Old 04-09-2011, 04:50 PM   #1
thegarius
Member#: 151891
2011 WRX
WR Blue Mica
Default Ap Log for 2011 WRX - Stage 1, 93 - CYLINDER KNOCK - PLEASE HELP..........
Been running stage 1, 93 octane on my new 2011 wrx for about 2 weeks - has about 700 miles on it. I did my first real pull for data today - started recording from 0-80 mph. Ran 2nd and 3rd gear from 2,000 rpm to 6,000 rpm with the pedal all the way to the floor twice. There is some basic driving around between each pull and after both pulls.
I have been posting all over and can't get any one to take a look and offer some thoughts on my readings. Im a noob definitely, and want to make sure that things look right with the car - I don't want to hurt it since its so new.
I posted the spreadsheet to google docs spreadsheets - please review - any assistance is much appreciated:
https://spreadsheets.google.com/ccc?...lE&hl=en#gid=0
thegarius is offline   Reply With Quote
Old 04-09-2011, 05:54 PM   #2
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
No break in for you, not even one oil change? If you develop any serious engine problem, it will be out of your pocket. Amusing that you mention: "don't want to hurt it since its so new" and yet you push a new engine 100% still on factory oil.
moonrider_99 is offline   Reply With Quote
Old 04-09-2011, 07:00 PM   #3
starbai007
Member#: 245652
2010 LGT
graphite
From my newbie experience it looks great ...but I've just been getting into this three days ago.
starbai007 is offline   Reply With Quote
Old 04-09-2011, 08:03 PM   #4
PeteJM
Member#: 244836
2012 Legacy 3.6R LM
Thats not much Knock as the sum reads 3... Break in your engine before you start doing hardcore stuff.
Aside from this, I highly suggest you log LESS data.
Critical Stuff =
Engine Speed
Inj. Duty Cycle
Fuel Pump Duty
Throttle Position
Wastegate Duty
Boost Target
Calculated Load
Coolant Temp
Knock Sum
LM1-A/F Ratio *IF YOU HAVE A WIDEBAND, I use a MTX-L from Innovate to log this*
If your Injector Duty gets above 90% its time for new ones that are rated higher, other than that, I highly suggest you go to EFI 101 from EFI University. Will teach you a lot.
PeteJM is offline   Reply With Quote
Loaded COBB AP Stage 1 93 oct in 2011 STI!! jockeygolfs Newbies & FAQs 843 08-26-2011 06:54 AM
Dyno Tune: Stock 2011 WRX Stage 1 KWIL Proven Power Bragging 68 07-25-2011 11:36 PM
AP stage 1 91 octane vs stage 1 93 octane mccallrl AccessPort 1 05-16-2007 12:28 PM
Dyno Flash Pro Tune vs Cobb Base Map on 04 WRX Stage 1 93 octane Dyno Flash Proven Power Bragging 13 10-26-2006 02:09 PM
wrx hits 10psi and knocks.. please help mastershakewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-23-2006 04:33 PM
