Old 07-17-2002, 04:40 PM   #1
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Question Exhaust pop, 98-99 vs 00 and up
Just curious here...
I've been thinking about the exhaust "pop" that we all seem to experience. From my understanding (and I could be TOTALLY wrong here) it is due to unburnt fuel hitting the hot cat and exploding.
Now...I'm having trouble thinking here but... When a car is running "rich" is that MORE fuel/LESS air than stoich or the other way around?
'Cause I was thinking...again from memory here...the 98s (and possibly the 99s) tend to run LEAN after putting on an aftermarket intake. Now do people with that lean effect experience the same amount of "popping" that us with 00 (which tend to run RICH after an aftermarket intake)?
Throwing it out here...lemmie know what you think.
NC
Reciprocity is offline   Reply With Quote
Old 07-17-2002, 05:17 PM   #2
scoobyguy
Member#: 18374
2002 2.5RS
Blue Ridge Pearl
An answer to your fuel question.
Rich= less oxygen per part combustable fuel.
Parts air|| Parts fuel
Lean 18 : 1
> greater then condition
Stoich ~14.7 : 1
< less then condition
Rich 10 : 1
Someone with a catless setup would be of great help... Do you hear the distinctive "pop."
Oh and one more thing, we must consider the variable in header design. Equal length vs non-equal length. For instatnce do people with MRT "Y" headers experiance "pop."
I think it will be helpful to eliminate or more correctly identify each condition we experience from the setup on our cars so that we break down and ID what the cause is..
~Chaise
scoobyguy is offline   Reply With Quote
Old 07-17-2002, 05:24 PM   #3
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Thanks for the info on rich vs lean.
I have an MRT setup (which is actually an "H" or really...an "A") and I get the pops all the time.
Someone going catless would be the best indicator if it is the cat's heat causing the pops, and would help narrow down the search for information.
NC
Old 07-17-2002, 05:37 PM   #4
imprezadan
Member#: 6935
1999 Impreza 2.5RS
Rally Blue
If I'm not mistaken, the 99s only ran lean after 5500rpm and with an intake. The mass airflow sensor gets "confused" I think.
imprezadan is offline   Reply With Quote
Old 07-17-2002, 11:46 PM   #5
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
yeah, the MAF gets tricked due to vibrations...
It isn't really running lean.
DanzBorin is offline   Reply With Quote
Old 07-18-2002, 12:46 AM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
My car doesnt pop with the custom exhaust I just got... Only once, but I think it was cause it was a hot day (100), and the exhaust had just been welded and was still hot too I dont remember it poping either when I tried reving it without a muffler at all awhile ago... (I couldnt resist!!!)
But, all the newer Imprezas I hear pop ALOT with exhaust mods! Especially your car Niel
Old 07-18-2002, 03:57 PM   #7
Julian
Member#: 1182
MY00 RS
BRP
MY00, I had pop with the stock system, and I either have MORE pop or more NOTICABLE pop with the MRT system. I can get it to not pop by changing how I shift, but I'm not always that concerned. Until I take apart my system to fix the exhaust leak and find out my cat is falling apart like someones...
short term fuel trim is 0%
Long term fuel trim is +2% (was +4% before the exhaust leak).
Julian is offline   Reply With Quote
Old 07-18-2002, 04:31 PM   #8
Jademonkey
Member#: 9213
2000 RS
Red
I have borla header and catback, and I get some LOUD pops. It seems more recently though, since I had my ECU flashed after the last recall...but that could just be my imagination. I did hit a nasty bump, and my 2nd cat shield got scrapped....if my 2nd cat got damaged would this cause more popping?
Jademonkey is offline   Reply With Quote
Old 07-18-2002, 08:33 PM   #9
pillaka
Member#: 16659
2005 WRX Wagon
I have intake and full borla exhaust / headers. My exhaust only seems to pop a lot between 2000 and 3000 rpm.
pillaka is offline   Reply With Quote
Old 07-18-2002, 11:38 PM   #10
nukeyfish
Member#: 7447
2001 RS
BRP
I only have magnaflow muffler,but it pops like crazy. I love it!
nukeyfish is offline   Reply With Quote
Old 07-23-2002, 03:53 PM   #11
scoobyguy
Member#: 18374
2002 2.5RS
Blue Ridge Pearl
Hey have some more info about my own pop problems.... I threw a code about 4 days ago, sorry don't know what code dont have a scanner yet, and the "poping" is now more frequent. I guess I need to check to see if its a CEL issue or not.
However, I think we can get some insight I one of you without a cat can pipe in an let us know if you have "pops".
~Chaise
P.S Sorry for the stupid pun.
Old 07-23-2002, 07:42 PM   #12
tmaler13
Member#: 1992
Hey,
I have Borla headers, no cats or resonator out to the scoobysport backbox and i do experiance the "Pops" I still tend to run rich with my intake...but i hope that when I replace my bad front O2 sensor it should clear up...its funny that even with an s-afc i just can't tune away my rich condition.
-Terry
tmaler13 is offline   Reply With Quote
Old 07-23-2002, 07:47 PM   #13
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Originally posted by tmaler13
Hey,
-Terry
no cats, no resonator? So it's just Borla header...a long pipe...then scoobysport can?
If you are still getting pops then it's not the gasses hitting the cat. Hmmmmm....
Are your pipes coated at all? wrapped?
I had forgotten about this thread!
NC
Old 07-23-2002, 10:54 PM   #14
tmaler13
Member#: 1992
Yes..thats correct, just headers...no wraps or coating, long pipe and the scoobysport. It sounds just like the WRC car. I think this may be solved by getting the o2 sensor fixed. Its just weird i figured that i could control it with my s-afc but i can't...it always seems to be rich and i still get the bad cat too rich sulpher smell.
my egt at wot and cruising stays at 1350 or less no matter how i tune the afc.
Old 07-23-2002, 11:30 PM   #15
obyone
Member#: 16523
I just noticed this today.
Have you guys, who hear exhaust pops, tried bogging down to engine in first? Drive really slow in first gear and let off the gas. (Clutch has to be fully engauged) I ususally do this in the parking garage at work. (5mph limit) When I let off the gas, I can hear the exhaust pop multiple times. It's not as loud as the pops I hear when shifting gears, but its there.
obyone is offline   Reply With Quote
Old 07-24-2002, 04:16 AM   #16
wistful
Member#: 745
2004 STi
Java Black Pearl
my car pops like frickin mad. MRT replica headers, Blitz can. The only time it pops is when I get off, then back on the throttle. At which point my standable o2 meter spikes to rich, then goes back to normal. The pop always coincides with this rich spike.
Don
wistful is offline   Reply With Quote
Old 07-24-2002, 03:43 PM   #17
scoobyguy
Member#: 18374
2002 2.5RS
Blue Ridge Pearl
So can we all agree to rule out cat vs no cat theory??
Let me assume for a minute that the pops are consistent for a rich condition in ever case. Then what we are hearing is unburnt fuel ingniting some where in the exhaust system. I don't see how this could be a good thing.
hmmm... need to get monitoring system installed.
Is there anyone who does not experience this "pop" condition?
~Chaise
Old 07-24-2002, 04:20 PM   #18
Jademonkey
Member#: 9213
2000 RS
Red
Not cats then...it must be header? Those pipes get VERY hot...and the sound would resonate throught he entire exhuast system?
Old 07-24-2002, 05:27 PM   #19
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
I didn't read the whole thread, but couldn't that popping be from when the exhaust gases from the two sides of the engine meet eachother?
garface is offline   Reply With Quote
Old 07-25-2002, 12:19 AM   #20
jeffsnyder
Member#: 10039
my my98 rs has the popping sound when i let off of it a bit then on it again.
From it back firing it blew the guts out of my random tech cat, so i removed it and guted it the rest of the way becasue it was ratting like crazy.
And i still get the popping sound yet but its louder because of just goin in a empty cat and echoing (sp?)
~Jeff
PS forgot to metion borla header, ramdom tech cat and 5ziegn cat back. ohh and i'm an auto too
jeffsnyder is offline   Reply With Quote
Old 07-25-2002, 12:55 AM   #21
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
I have had a stock intake for 3 years. My car always runs rich. I have a Borla exhaust. I have upgraded my intake since and I still run rich. My car is MY99.
Fred Zaplitny is offline   Reply With Quote
05 stock sti exhaust 30k miles SOCAL 250.00 picked up 05stisocal Engine/Power/Exhaust 3 09-06-2009 06:28 AM
model year dilemma 99 Vs 00/01 Sir Punk Newbies & FAQs 3 04-07-2008 12:37 AM
98-99 RS wheels and tires Danbob Private 'Wanted' Classifieds 0 03-27-2005 01:10 PM
FS: Injen CAI for the RS MY 00 and up Frakk's2.5 Southern California Impreza Club Forum -- SCIC 1 01-23-2003 11:48 AM
99 vs. 00 John2.5RS Normally Aspirated Powertrain 10 01-16-2001 11:10 PM
