Old 07-17-2002, 08:16 PM   #1
Silverscooby27
Member#: 9124
2014 335i xDrive
Default Exhaust: Convince me.
I'm going to turbo my 1999 RS within the next couple months. I already have a 2.25" Stromung dual-tip cat-back exhaust. I bought it for N/A setup. Should I get a 3" cat-back to replace the Stromung when I put the turbo on? What advantages would it give me? Or would I be OK just leaving it? Thanks.
Also what setup should I get?
Silverscooby27 is offline   Reply With Quote
Old 07-17-2002, 09:17 PM   #2
christoph1371
Member#: 1090
I'll answer the stro-dung part 1st. I liked the sound but the welds were crap. Each one I have ever seen (about 8-10) have all rusted and left decent size exhaust holes/leaks.
for the rest i'd like to defer to my mommy...kastle.
ps. xcuse the sarcasm....i am pretty sure I am gonna get fired tomorrow...doah.
christoph1371 is offline   Reply With Quote
Old 07-17-2002, 09:27 PM   #3
Andrew
Member#: 1170
2005 STi
just go to your local muffler shop and have them custom make you a 3" pipe and put on some exhasut tips. itll be pretty loud without a muffler so just have them put on a resonator or two.
or you cna have them put on a muffler like a Magnaflow.
Andrew is offline   Reply With Quote
Old 07-18-2002, 12:35 PM   #4
STiTuner
Member#: 5778
09 135i
Jet Black
I'ld probably shell out for like a magnaflow can and then have a 3 in turbo back.
I've got a 2.5 exhaust (Prodrive WR Sport) right now that should be plenty for what I intend on running though.
Brad
STiTuner is offline   Reply With Quote
Old 07-18-2002, 12:36 PM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Make that 9-11. My welds broke just the other day when the car was towed. The tips scraped on the driveway a very small bit, but it was enough to break em. The Cusco exhaust hangers didn't move enough.
To answer Silverscooby27's question, backpressure is a no-no on all exhausts. Even, N/A cars don't like backpressure. (They like the velocity from smaller exhausts.) So, go with larger if you can afford it.
Charlie
wcbjr is offline   Reply With Quote
Old 07-18-2002, 12:44 PM   #6
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I have a custom made 3" Stromung and have had no problems whatsoever with it... I suppose that has to do with the lack of weather other than extreme heat here in hell, err, I mean Phoenix....
kastle is offline   Reply With Quote
Old 07-18-2002, 02:27 PM   #7
Silverscooby27
Member#: 9124
2014 335i xDrive
I've just ordered a Brullen 3" stainless dual tip cat-back, so I guess the point now is moot, but will the 0.75 inch of diameter behind the downpipe really make that much of a difference? I'm going to have to run the Stromung for a while anyway until the Brullen gets "made", but I was just wondering. I understand that the backpressure will resist the turbo from turning as well, but that's pretty much the extent of my knowledge. Does anybody have an estimate of what kind of HP loss this would be?
Thx.
Old 07-19-2002, 01:34 AM   #8
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Since I installed the Brullen 3" there was a huge differance in spool up time. Boost starts at 2000 rpm 5psi at 2500 an on.
big differance on the pull at around the 4200-4700 range.
Don't know higher than that the clutch slips too much. Need to get the new clutch in soon.
david2z4 is offline   Reply With Quote
Old 07-19-2002, 10:20 AM   #9
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
That car is WAY too clean! Nice!
Old 07-19-2002, 02:07 PM   #10
jlw
Member#: 12654
02 WRX Sdn, 2.5L
Element Tuning GT65r/hdrs
david2z4 ... how is the sound? I'm interested in less back presure, but minimal sound increase.
jlw is offline   Reply With Quote
Old 07-19-2002, 04:08 PM   #11
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
You can have a combo of 6 loudness configurations
Loud muff no resonator
Loud muff w/ res
medium muff no res
medium w/ res
soft muff no res
soft muff w/ res
I got the med muff no res and due to the 3" piping it is just slightly louder than the Stromung.
If you want it no louder than the Stro get the soft muff no res
or the med muff w/ res.
The quietest one would be the soft muffler with resonator.
Old 07-19-2002, 07:12 PM   #12
Silverscooby27
Member#: 9124
2014 335i xDrive
Thanks, that's exactly the kind of info I was looking for.
I'm looking forward to the new setup, although I don't recall getting an option as to the "loudness" of the setup. I hope it's no louder than what I've got now because it's already bordering on too loud.
Old 07-19-2002, 10:49 PM   #13
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
What are the prices like on the Brullen?
garface is offline   Reply With Quote
Old 07-20-2002, 09:14 AM   #14
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Can't remember the price but I think it is in the upper $600's. I got it with a polished muffler can so it was $50 extra + rush shipping DHL which was a little over $200 more.
I would call and comfirm what configuration you got. The Loud w/out res is quite loud!
Contact Larry Ganz or Jack (GTBGUY). Jack handles all the US Distributors I think.
One more thing, Don't expect a lightweight settup, this thing could work on a semi truck, it is a beefy just under 40 lbs.
The test drive convinced me, but now... AWDriver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-16-2001 05:55 PM
im terrified, help convince me..... SLIM General Forum Archive 15 03-21-2001 07:16 AM
convince me to order my WRX!!! shaolin General Forum Archive 13 01-22-2001 09:27 PM
WRX or IS - PLEASE convince me!!! RacerinLSL General Forum Archive 58 01-22-2001 01:34 PM
