Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 06-19-2013, 12:06 AM   #201
pezcore
Member#: 178045
06 WRX
CGM
Has anyone tried baking headlights that had a clear bra installed?
The 06 WRX I bought has clear bra all over the front including the lights and I want to do a retrofit, but am worried about removing the 3M film unnecessarily or ruining the lights if the stuff melts.
pezcore is offline   Reply With Quote
Old 06-20-2013, 01:45 PM   #202
OBS10
Member#: 348379
2010 Outback Sport
Heres my first attempt at anything like this. wanted to do something different so I did florescent yellow around the projectors.
OBS10 is offline   Reply With Quote
Old 06-20-2013, 01:59 PM   #203
Drowner
Member#: 49297
14 Focus ST3
Its your car, but it looks surprised. I'm not a fan at all.
Drowner is offline   Reply With Quote
Old 06-20-2013, 02:44 PM   #204
alecb
Member#: 335146
2004 STi
Ew ^. Not feeling it at all.
alecb is offline   Reply With Quote
Old 06-20-2013, 02:52 PM   #205
OBS10
Member#: 348379
2010 Outback Sport
Yea Im still not sure how I feel about it. Before I go ripping them apart again Im going to think about it some more. Other thought was to black out the projectors and sides then put on some Morimoto xBALED angel eyes. Would have that thin yellow ring on the projectors when not on but look much less bold. Thoughts?
Old 06-21-2013, 12:07 AM   #206
S1CkWrx
Member#: 325249
2012 wrx
dgm
the one thing i regret not doing was painting the high beam bowl with a yellow glass paint. looks totally bad ass.
S1CkWrx is offline   Reply With Quote
Old 06-21-2013, 09:35 PM   #207
iommichild
Member#: 194990
2008 OBS
Steel Silver/Spark Silver
[/quote]
LOOOOOK INTO MY EYYYYYEEESSSSS!!!
iommichild is offline   Reply With Quote
Old 06-21-2013, 10:17 PM   #208
jimbosv650
Member#: 261307
04 wrx wagon
jimbosv650 is offline   Reply With Quote
Old 06-21-2013, 10:18 PM   #209
personality
Member#: 287830
My retrofit
personality is offline   Reply With Quote
Old 06-23-2013, 08:47 AM   #210
SwiftShifter87
Member#: 208994
2009 Impreza WRX/STI
Camouflage Blue
use a heat gun and run it back and forth along the seem of the light, and that will work just as well, but i recommend another person because doing it alone with a heatgun can suck the big one, doing with a partner is easy.
SwiftShifter87 is offline   Reply With Quote
Old 06-23-2013, 12:35 PM   #211
Risko
Member#: 342526
2013 WRX Hatch
CBS
Risko is offline   Reply With Quote
Old 06-23-2013, 01:26 PM   #212
Jaytronzero
Member#: 356590
2002 WRX Wagon
How much do you charge for people to do people's headlights for them?
Since I'm sorta local, could I just come to you and have you do them sometime so my car isn't down for a few days?
Jaytronzero is offline   Reply With Quote
Old 06-24-2013, 02:24 AM   #213
borderguy
Member#: 333855
2001 Impreza RS 2.5L
BRP
No daytime pics yet...
borderguy is offline   Reply With Quote
Old 06-24-2013, 03:00 PM   #214
TeeYouAreBeeOh
Member#: 281446
2004 STi
Anyone who has a hawkeye or a headlight with a projector you can pull out the cutoff plate that makes the projector light low and spray it whatever color and in the light it will reflect through the projector ball. I tested a headlight.
This is chevy engine block orange
TeeYouAreBeeOh is offline   Reply With Quote
Old 06-25-2013, 12:54 AM   #215
borderguy
Member#: 333855
BRP
My yellow was too bright so I redid them today.
Old 06-25-2013, 12:10 PM   #216
pezcore
Member#: 178045
06 WRX
CGM
I don't have a heat gun
Old 06-25-2013, 05:48 PM   #217
Relier1
Member#: 350437
DIY? How long did it take? Write up or advise? I have the same car and it needs it bad... Too much chrome for a black car.
Relier1 is offline   Reply With Quote
Old 07-14-2013, 06:08 AM   #218
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
It takes about 4-5 hrs.
I did 2012 STI headlights today.
Fat Black Pig Sac is offline   Reply With Quote
Old 07-17-2013, 11:28 PM   #219
Ridin_The_Short_Bus
Member#: 218938
2005 CGM Wrx Wagon
2009 SW Legacy GT Limited
I really like the outcome just to sketched out to try it. Is there anyway to really "fail" at this? I just want to clear my headlights aka remove the amber stuff that's all.
Ridin_The_Short_Bus is offline   Reply With Quote
Old 07-17-2013, 11:38 PM   #220
Andrew025
Member#: 303408
04 STi
There's only a few ways to fail.
You bake it too hot or too long.
You mess up the housing when prying it apart (deforming the housing/seal).
You don't seal it well enough and they leak (this one is easily fixable though but can be caused by the prying that damaged the housing).
As long as you don't rush it, you should be fine.
Andrew025 is offline   Reply With Quote
Old 07-18-2013, 01:20 AM   #221
WRXGURT
Member#: 349538
2006 WRX
Crystal Grey Metallic
I just baked mine today. It's really hard to fail if you ask me, 220 for 20 minutes was perfect and it came apart easily.
WRXGURT is offline   Reply With Quote
Old 07-18-2013, 02:12 AM   #222
crazyjester900
Member#: 323176
2004 WRX
did you guys re use the glue that seals the headlights or use some sikaflex or what ever its called?
crazyjester900 is offline   Reply With Quote
Old 07-18-2013, 02:40 AM   #223
2011sti24
Member#: 295892
2011 sti
white
i wish i had time to do this, plus i would probably mess mine up..
2011sti24 is offline   Reply With Quote
Old 07-18-2013, 02:44 AM   #224
crazyjester900
Member#: 323176
2004 WRX
I have done a set already and I re-used 1 headlight resealed perfect the other lets in a tiny amount of moisture
Old 07-18-2013, 10:13 AM   #225
OBS10
Member#: 348379
2010 Outback Sport
what the....from my experience there is no need to bake the lights that long. 200 for 10 mins is definitely all it takes.
Baking headlights devil13 Tri-State Area Forum 10 10-13-2013 02:11 PM
Clearing/baking headlights for others sc00ter Interior & Exterior Modification 9 04-30-2008 12:19 AM
baking headlights (evo) question PSMWRX03 Interior & Exterior Modification 6 03-06-2008 12:48 AM
baking headlights...HELP! PSMWRX03 Interior & Exterior Modification 10 01-09-2008 09:09 PM
baked headlights and gasket came loose... mindchatter Interior & Exterior Modification 1 04-20-2006 04:43 PM
