North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 07-17-2002, 09:53 PM   #1
saggioWRX
Member#: 18994
08 GTS
10 CTS W
Default Blitz Dual TT Install Q's?
Ok, I have the Blitz Dual TT, and I did buy the wiring harness. I installed everything "but" the length of wire from the Alarm Module to the parking brake sensor Module. And the damn boost gauge vacuum hose.
So first off, do I run a wire from the Dark green/w/black strip above the fuse panel, to the gray wire that goes to the parking brake sensor??? Does this make my alarm work again? Cuz right now, my alarm doesn't work anymore And Yes, I went to Swankmonkey.com but it's as clear as mud how they explain it!
And for the boost vacuum hose. Do I go to the BOV hose, or the FPR hose? Ivan......if your reading this please let me know what you did with yours! Thanks everyone, Later
saggioWRX is offline   Reply With Quote
Old 07-18-2002, 12:10 AM   #2
iv30
Member#: 10865
16 958.2 997.1 C2S
You need to cut 2 wires one at the at the Keyless entry module above the fuse panel which is a dark green/black wire just cut it and tape both ends. The second is at the alarm module under the parking brake area just cut the gray wire and tape both ends. The parking sensor wire from the TT goes to the pink wire beside the parking brake just tap into this wire. For the vacum hose tap into the hose going into the BFV on your right when facing the engine. Thats it. Any problems let me know.
iv30 is offline   Reply With Quote
Old 07-18-2002, 11:16 AM   #3
saggioWRX
Member#: 18994
08 GTS
10 CTS W
Is the BFV, the BOV? Sorry, I know more about Airplanes(Thank God) than my new Rex! Thanks Ivan.
Old 07-18-2002, 11:23 AM   #4
iv30
Member#: 10865
16 958.2 997.1 C2S
Yup BOV, my dislexia is showing
Old 07-19-2002, 10:26 AM   #5
saggioWRX
Member#: 18994
08 GTS
10 CTS W
I.......V.......A........N........I'm not sure if the TT is working now! I drove it to work in the Automatic mode, and it didn't stay running when I got to work. But before I got to my work parking lot I was at a red light for about 2 minutes. Does the TT know when I'm idling, and use this time as the cool down period? Also, on the way home I set it on the Manual mode, and it didn't stay running again! So,....I'm not sure if this is how it's supposed to be working Shouldn't it stay running no matter what if I have it in the Manual mode? Please help! I did exactly what you said to do about ALL the hook ups. THanks Again!
Old 07-19-2002, 12:29 PM   #6
iv30
Member#: 10865
16 958.2 997.1 C2S
I guess the first place to check is the handbrake wire make sure you have a good connection and the hanbrake is engaged. You should see the timer counting down in automatic mode if you see nothing when you shut of your car its the parking brake signal.
Let me konw what happens.
Old 08-14-2002, 08:46 PM   #7
02wrx999
Member#: 22802
2002 WRx
Default Re: Blitz Dual TT Install Q's?
can you post a pic of this hose it would help me out alot, ad im having trouble locating my alarm moduals, the arent in the same places, any ideas?
02wrx999 is offline   Reply With Quote
Old 08-16-2002, 11:58 AM   #8
ChrisDP
Member#: 5879
'02 WRX SDN 5MT
STS Civic, ITA Integra
Just did a search and noticed these threads. I installed my Blitz DTT yesterday. As for the boost tap, I used what I think is the BOV line. If you're standing looking at the engine, the BOV is the gold-tinted circular part with one black vacuum hose, bolted to the right front corner of the intercooler. The diameter of the tubing there is much larger than the fitting Blitz gives you. The ID of the stock tube there is 1/4". The OD of the fitting Blitz gives is 1/8". I picked up two reducers that step from 1/4" down to 1/8". I cut the hose about 3" away from the BOV, then inserted the reducers into both ends. Then I used some 7/64" (any small size will do that fits tightly over the 1/8" end of the reducers and the Blitz fitting) rubber tubing I bought at the autoparts store to connect the Blitz T-fitting between the two reducers. I then routed the boost line through the firewall plug that is right behind the clutch and brake.
As for the factory alarm module, take off the lower dash panel. Stare at the fuse block on the left, the move your eyes upwards. There should be a black box with one wide connector of wires going into it. It's held in by 1 10-mm bolt. Remove the bolt. Find the DARK Green wire with a BLACK stripe on it. (there's also a light green wire with black, this is NOT the one you want) Snip the DARK wire and tape both ends.
ChrisDP is offline   Reply With Quote
Installing JDM Blitz Dual TT Santo Domingo 2.5 RS Normally Aspirated with bolt-on Forced Induction Powertrain 4 06-29-2003 05:29 PM
Need help on installing Blitz dual TT edkwon Electrical & Lighting 2 05-12-2003 03:52 PM
Blitz Dual TT install questions WRX Power Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-06-2001 06:34 PM
Blitz Dual TT or MSTT? dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-22-2001 11:49 AM
Blitz Dual TT questions? jjameson New England Impreza Club Forum -- NESIC 0 05-01-2001 08:28 AM
