Old 04-07-2011, 07:43 PM   #1
Pstl_Pete
Member#: 171000
08 WRX sedan
flat black
Default 08 WRX flashing cruise control light (NO CEL)
This has been an ongoing problem with the car and I'd really like to track down the issue.
The cruise control light flashes after Ive been driving the car for a bit. I had the car at the dealer and they didn't find anything (I dont even know if they looked into the light since they were more concerned with the hill assist light).
My hill assist light is also on but otherwise everything is good, no CEL. The cruise control doesnt work though.
Anyone have a similar problem? Suggestions on how to fix this?
Pstl_Pete is offline   Reply With Quote
Old 04-07-2011, 09:49 PM   #2
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I occasionally get the Hill Assist light (and hill assist does not work). The light will go on for a day or so and then go off. Three times now I have also gotten a CEL (and all the other lights that go on with a CEL, Cruise, TC, Hill Assist, etc).
The CEL scans as a P0852 - Park/Neutral Switch. Based on what I've read, this means I have a bad clutch sensor. Haven't gotten much further into troubleshooting yet, because the light goes away for at least a couple weeks after it gets reset.
Anyone know where this sensor is located, or where to order one? Is it on the clutch pedal assembly? Maybe on the transmission somewhere? I think I might have seen that online. How do you access it? I'd rather just replace the sensor myself if it's an easy plug and play.
xluben is offline   Reply With Quote
Old 04-08-2011, 07:35 AM   #3
4080wrx
Member#: 68129
Chapter/Region: HIIC
2001 Impreza RSTi
flashing cruise is usually an indication of a temporary problem. what problem you ask? until read the codes there is no telling what. get the code read....
mine flashed recently and when I read it, it turned out to be the front O2 getting a low voltage reading.
4080wrx is offline   Reply With Quote
06 WRX CEL and flashing cruise control light. Mehdik Service & Maintenance 13 12-06-2011 08:49 AM
Check Engine Light and Flashing Cruise Control Light moose00015 Newbies & FAQs 17 05-29-2011 09:16 PM
Flashing Cruise Control but no CEL blindgoldfish z Newbies & FAQs 0 02-06-2011 12:06 PM
check engine light + flashing cruise control light ericmwas Newbies & FAQs 6 08-24-2009 11:21 PM
flashing cruise control with no chip ecasirhc Engine Management & Tuning 0 03-05-2007 05:01 PM
