This thread is, and is here amongst the other posts. I've updated the information above with both a) information from Wayne's page and b) a link to Wayne's page. Sweet.
ConeMasher, sorry, I didn't intend at all to post any information about aftermarket rims/tires. I think that would make an excellent separate thread though. I wanted this to just be a gathering for stock specs and general basic wheel/tire information (tips).
Old 08-13-2002, 06:17 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Stock USDM 16 by 6.5 rims are FIFTY THREE, 53mm
Old 08-13-2002, 08:11 PM   #7
NETWRX
Member#: 17364
2002 WRX wagon
Sedona Red Pearl
Default Ronal also makes a number of wheels with offsets as high as 45mm...
NETWRX is offline   Reply With Quote
Old 08-13-2002, 08:28 PM   #8
WRXforME
Member#: 15372
2002 WRX Sedan
WR Blue Pearl
Ya' mean THESE wheels? '02, or do you mean the earlier ones...These are '02's
WRXforME is offline   Reply With Quote
Old 08-13-2002, 08:57 PM   #9
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Ouch
Old 08-13-2002, 10:08 PM   #10
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Sweet.
Thanks for doing this Jeff.
Paul G. <--you must be bored at work.
I'll keep my eyes open for a set of RS rims for ya.
paultg is offline   Reply With Quote
Old 08-13-2002, 10:32 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Mine(Aug/01 mfg. date) were, stamped '53mm" and a tape measure 'SEEMED' to indicate a 7" rim width.....
I think they changed deseign spec's along the way....
Old 08-14-2002, 12:10 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
I have the 02 wheels and they read 53mm. Do I really have to take a picture to prove it?
edit: Damn, never had my post repeated so many times! Extra replies deleted.
Old 08-14-2002, 12:56 PM   #13
Those Meddling Kids
Member#: 4140
02 WRX
00 MR-S
Holy crap quintuple post!
TMK
Those Meddling Kids is offline   Reply With Quote
Old 08-14-2002, 01:34 PM   #14
Dori Dori
Member#: 6780
1993 Nissan
Prove it.
Prove it.
Prove it.
Prove it.
I'm just kidding.
Dori Dori is offline   Reply With Quote
Old 08-14-2002, 02:02 PM   #15
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
For now, I've updated it to say "Offset: +55 or +53 (both have been reported, oddly enough...)"
I'll check my rims tonight since they're off my car.
Old 08-14-2002, 05:24 PM   #16
STI RDY
Member#: 5738
2002 WRX Sedan
Sedona Red Pearl
Mine is +55 offset too...build date February 2001
STI RDY is offline   Reply With Quote
Old 08-14-2002, 05:34 PM   #17
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Okay, mine read 55. That's pretty freaky that they changed spec in the middle of production or something. ciper, do you know when your manufacture date was?
Old 08-15-2002, 05:42 PM   #18
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default My wrx wheels
read 55 offset. I bought them in may of 2001, right after the rexes came out.
subysouth is offline   Reply With Quote
Old 08-15-2002, 09:40 PM   #19
AEA-1919
Member#: 18768
Default My contribution
My January 02 built WRX has 55 offset wheels too. Maybe if enough people reply we can figure out when SoA changed it.
AEA-1919 is offline   Reply With Quote
Old 08-19-2002, 11:49 PM   #20
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Just hypothesizing now...Could it be that all the '02 and beyond ('01 and beyond for our JDM and other DM brethren) Impreza based platforms needed the +55 offset to match with the new chassis' geometry? Has anyone checked an '02 OBS alloy wheel or possibly even the new '03 Forester to see if those models have moved to the +55. Just a thought.
Br, Dale
Subietonic is offline   Reply With Quote
Old 08-20-2002, 12:29 PM   #21
STI RDY
Member#: 5738
2002 WRX Sedan
Sedona Red Pearl
Good hypothesis and very intriguing...mine is built Feb '01 and is stamped 55mm but Uncle Scotty's Aug '01 is 53mm. That seemed "backwards" to your hypothesis . Unless Subaru flip, flop and then flip back to 55mm?
Could the "55" looked like "53" due to brake dust or grime accumulation under insufficient lighting?
(just kidding! )
Mine(Aug/01 mfg. date) were, stamped '53mm" and a tape measure 'SEEMED' to indicate a 7" rim width.....I think they changed deseign spec's along the way....
Old 10-22-2002, 06:25 AM   #22
aspera
Member#: 7879
They did it just to freak me out! Now I have to go to the garage and look! AAAAARRRRGGG!
aspera is offline   Reply With Quote
Old 10-22-2002, 06:32 AM   #23
aspera
Member#: 7879
I'm back. They're 55mm, at least one of them is...
I got mine in early 01. It's old enough to have the early clutch problems, but not the ECU problem (I think?).
Old 10-23-2002, 01:45 AM   #24
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
Ordered 7/01, received 9/06/01: 55 offset, 16x6.5.
To add to the list:
B4 wheels (B4 Legacy, Japan, but available from a number of US dealers), 17x7, 55 offset.
A friend has them on his wagon - with the 4-pots and DBA rotors; very nice looking wheel on the car; Web pictures I've seen don't do it justice at all. (If I'd seen them before I bought the P1s the decision would have been a lot harder )
GravelRash is offline   Reply With Quote
Old 10-23-2002, 09:51 AM   #25
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default Weird
Has any one figured the WRX wheel offset out? When it changed etc.?
subysouth
WTT:my legacy gt wheels and/or wrx wheels and cash for your 5/6 spoke impreza wheels vipernj Private 'For Sale' Classifieds 1 09-11-2005 01:24 AM
Online Technical Info Collection BakedCookies Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 06-11-2004 08:09 AM
Impreza alignment info and questions schnell Brakes, Steering & Suspension 0 02-07-2003 10:23 AM
Impreza ECU info scooby32 General Community 0 12-13-2001 01:33 AM
Please help me! 1998 Subaru Impreza RS Info dman918 Normally Aspirated Powertrain 20 10-18-2001 12:20 PM
