Old 03-26-2012, 03:24 PM   #26
junk240sx
Member#: 53826
2005 WRX STi
CGM
Thanks for the bracket part number. Here is my before and after upgrading to the GR TMIC:
junk240sx is offline   Reply With Quote
Old 03-26-2012, 05:52 PM   #27
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Here it is with a V9 Spec C
It's on top of a twinscroll 16g.
My old thread shows it fitted it in a 2002 WRX.
Old 04-30-2012, 04:00 PM   #28
The Duke
Member#: 264877
Does anyone have any logged data to see any difference?
The Duke is offline   Reply With Quote
Old 04-30-2012, 06:18 PM   #29
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
book marking this... thanks for doing the install
All4bSpinnin is offline   Reply With Quote
Old 04-30-2012, 09:46 PM   #30
wrxstage2
Member#: 149806
I have a gr on my 2006 wrx tr with a vf48 and a bunch of other stuff good intercooler
wrxstage2 is offline   Reply With Quote
Old 05-01-2012, 12:14 AM   #31
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
IA Performance is offline   Reply With Quote
Old 09-17-2012, 10:28 AM   #32
Speakerpatrol
Member#: 99569
2006 VF39 WRX JDMSTI
So yesterday i tried to install a 2011 Sti intercooler on my 06 WRX. There was couple issues that i ran into. I'm running the stock TD-04 btw. First as stated above, the passenger bracket does not reach, you need to extend it out. Second, on the td04 the wastegate actuator line comes out of the top of the actuator and makes a 90 degree turn. So it does not clear the front corner of the intercooler. Third, the 90 degree elbow on the Y-pipe does not reach the turbo inlet on the td04. I figured some people might find this info useful. My solution is to pick up a Vf-39
Speakerpatrol is offline   Reply With Quote
Old 10-22-2012, 10:34 PM   #33
BLUE STINGER2
Member#: 245434
I'm glad this thread is helping out some members here doing this particular upgrade. I'm getting a few messages regarding leaks and honestly I've personally never seen a stock sti gd/gr sti tmic leak around the crimped endtanks but it's definitely a possibility because the endtanks are not welded from the factory. My best advice to you guys doing this upgrade is to pressure test their IC first before installing them to avoid the headache.
Regards,
Ron
BLUE STINGER2 is offline   Reply With Quote
Old 11-20-2012, 11:24 AM   #34
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
The 08-12 STI TMIC has 8 additional crimps vs 04-07 STi so theoretically is 12% more resistant to leaks, 68 crimps vs 76 crimps, 8/68 = 12%.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 11-21-2012, 10:38 AM   #35
Loubaru
Member#: 155489
07 STi
Doesn't the newer one have a larger surface area though....?
Loubaru is offline   Reply With Quote
Old 11-22-2012, 04:50 PM   #36
IA Performance
Member#: 25194
Dark Gray
yes, the new one is wider end to end, hence the added crimps. I'm pretty certain the strength/failure rate would be the same between the 2 different sizes.
stephen
Old 12-21-2012, 12:37 AM   #37
slavik.86
Member#: 238300
00 2.5rs built
ej255 swap
are the y pipes interchangeable?
slavik.86 is offline   Reply With Quote
Old 04-21-2013, 11:58 AM   #38
Dirty Bucket
Member#: 292682
2015 Impreza WRX
WR Blue
Does anyone know where I can pick up that third bracket? I need one for 06 WRX.
Dirty Bucket is offline   Reply With Quote
Old 04-21-2013, 01:22 PM   #39
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
subarugenuineparts.com.
you will find it in their OEM Catalog under: 2011 Impreza WRX - cooling - intercooler - intercooler - support right.
It costs $18.76. I am sure any year 08+ will work, I just chose 2011.
You will also need a bolt to secure the mount to the hole that a 04-07 STi intercooler goes into. It is the same bolt that secures the left side mounting bracket to the intake manifold (there are two there, you only need one extra for the right side though). I just cut the new bracket so I did not have to mess with trying to mount it using all three bolts, you can do it how ever you want though.
jebjkey is offline   Reply With Quote
Old 04-21-2013, 01:30 PM   #40
cmiovino
Member#: 134005
2004 WRX Premium
Nice to know. Not that I'll be upgrading any time soon... lol.
Old 04-21-2013, 05:01 PM   #41
Dirty Bucket
Member#: 292682
2015 Impreza WRX
WR Blue
Thanks!! Just purchased it. Hopefully that's all I need
Old 04-21-2013, 08:18 PM   #42
awdorgtfo
Member#: 252252
2007 WRX Wagon
UGM
Yea I got that bracket and had to cut it because I couldn't figure out where the other end of it mounted. It also hit on my wastegate actuator until I went EWG
awdorgtfo is offline   Reply With Quote
Old 06-17-2015, 11:33 AM   #43
imprezu
Member#: 32224
02 WRX Wagon
WRB Bone Stock
I'm digging up this old thread to get an answer on a coupler that will work on a GR STi to GD.
imprezu is offline   Reply With Quote
Old 06-17-2015, 12:21 PM   #44
my name is joe
Member#: 171412
I just bought a mishimoto one. It was the cheapest one I could find
my name is joe is offline   Reply With Quote
Old 06-17-2015, 02:12 PM   #45
imprezu
Member#: 32224
02 WRX Wagon
WRB Bone Stock
Size and Diameter or link to it please.
Old 06-17-2015, 06:47 PM   #46
my name is joe
Member#: 171412
They only have one.. stock diameter. They just make it longer because its suppose to be cut to fit but its just right. But I would go with another brand. Mishimoto quality is honestly crap.
Old 06-18-2015, 07:44 PM   #47
awdorgtfo
Member#: 252252
2007 WRX Wagon
UGM
I have mi****tymoto, had to cut it
Old 06-18-2015, 10:59 PM   #48
Sikk
Member#: 241662
2006 WRX VF48
to add on to this. is it possible to fit a 2015 TMIC on a 06 wrx? I assume you would need some kind of custom mount.
Sikk is offline   Reply With Quote
Old 06-18-2015, 11:16 PM   #49
my name is joe
Member#: 171412
Its likely the same thing.
Old 06-19-2015, 07:00 AM   #50
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
can you count the rows of the 2015 and then post the number?
Also post a picture of the underside, let's see that v-duct shape.
Widest tire that will fit inside GD wheel well bayluck Tire & Wheel 11 03-23-2010 07:21 PM
will a stock 02 WRX Dowpipe fit my 04 STi ? Extraze Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-30-2009 07:03 AM
Will Sti tmic fit on WRX wrxbert Tri-State Area Forum 6 03-12-2007 06:53 PM
Will GC8 Cusco front camber plates fit a GD front strut? esper Brakes, Steering & Suspension 9 06-17-2005 02:20 AM
Will GC Tein RA Coil Over Fit 02+GD WRX? SpoonTypeR Brakes, Steering & Suspension 2 02-10-2004 02:26 AM
