Old 07-17-2002, 08:49 PM   #1
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
Default Fuel pressure and injectors
Ok, I'm running 4.5 pounds on my Ludespeed kit and my injectors are hitting 80% duty cycle when I'm really on it. I would prefer not to go abouve 85% on the injectors and I woul like to run more boost, so my question is do I have to get bigger injectors or can I just get an adjustable FPR and crank up the fuel pressure?
PunKidd is offline   Reply With Quote
Old 07-17-2002, 08:56 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
You could crank up your fuel pressure a bit, but I wouldn't suggest going too high on the stock injectors. What is the current high pressure that you are seeing at full boost?
Old 07-17-2002, 09:09 PM   #3
PunKidd
Member#: 8533
2002 2.5 RS-T
I don't know. I don't have a fuel pressure gauge just yet.
Any idea what a high, but safe pressure is for the stock injectors.
Old 07-17-2002, 10:52 PM   #4
Delicious Tuning
Member#: 1990
Get bigger injectors, raising the fuel pressure is not the greatest solution. Since then you will be really overworking the injectors, that were based on lower pressure settings.
Delicious Tuning is offline   Reply With Quote
Old 07-18-2002, 03:00 AM   #5
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I am told that the stock ECU for 2000-2002 can't handle bigger than 25% over stock on the new injectors if you wanna meet emmisions in closed loop and idle.
I am also told pushing the fuel pressure over 70-75 psi will sometimes make the stock injectors stick open.
Your best bet is to add extra injectors like I did at www.SubaruPlanet.com/sdsefi.htm or to get a programable ECU with bigger injectors if you can afford it.
Otherwise, get a fuel pressure gauge and push about 70-73 psi fuel pressure with a 4:1 or 5:1 RRFPR at 6 psi for 250hp and be happy.
ImprezaRS dot com is offline   Reply With Quote
Old 07-18-2002, 11:53 AM   #6
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Yah, but there aren't any injectors that are direct replacements for MY 2000/2001 RS's are there? From my knowledge that RC's have to be modified, though Imprezha here on the board is testing out a prototype set for us RS guys, so maybe soon.
Graham
Graham is offline   Reply With Quote
Old 07-18-2002, 12:07 PM   #7
PunKidd
Member#: 8533
2002 2.5 RS-T
OK I will avoid running higher pressure beings my main concern was overworking the stock injectors in the first place.
I am already running the Link, so I'll just have to come up w/ the cash to get bigger injectors.
The WRX injectors will work on the EJ25 you just have to add a spacer under the fule rail beings they are taller and you have to chance the o-rings so that they will fit. Andrew at AMR has already been down that road. The same thing goes for the RC injectors, they are not "direct" replacments, but it doesn't take much to make them fit.
Old 07-18-2002, 12:29 PM   #8
STiTuner
Member#: 5778
09 135i
Jet Black
Graham
the DSM injectors will fit in you just need to add some resistors and a few other things to make them work right. shouldn't cost a whole lot more to get them to work.
Brad
STiTuner is offline   Reply With Quote
Old 07-19-2002, 01:53 AM   #9
Imprezha
Member#: 6818
2002 NSX
2010 Gen Cpe,2016 Outback
My rc440cc injectors are not in yet. Tom said it should be in anyday. I'll let you guys know how it works out.
Imprezha
Imprezha is offline   Reply With Quote
OEM WRX blue injectors, fuel rails and injector wire harness SedonaRed03WrX Engine/Power/Exhaust 5 01-08-2009 12:26 PM
Fuel pressure and its effect on injector performance ravenhil Commercial ECU Reflashes 15 07-01-2008 07:27 AM
For Sale: DEFI BF AMBER IMPERIAL fuel pressure and oil pressure syoung0298 Interior/Dressup/Audio & Security 5 06-09-2008 01:12 PM
Fuel pressure and larger injectors. Aus_RS Normally Aspirated with bolt-on Forced Induction Powertrain 6 05-17-2005 08:10 PM
First results: High fuel pressure, and... scootr Normally Aspirated with bolt-on Forced Induction Powertrain 12 11-24-2001 02:18 PM
