Old 07-11-2012, 04:33 PM   #26
4Flat4Life
Member#: 321041
2004 WRX
Originally Posted by gorillaphones View Post
Is it possible to do this same process with the tail lights as well?
Why would you touch the sexiest tail lights of an 04WRX ?!
4Flat4Life is offline   Reply With Quote
Old 07-19-2012, 02:31 PM   #27
Gunner Gordo
Member#: 324247
2004 WRX wagon
4Flat4Life Quote:
I actually tried this just to see if it would be the same as the front lights since I am not a fan of chrome either. I got so far as baking the tail light assembly but was unable to separate the bezel from the outer lens. I tried different temps and times in the oven under close watch and tried to pry in 3 different areas to no avail. The plastic either gets too hot (soft) or not hot enough to breakdown the adhesive holding the assembly together.
I did not want to push it and crack a tail light or mar it up too bad. Any one else have success in this area?
Cheers,
Gordo
Gunner Gordo is offline   Reply With Quote
Old 07-19-2012, 02:33 PM   #28
Gunner Gordo
Member#: 324247
2004 WRX wagon
Cheers,
Gordo
Old 08-31-2012, 01:05 PM   #29
juntao3
Member#: 269549
2005 Impreza WRX
awesome project...did mine and came out gr8...dont b like me and be lazy and not put the extra sealant on when u bake it back together....andddddi put the oven up to 220...its not too hot but it makes it easier to pull the housing apart..and when i put my headlight back into the oven for reassembly..i say the headlight housing on its back and i put the headlight cover on top so when the goo melted it melted down to where it was supposed to go and it was easier to jus press together
juntao3 is offline   Reply With Quote
Old 09-08-2012, 07:53 PM   #30
jgates411
Member#: 148524
2002 05 STI convert!
Man my headlights are fogged bad! They were spray tinted when i got em. I stripped all that spray off today, they were still hazed out so I pulled em apart and the insides look horrible lol. Definite fail.
jgates411 is offline   Reply With Quote
Old 09-09-2012, 09:55 AM   #31
hoffmanEstates
Member#: 122043
04 wagonier
psm
Tail lamps wont work I believe as.they are either welded together or molded together. I would never fubar 04 tails those are rare and worth $ to some peeps
hoffmanEstates is offline   Reply With Quote
Old 10-21-2012, 10:06 PM   #32
calimojo
Member#: 334163
2004 STI
Aspen white
Exactly what i needed. Great job on the instructions! might also do a different color than black but not 100%. i have an 04 and i was thinking of just tinting the red are and leaving the clear alone.
calimojo is offline   Reply With Quote
Old 12-22-2012, 09:46 PM   #33
Megabytesz
Member#: 302104
2005 STi
World Rally Blue
just did this mod in 8 hours, 4 hours each, that included sanding & buffing the lens to shine them back up.... Thanks!
Megabytesz is offline   Reply With Quote
Old 12-31-2012, 11:33 AM   #34
Lima05
Member#: 322809
2005 wrx
grey/black
Cool tails
it is possible to black out the tails i did it about a year ago with a friend of mine i can get pics and try and remember the details on the process.
Lima05 is offline   Reply With Quote
Old 01-11-2013, 02:23 PM   #35
Tgates3
Member#: 343266
2004 Sti
Wrb
This is supper cool, I'm going to do this this weekend, thanks for the write up!
Tgates3 is offline   Reply With Quote
Old 01-11-2013, 03:20 PM   #36
alt14
Member#: 271928
2007 Impreza 2.5i SE
http://forums.nasioc.com/forums/show....php?t=1098681
Link for diy on the tails.
If you can buy a second set, they're pretty cheap, this way you can take your time because sealing these is a lot different then the headlights, I used an epoxy plastic welder and have yet to see leaks, knock on wood.
alt14 is offline   Reply With Quote
Old 01-16-2013, 04:21 PM   #37
rodm57
Member#: 328918
2005 wrx
wrb
Looks great. How much did it affect the brightness of the headlights at night?
rodm57 is offline   Reply With Quote
Old 02-08-2013, 07:04 PM   #38
TurboSTIPower
Member#: 342225
2004 impreza sti
wr blue
anyone want to trade their untouched set for my blacked out with halo set of headlights? i bought the car with this mod and i dont really like it and would like to go back to stock
TurboSTIPower is offline   Reply With Quote
Old 03-17-2013, 06:16 PM   #39
nola
Member#: 291124
05 wrx
blue
Thanks for the info
nola is offline   Reply With Quote
Old 03-20-2013, 06:06 PM   #40
dirrtydetroit
Member#: 295302
2005 RS Wagon
Did this a few months back, went with white instead of black since i love the clean look. Also white bezels on a soon to be OPB car should look nice.
Forgive the mess my bumper is/and lack of turbo.
dirrtydetroit is offline   Reply With Quote
Old 03-27-2013, 07:20 PM   #41
janderson13
Member#: 306735
2004 WRX STi
IM getting ready to do this, can you clear up one thing for me? Which part is the hid backpack? And the " rubber seal " basically I thought all you had to do was remove all the light bulbs? What is the " backpack " can you put that and the rubber seal out for me please!
janderson13 is offline   Reply With Quote
Old 04-06-2013, 06:34 PM   #42
Devistater
Member#: 352517
04 Wrx
If the headlight is real hazed out inside and out is there any way you could buff it out or am I just screwed? And if it is possible how would I go about doing it?
Devistater is offline   Reply With Quote
WTT? 04 WRX Headlights for 05 WRX/STI Headlights BuyMeAnEnergyDrink Exterior/Styling 0 01-23-2009 01:38 AM
04/05 wrx/sti orange headlight reflectors chaoticSTi Exterior/Styling 4 01-05-2007 05:21 PM
FS: Passenger-side 04-05 WRX Sti headlight & damaged driver-side Mudguts Exterior/Styling 8 12-28-2006 11:17 PM
04-05 wrx/sti smoked headlight film anthonyrb98 Exterior/Styling 1 10-22-2006 01:53 AM
Need Jdm Sti Hid Headlights 04-05 Wrx straywise Private 'Wanted' Classifieds 0 08-22-2005 11:33 AM
Message Board Statistics All times are GMT -4. The time now is 03:02 AM.
