Old 07-17-2002, 11:11 PM   #1
rupteur7000
Member#: 11585
02 2.5RS
i am also not a p****
Default Still looking for ECU diagram
i am still looking for an ECU diagram so i can hook up that damn air/fuel gauge in!!
anyone found one, i tried B136 #18 with no luck so i am assuming it is different from the 01 RS
any help is welcome
thanks
rupteur7000 is offline   Reply With Quote
Old 07-17-2002, 11:33 PM   #2
jkyes
Member#: 707
99 Legacy GT
Quick silver
try
http://www.northursalia.com/index1.html
look under technical documents
jkyes is offline   Reply With Quote
Old 07-19-2002, 09:36 AM   #3
rupteur7000
Member#: 11585
02 2.5RS
it is not in that site, i already looked and tried the pin out B136- #18.
i need someone with experience with the MY02 RS
thanks for looking anyway
Old 07-19-2002, 09:39 AM   #4
Puckaveli
Member#: 1518
00 2.5RS
Give me your e-mail I have a Word doc of the ecu pin outs.
Puckaveli is offline   Reply With Quote
Old 07-19-2002, 01:46 PM   #6
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
Also, for future reference, if you really are stuck, for example, I couldn't find a diagram anywhere anyhow from anyone for my 1990 Legacy for the A/F meter. So I took a 15ft long peice of wire, disconnected my O2 sensor and hooked the wire up to the white? wires terminal, and then used the continuity check on my multimeter to find the ECU pin, which was also white, so I only had so many to check. Took me about 5 min, and wasn't TOO stressful
Have fun
ChicksDigWagons is offline   Reply With Quote
Help: Looking for wiring diagram for blitz r115 gauge! dacatz Electrical & Lighting 2 05-31-2006 01:41 AM
ECU Pinouts.. found one, still looking for one! Hoffman Engine Management & Tuning 1 12-10-2004 09:40 AM
Looking for Wiring Diagram for a WRX 6-CD changer 16-pin connector ttl Car Audio, Video & Security 0 05-14-2004 05:19 PM
Service manual; looking for a diagram, or pdf of WRX turbo layout Solomon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-03-2003 01:15 AM
('93-'01) looking for wiring diagrams popnGEAR Impreza Forum 5 05-15-2001 12:33 AM
