Welcome to the North American Subaru Impreza Owners Club Saturday August 23, 2014
Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Fred Beans Parts
Old 04-06-2011, 11:42 AM   #1
FredBeansParts
NASIOC Storefront Vendor
Vendor Sales Rating: (18)
Member#: 214387
Exclamation Injector Dynamics Now @ FBP
Fred Beans Parts is proud to announce its newest manufacturer arrival:
Injector Dynamics, or as some of you may know them “ ID “
ID is not new to producing Fuel Injectors by any means, they are most notably known for having the best injectors on the market for two reasons. Both Idle Quality, & ease of Tuning. They exceed all of their competitors in these categories! And with the growing popularity of E85, the need for larger Injector sizes is becoming more mainstream!
Injector Dynamics is a Strategic Alliance between Yaw Power Products and T1 Race Development and was created to bring Yawpower’s dynamic injector characterization technology to the public. Previously this service was only available to tuners in the high end racing industry.
Injector Dynamics pride themselves on providing the absolute best fuel injectors available. ID backs this claim by providing data and technology that absolutely no one in the industry can match!
A Little Bit About the Injector Dynamics Technology:
Simply stated, a fuel injector is a dynamic device. It does not operate in a wide open or “static” condition. To learn anything of value about a fuel injector, it must be tested dynamically.
It must also be tested in an environment that simulates real world conditions as closely as possible. This means testing with temperature controlled gasoline, methanol, E85 or whatever fluid will actually be used on the running engine.
This type of testing is referred to as dynamic characterization, and was recently introduced to the racing industry by Yawpower in collaboration with Motec USA.
The Products:
Injector Dynamics fuel injectors are the result of batch testing large quantities of specially modified fuel injectors, and then carefully matching them into sets based on their dynamic flow across the pulsewidth range. The result is vastly superior cylinder to cylinder consistency, even at very low pulsewidths.
In addition to receiving tightly matched injectors, you will be provided with dead time compensation values across the entire pressure and voltage range of the injector. This data will insure that the compensations in your ECU work properly, and your air fuel ratios will remain consistent as atmospheric or voltage conditions change.
Fred Beans Parts will initially be stocking:
725cc Top Feed Injectors for 2002+ Subaru WRX, 2007+ Subaru STi, & 2007-2009 Subaru Legacy GT
1000cc Top Feed Injectors for 2002+ Subaru WRX, 2007+ Subaru STi, & 2007-2009 Subaru Legacy GT
1000cc Top Feed Conversion Injectors (includes 2 Rails & 1 Injector Set) for 2004-2006 Subaru STi, & 2005-2006 Subaru Legacy GT
1000cc Injectors For 2008-2010 Mitsubishi Lancer Evolution X
1600cc Top Feed Injectors for 2002+ Subaru WRX, 2007+ Subaru STi, & 2007-2009 Subaru Legacy GT
1600cc Injectors For 2008-2010 Mitsubishi Lancer Evolution X
2000cc Top Feed Injectors for 2002+ Subaru WRX, 2007+ Subaru STi, & 2007-2009 Subaru Legacy GT
2000cc Top Feed Conversion Injectors (includes 2 Rails & 1 Injector Set) for 2004-2006 Subaru STi, & 2005-2006 Subaru Legacy GT
2000cc Injectors For 2008-2010 Mitsubishi Lancer Evolution X
Key highlights on the different Injector Sizes:
The ID725cc Injectors:
These maintain strict linearity at flow rates that will satisfy idle and cruise requirements for even the smallest engines. This makes the ID725 ideal for emissions compliant OEM applications while offering the high flow rates required for mildly boosted motors.
The ID1000cc Injectors:
The ID1000 was the first offering from Injector Dynamics, and was also the first injector to deliver a number of innovative features to the performance aftermarket. With a maximum pressure capability of 7 bar and excellent low pulsewidth extension, this is a versatile injector that will be at home in many different applications. From high power high boost daily drivers, the ID1000 set the standard and marked the beginning of a new era in fuel injector performance.
The ID1600cc Injectors:
The ID1600 fills the gap between the ID1000 and the ID2000, and is a drop in replacement for older EV-1 style 1600cc injectors.
Unlike the older technology, the ID1600 has a very gradual rolloff into the lower non linear range, with none of the rollercoaster response caused by undamped pintle bounce.
This smooth response makes for easy idle tuning, even on small displacement motors. In addition to the excellent response, the minimum usable fuel volume nearly matches that of the venerable ID1000, which means if you could make it idle with an ID1000, you can make it idle with an ID1600!
The ID2000cc Injectors:
The ID2000 has set the standard for linearity and control in a large injector! Flowing in excess of 2000cc/min at 3 bar, the ID2000 will also provide a smooth stoichiometric idle on small bore engines running E85, and it will do all this while maintaining strict linearity up to 95% duty cycle at 9000rpm. With a pressure capability of 9 bar this injector can flow as much as 3700cc/min with excellent low pulsewidth linearity, and has the broadest operating range of any injector on the market.
FredBeansParts is offline   Reply With Quote
Old 04-20-2011, 02:47 PM   #2
FredBeansParts
Member#: 214387
in stock! these are awesome
Old 05-09-2011, 02:15 PM   #3
creative wrx
Member Sales Rating: (4)
Member#: 141754
04 stock wrx ;)
z31 project, passat dd
i heard that the 1600cc top feeds may not truly work with the wrx for some odd reason. Do you have any wrx's running them.
creative wrx is online now   Reply With Quote
Old 05-20-2011, 10:28 AM   #4
FredBeansParts
Member#: 214387
hmmmm good question, what is the reasoning?
Old 05-20-2011, 10:47 AM   #5
creative wrx
Member#: 141754
04 stock wrx ;)
I wasnt given a specific reason but the shop had said they contacted ID and in response they were told since they do not make a wrx specific 1600cc injector they can not confirm or deny if they would fit. confusing to me because the top feed tgv's are the same from my understanding.
Old 08-22-2011, 05:24 PM   #6
FredBeansParts
Member#: 214387
in stock!
Old 01-16-2012, 04:39 PM   #7
FredBeansParts
Member#: 214387
they are IN STOCK!!
