#1 |
Member Sales Rating: (14)
Member#: 226535
E. Canada
Vehicle:1998 Impreza L (RIP) |
Over a year to compile the parts, trial and error, tuning, parts swapping, and more tuning...
Worst thing is, its all for sale. ALL OF IT. Make me offers! Located in Kingston, Ontario, Canada: $1200 OBO OFFERS!!! -Complete Longblock, good to 450+ WHP: EJ25 DOHC heads, EJ25 Phase 2 block and crank, EJ257 rods, Mahle 99.5mm forged 2618 alloy pistons, Clevite main and rod bearings, shimmed 10mm oil pump, Cometic 0.040" 1mm head gaskets, 8.78:1 compression, OEM Subaru gaskets throughout, new valve seals, turbo oil return boss tapped and fitted on right side head, same as turbo oil supply(~600 miles on block, not even fully broken in yet! Doesn't leak oil!!!) Can part out if enough interest $125 Shipped -AVO 2.5" downpipe, with bellmouth T25 flange, modified to bolt up to stock WRX/STi Cat and midpipe. Comes with 2004 WRX Cat. $60 Shipped -1998 EJ22 grey top injectors (modified to ~500cc) $40 Shipped -GM 2 bar MAP sensor, OEM, with connector pigtail $50 Shipped -GM 3 bar MAP sensor, New, with connector pigtail $70 Shipped -B&M fuel pressure regulator (Brand new, never used) mounted on stock 1998 impreza FPR $70 Shipped -OEM Subaru center gauge pod, modified to accept 3X 2 1/16" gauges $50 Shipped -1998 Impreza EJ22 SOHC ECU (6200 RPM limit) $150 Picked up -1998 Impreza Outback hood with scoops (red) $110 Shipped -EJ22T pistons 4 X B size, no rings $60 Shipped -1999 EJ25 Phase 2 rods $750 Picked up OBO -2005 STi heated front seats and rear bench with pass through (heater switches sourced from 1998 Legacy Outback, included with seats) $190 Shipped -1998 JDM WRX STi GF8 Momo steering wheel $100 Shipped -1998 Forester gauge cluster (6500 RPM redline, 180 km/h, pinout to match 1998 Impreza, includes harness, Mounts in any 1998 Impreza!) $70 Shipped -1998 Impreza power mirrors (black, work great!) $150 Shipped -2004 Tokico WRX calipers (2 Pots, red, with paint kit to match from Duplicolour) $800 Picked up -2002 WRX 16" rims and 1 summer old Bridgestone Poteza Grids All prices are OBO, dont be afraid to make offers! I dont want my garage full of this stuff. This is my entire Subaru hobby for sale here... It will end up getting thrown out! -Walbro 255 LPH fuel pump (HP version, high flow even at high pressure) SOLD!! (Locally) -Perrin 22mm swaybar, stout mounts and endlinks, all for rear! SOLD!! Thanks Eyeballs -Scangauge 2 OBD2 scan tool, realtime engine sensor monitor(4 at a time)SOLD!! Thanks Vermont22gt -Ebay 3" midpipe with 2.5" adaptor to stock axle back SOLD!! Thanks Jester409 -Kenne Bell Boost A Spark (New as of Jan 2011) SOLD!! Thanks Sirwolf -Greddy Type RS BOV (Genuine with all fittings to recirc/blow off, flanges, etc) SOLD!! Thanks Sirwolf -2007 STi OEM axle-back muffler SOLD!! Thanks mEatwaD33 -2004 STi yellow 550cc Injectors SOLD!! Thanks WhiteBgeye02 -ATP Turbo Fuel pressure gauge SOLD!! -V7 STi aluminum pedals (all three) SOLD!! -Spearco TMIC for GC/GF chassis SOLD!! Thanks Jagular1785 -HKS 3" downpipe, with bellmouth T25 flange and flex section, no cat SOLD!! Thanks Jagular1785 -Kinugawa TD06SL2 20G with 8cm^2 T25 exhaust housing (wrapped with Thermotec turbo wrap) 3" Compressor inlet SOLD!! Thanks Jagular1785 -AVO 2.5 RS rotated mount uppipe with T25 flange (Painted with VHT 2000 degree white, wrapped with Thermotec exhaust wrap) SOLD!! Thanks Jagular1785 -Borla rep SS UEL header (Painted with VHT 2000 degree white, wrapped with Thermotec exhaust wrap) SOLD!! Thanks Jagular1785 -Greddy Emanage Blue with injector and ignition harnesses, and option port harness, Greddy tuner software, knock sensor adaptor SOLD!! Thanks Jagular1785 -AEM UEGO Wideband gauge/controller and sensor SOLD!! Thanks Jagular1785 -Autometer Sport Comp mech Boost, 30 in/hg - 20 Psi boost SOLD!! Thanks Jagular1785 -SAGA EGT gauge and sensor kit, 0-1900 degrees SOLD!! Thanks Jagular1785 -Maxima MAF, filter adaptor, and 3" intake for Turbo setup above SOLD!! Thanks Jagular1785 -1999 Legacy Outback EJ25 DOHC ECU (6500 RPM limit) SOLD!! Thanks Jagular1785 -AEM Water/Methanol Injection kit, setup with 1998 impreza wagon washer tank SOLD!! (Locally) More, cant think of it now. PM for pics and to make offers or just post... See my build thread for pics of most of this stuff... http://forums.nasioc.com/forums/show....php?t=1888017
#9 |
Member#: 226535
E. Canada
Prices added for all!!! Make offers! Should a built EJ25 live the rest of its life in a puddle in some junkyard??
#12 |
Member#: 226535
E. Canada
Car is going to scrapyard tomorrow. ANYTHING you need, NOW is the time to speak up. As of 10 am eastern time, this thing will be GONE!
#17 |
Member#: 226535
E. Canada
Parts are still here, car is gone. Here's whats left:
$1000 OBO OFFERS!!! -Complete Longblock, good to 450+ WHP: EJ25 DOHC heads, EJ25 Phase 2 block and crank, EJ257 rods, Mahle 99.5mm forged 2618 alloy pistons, Clevite main and rod bearings, shimmed 10mm oil pump, Cometic 0.040" 1mm head gaskets, 8.78:1 compression, OEM Subaru gaskets throughout, new valve seals, turbo oil return boss tapped and fitted on right side head, same as turbo oil supply(~600 miles on block, not even fully broken in yet! Doesn't leak oil!!!) Can part out if enough interest $125 Shipped -AVO 2.5" downpipe, with bellmouth T25 flange, modified to bolt up to stock WRX/STi Cat and midpipe. Comes with 2004 WRX Cat. $50 Shipped -1998 EJ22 grey top injectors (modified to ~500cc) $40 Shipped -GM 2 bar MAP sensor, OEM, with connector pigtail $40 Shipped -GM 3 bar MAP sensor, New, with connector pigtail $60 Shipped -OEM Subaru center gauge pod, modified to accept 3X 2 1/16" gauges $60 Shipped -1998 Impreza EJ22 SOHC ECU (6200 RPM limit) $150 Picked up -1998 Impreza Outback hood with scoops (red) $110 Shipped -EJ22T pistons 4 X B size, no rings $60 Shipped -1999 EJ25 Phase 2 rods $190 Shipped -1998 JDM WRX STi GF8 Momo steering wheel $100 Shipped -1998 Forester gauge cluster (6500 RPM redline, 180 km/h, pinout to match 1998 Impreza, includes harness, Mounts in any 1998 Impreza!) $70 Shipped -1998 Impreza power mirrors (black, work great!) $150 Shipped -2004 Tokico WRX calipers (2 Pots, red, with paint kit to match from Duplicolour) $400 Picked up -2002 WRX 16" rims X 4 (no tires) All prices are OBO, dont be afraid to make offers! I dont want my garage full of this stuff. This is my entire Subaru hobby for sale here... It will end up getting thrown out! -Bridgestone Potenza Grids, X 4, SOLD!! (Locally) -2005 STi heated front seats and rear bench with pass through (heater switches sourced from 1998 Legacy Outback) SOLD!!! Thanks BrandonS13 -B&M fuel pressure regulator (Brand new, never used) mounted on stock 1998 impreza FPR SOLD!! (Locally) -Walbro 255 LPH fuel pump (HP version, high flow even at high pressure) SOLD!! (Locally) -Perrin 22mm swaybar, stout mounts and endlinks, all for rear! SOLD!! Thanks Eyeballs -Scangauge 2 OBD2 scan tool, realtime engine sensor monitor(4 at a time)SOLD!! Thanks Vermont22gt -Ebay 3" midpipe with 2.5" adaptor to stock axle back SOLD!! Thanks Jester409 -Kenne Bell Boost A Spark (New as of Jan 2011) SOLD!! Thanks Sirwolf -Greddy Type RS BOV (Genuine with all fittings to recirc/blow off, flanges, etc) SOLD!! Thanks Sirwolf -2007 STi OEM axle-back muffler SOLD!! Thanks mEatwaD33 -2004 STi yellow 550cc Injectors SOLD!! Thanks WhiteBgeye02 -ATP Turbo Fuel pressure gauge SOLD!! -V7 STi aluminum pedals (all three) SOLD!! -Spearco TMIC for GC/GF chassis SOLD!! Thanks Jagular1785 -HKS 3" downpipe, with bellmouth T25 flange and flex section, no cat SOLD!! Thanks Jagular1785 -Kinugawa TD06SL2 20G with 8cm^2 T25 exhaust housing (wrapped with Thermotec turbo wrap) 3" Compressor inlet SOLD!! Thanks Jagular1785 -AVO 2.5 RS rotated mount uppipe with T25 flange (Painted with VHT 2000 degree white, wrapped with Thermotec exhaust wrap) SOLD!! Thanks Jagular1785 -Borla rep SS UEL header (Painted with VHT 2000 degree white, wrapped with Thermotec exhaust wrap) SOLD!! Thanks Jagular1785 -Greddy Emanage Blue with injector and ignition harnesses, and option port harness, Greddy tuner software, knock sensor adaptor SOLD!! Thanks Jagular1785 -AEM UEGO Wideband gauge/controller and sensor SOLD!! Thanks Jagular1785 -Autometer Sport Comp mech Boost, 30 in/hg - 20 Psi boost SOLD!! Thanks Jagular1785 -SAGA EGT gauge and sensor kit, 0-1900 degrees SOLD!! Thanks Jagular1785 -Maxima MAF, filter adaptor, and 3" intake for Turbo setup above SOLD!! Thanks Jagular1785 -1999 Legacy Outback EJ25 DOHC ECU (6500 RPM limit) SOLD!! Thanks Jagular1785 -AEM Water/Methanol Injection kit, setup with 1998 impreza wagon washer tank SOLD!! (Locally) |
#18 |
Member#: 226535
E. Canada
Parts are still here, car is gone. Here's whats left (Everything I have is listed...):
$1000 OBO OFFERS!!! -Complete Longblock, good to 450+ WHP: EJ25 DOHC heads, EJ25 Phase 2 block and crank, EJ257 rods, Mahle 99.5mm forged 2618 alloy pistons, Clevite main and rod bearings, shimmed 10mm oil pump, Cometic 0.040" 1mm head gaskets, 8.78:1 compression, OEM Subaru gaskets throughout, new valve seals, turbo oil return boss tapped and fitted on right side head, same as turbo oil supply(~600 miles on block, not even fully broken in yet! Doesn't leak oil!!!) Can part out if enough interest $125 Shipped -AVO 2.5" downpipe, with bellmouth T25 flange, modified to bolt up to stock WRX/STi Cat and midpipe. Comes with 2004 WRX Cat. $40 Shipped -GM 2 bar MAP sensor, OEM, with connector pigtail $40 Shipped -GM 3 bar MAP sensor, New, with connector pigtail $60 Shipped -OEM Subaru center gauge pod, modified to accept 3X 2 1/16" gauges $60 Shipped -1998 Impreza EJ22 SOHC ECU (6200 RPM limit) $150 Picked up -1998 Impreza Outback hood with scoops (red) $100 Shipped -EJ22T pistons 4 X B size, no rings $60 Shipped -1999 EJ25 Phase 2 rods $100 Shipped -1998 Forester gauge cluster (6500 RPM redline, 180 km/h, pinout to match 1998 Impreza, includes harness, Mounts in any 1998 Impreza!) $70 Shipped -1998 Impreza power mirrors (black, work great!) $150 Shipped -2004 Tokico WRX front calipers (2 Pots, red, with paint kit to match from Duplicolour) $400 Picked up -2002 WRX 16" rims X 4 (no tires) All prices are OBO, dont be afraid to make offers! I dont want my garage full of this stuff. This is my entire Subaru hobby for sale here... It will end up getting thrown out! -1998 JDM WRX STi GF8 Momo steering wheel SOLD!! (Locally) -1998 EJ22 grey top injectors (modified to ~500cc) SOLD!! Thanks jdmcb3si -Bridgestone Potenza Grids, X 4, SOLD!! (Locally) -2005 STi heated front seats and rear bench with pass through (heater switches sourced from 1998 Legacy Outback) SOLD!!! Thanks BrandonS13 -B&M fuel pressure regulator (Brand new, never used) mounted on stock 1998 impreza FPR SOLD!! (Locally) -Walbro 255 LPH fuel pump (HP version, high flow even at high pressure) SOLD!! (Locally) -Perrin 22mm swaybar, stout mounts and endlinks, all for rear! SOLD!! Thanks Eyeballs -Scangauge 2 OBD2 scan tool, realtime engine sensor monitor(4 at a time)SOLD!! Thanks Vermont22gt -Ebay 3" midpipe with 2.5" adaptor to stock axle back SOLD!! Thanks Jester409 -Kenne Bell Boost A Spark (New as of Jan 2011) SOLD!! Thanks Sirwolf -Greddy Type RS BOV (Genuine with all fittings to recirc/blow off, flanges, etc) SOLD!! Thanks Sirwolf -2007 STi OEM axle-back muffler SOLD!! Thanks mEatwaD33 -2004 STi yellow 550cc Injectors SOLD!! Thanks WhiteBgeye02 -ATP Turbo Fuel pressure gauge SOLD!! -V7 STi aluminum pedals (all three) SOLD!! -Spearco TMIC for GC/GF chassis SOLD!! Thanks Jagular1785 -HKS 3" downpipe, with bellmouth T25 flange and flex section, no cat SOLD!! Thanks Jagular1785 -Kinugawa TD06SL2 20G with 8cm^2 T25 exhaust housing (wrapped with Thermotec turbo wrap) 3" Compressor inlet SOLD!! Thanks Jagular1785 -AVO 2.5 RS rotated mount uppipe with T25 flange (Painted with VHT 2000 degree white, wrapped with Thermotec exhaust wrap) SOLD!! Thanks Jagular1785 -Borla rep SS UEL header (Painted with VHT 2000 degree white, wrapped with Thermotec exhaust wrap) SOLD!! Thanks Jagular1785 -Greddy Emanage Blue with injector and ignition harnesses, and option port harness, Greddy tuner software, knock sensor adaptor SOLD!! Thanks Jagular1785 -AEM UEGO Wideband gauge/controller and sensor SOLD!! Thanks Jagular1785 -Autometer Sport Comp mech Boost, 30 in/hg - 20 Psi boost SOLD!! Thanks Jagular1785 -SAGA EGT gauge and sensor kit, 0-1900 degrees SOLD!! Thanks Jagular1785 -Maxima MAF, filter adaptor, and 3" intake for Turbo setup above SOLD!! Thanks Jagular1785 -1999 Legacy Outback EJ25 DOHC ECU (6500 RPM limit) SOLD!! Thanks Jagular1785 -AEM Water/Methanol Injection kit, setup with 1998 impreza wagon washer tank SOLD!! (Locally) Last edited by cdnsigop; 05-02-2011 at 08:04 PM. |
#21 |
Member#: 226535
E. Canada
Looks like I feared shipping the engine for no good reason. I got a hold of a freight company. It costs approx $500 to ship from here (Kingston, ON, Canada) to Boulder, CO, USA. Just to give a ballpark ship price. Door to door, takes 4 business days. Would arrive on a pallet, right to your garage door... Includes liftgate service at both ends.
http://www.freightcenter.com/engine%20shipping.aspx |
#25 |
Member#: 226535
E. Canada
Build Thread: http://forums.nasioc.com/forums/show....php?t=1888017 $1000 picked up!!! $1500 shipped!! (USA or Canada)-Complete Longblock, good to 450+ WHP (8.78:1 compression): EJ25 DOHC heads, EJ20G metal cam gears, EJ25 Phase 2 block and crank, new OEM EJ257 forged rods, Mahle 99.5mm forged 2618 alloy POWERPAK PLUS pistons, Mahle Rings, Subaru piston pin circlips, Clevite main and rod bearings, shimmed & deburred 10mm oil pump, new OEM tensioner, new idler pulleys, new metal rear oil separator plate, new Gates timing belt, Cometic 0.040" 1mm head gaskets, OEM Subaru gaskets throughout, new valve seals, new valves where required, turbo oil return boss tapped and fitted on right side head, same as turbo oil supply. Throttle body, intake manifold, coil pack, new NGK plug wires and plugs, and complete engine harness included. Nothing wrong with this engine, ready to make some serious power! (~600 miles on block, not even fully broken in yet!!) $125 Shipped -AVO 2.5" downpipe, with bellmouth T25 flange, modified to bolt up to stock WRX/STi Cat and midpipe. Comes with 2004 WRX Cat. Designed to be used with AVO's 2.5RS turbo kit. $60 Shipped -OEM Subaru center gauge pod, modified to accept 3X 2 1/16" gauges $60 Shipped -1998 Impreza EJ22 SOHC ECU (6200 RPM limit) $100 Shipped -EJ22T pistons 4 X B size, no rings $60 Shipped -1999 EJ25 Phase 2 rods $100 Shipped -1998 Forester gauge cluster (6500 RPM redline, 180 km/h, pinout to match 1998 Impreza, includes harness, Mounts in any 1998 Impreza!) $40 Shipped -1998 Impreza passenger side power mirror (black, works great!) $150 Shipped -2004 Tokico WRX front calipers (2 Pots, red, with paint kit to match from Duplicolour) $400 Picked up -2002 WRX 16" rims X 4 (no tires) All prices are OBO, dont be afraid to make offers! I dont want my garage full of this stuff. This is my entire Subaru hobby for sale here... It will end up getting thrown out! (okay, probably not, but this stuff has to go!) |
| Thread Tools | |
| Display Modes | |
| FS : Complete Turbo GF firesale, too much to list. Dont miss out here | cdnsigop | Engine/Power/Exhaust | 44 | 08-08-2011 08:32 PM |
| FS: MA - Too much to list in the subject but click to see what's in here! | Aphex28 | NESIC Private Classifieds | 31 | 08-11-2010 02:31 PM |
| 06 WRX Forsale: Partout: Too much to list See Inside. | GregsblueRex | MAIC Private Classifieds | 80 | 09-19-2007 08:49 AM |
| fs: 1996 240sx 419whp... too much to list | forum04pl | Private Vehicle 'For Sale' Classifieds | 28 | 07-27-2007 06:15 AM |
| Whiteline Suspension Parts are now back in stock!!! Too much to list! | SpeedElement | BAIC Vendor Classifieds | 0 | 08-10-2006 06:02 PM |
