Old 04-04-2011, 10:40 AM   #1
dwomp24
Member#: 162988
06 06 Sti SM&STU
IAG/EvoSchool/Osgiken
Default Flutter..??
First off let me say this is not my car it is the best quality video of the exact same issue i am having to the T.
I drive an 06 sti
Mods: Invida Divorce Catted downpipe. Intake, cobb pro tune(Ptuning in Northern VA tuned it), fuel pump
Issue: I am receiving fludder, I do not believe it is my wastegate and i dont believe it is Compressor surge. Could it be my stock Bypass valve? It all of a sudden started happening. It really starts in 4,5,6 is im at low rpms building boost and mash the throttle "lets say to get around someone one the highway."
Now if im in 1,2,3rd gear and mash the throttle from a optimum rpm range it only hits about 15.5-16psi and my daily is tuned to 17.5-18
The vid is a camed wrx but with the same issue im having.
dwomp24 is offline   Reply With Quote
Old 04-04-2011, 11:39 AM   #2
KC
Member#: 442
16 SS
00 S2000
Motorsports Forum
The Motorsports forum on NASIOC is for all racing information from beginner amateur to seasoned professional.
You missed. Two of the three forums you posted this same post in have nothing in common with your post.
--kC
KC is offline   Reply With Quote
Old 04-04-2011, 01:43 PM   #3
dwomp24
Member#: 162988
06 06 Sti SM&STU
trying to see if anyone in the racing community is having the same problem, i autocross heavily
Old 04-04-2011, 06:02 PM   #4
garageGT
Member#: 80524
maybe we should have a technical sub-forum under motorsports..there is a lot of good info here and its normal that some subaru owners often ask questions here rather than the generic tech forum.
The problem in the video is the wg blowing open.
PS: Low rpm / high gear driving, along with steep slopes creates massive load. That's how people blow up motors usually, mostly on cold nights. You shouldn't close onto the throttle at low rpm, gradually give more angle until you feel the turbo spool then more throttle if needed..I'm not saying this will fix your problem, in general, this is a bad habit to start with.
garageGT is offline   Reply With Quote
Old 04-04-2011, 06:48 PM   #5
The Database
Member#: 225192
2008 BMW E92 M3
Bat Mobile Black
Make sure all of your lines are secure under the hood. If they are then it is most likely your stock BPV.
The Database is offline   Reply With Quote
Old 04-04-2011, 08:43 PM   #6
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
I'm gonna say bpv. 272 cams and a vf39 is a kinda odd combo, no?
rjrutzky is offline   Reply With Quote
Old 04-04-2011, 09:00 PM   #7
dwomp24
Member#: 162988
06 06 Sti SM&STU
lol thanks for the input and yes i think we should have a tech forum under motor sports. As for the video thats just some one with the same problem as me. im not camed, but yes i do have a vf39 in my o6
So yall think its the bpv?
Old 04-04-2011, 09:40 PM   #8
MSP608
Member#: 149631
ST-3 STi
2.3L Evo
Going with what garageGT said about how this sort of driving produces massive amounts of load, could the high load be causing the turbo to spin so fast that it's out of it's effeciency range and just chopping the air as it comes through the intake?
MSP608 is offline   Reply With Quote
Old 04-04-2011, 10:17 PM   #9
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
I missed the fact that it wasn't your car in the video. Don't get your smileys all in a wad
Old 04-04-2011, 11:16 PM   #10
dwomp24
Member#: 162988
06 06 Sti SM&STU
o yea i totally understand but its doing this in 4th 5th and 6th gear.
its all good lol
Old 04-05-2011, 02:02 AM   #11
The Database
Member#: 225192
2008 BMW E92 M3
Bat Mobile Black
Just go buy a BPV that isn't made of plastic like the OEM one lol. I've got an HKS somethin somethin. Check my profile.
Old 04-05-2011, 10:03 AM   #12
dwomp24
Member#: 162988
06 06 Sti SM&STU
06sti is not made of plastic and i want another oem one i guess..
Old 04-05-2011, 10:08 AM   #13
MSP608
Member#: 149631
ST-3 STi
2.3L Evo
I know, lower gears don't produce as much load as higher gears.
Are any Subaru bpv's made of plastic? My crushed 04 STi bpv is holding ~25 psi just fine.
Old 04-05-2011, 11:57 AM   #14
dwomp24
Member#: 162988
06 06 Sti SM&STU
Are any Subaru bpv's made of plastic? My crushed 04 STi bpv is holding ~25 psi just fine.[/quote]
dont think so.. perhaps the newer models are, idk
Old 04-05-2011, 12:01 PM   #15
garageGT
Member#: 80524
I would borrow one from a friend or put a block off plate for a test drive. Cheaper than buying one just in case it's the WG..
Old 04-05-2011, 03:29 PM   #16
dwomp24
Member#: 162988
06 06 Sti SM&STU
true im just located 3hrs from anyone i know with a sti lol fail
Old 04-09-2011, 01:10 PM   #17
nhat
Member#: 140163
03 STi
hellaflunctional
any GD bpv will work, they're all the same. i have one laying around i think. next time you're in the area, give me a shout in fb.
my vote is the wastegate.
Old 04-09-2011, 02:09 PM   #18
Mystery Machine
Member#: 176116
2006 WRX Wagon
I have this same issue now on my VF43...I run about 20 psi at WOT. It is only when it hits about 18-19 psi that the sound in the video begins.
Not sure...figured it was wastegate flutter....Thoughts?
Mystery Machine is offline   Reply With Quote
Old 04-11-2011, 06:29 AM   #19
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
My 2010 WRX comes with a plastic BPV.
DutchOven is offline   Reply With Quote
Flutter..?? dwomp24 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-04-2011 11:57 PM
Flutter..?? dwomp24 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-04-2011 11:55 PM
wastegate flutter or bov flutter-help!?!? odin1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-08-2004 06:25 PM
fluttering sound coming from intake after throttle lift? pbnj9786 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 03-21-2002 03:20 PM
Fluttering sound in the rear bumper? Daios Car Audio, Video & Security 1 10-02-2000 01:34 PM
