Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine Management
Closed Thread
Old 04-12-2011, 09:50 AM   #1
Motion Lab Tuning
Vendor Sales Rating: (6)
Member#: 228856
Default Free Overnight on Cobb AP!! Great pricing on AEM EMS!!
Free overnight shipping on the COBB accessport! Don't wait to get more power and off that crappy stock tune! Motion Lab Tuning is also happy to offer road, dyno, or remote tuning for your Access Port.
Modern vehicles are very sensitive to performance modifications. Simply changing an intake can have a dramatic, even degrading effect on performance and driveability. This is because modern ECUs (Engine Control Units) use very precise sensors to collect data in order to calculate appropriate fuel, ignition and cam phasing responses. Modifying a vehicle with performance parts will most likely cause one or more sensors to be improperly calibrated, feeding erroneous data to the ECU and contaminating the response. This is why changing a part as simple as an intake or a panel filter can cause the engine to run too lean, too rich, or even stumble.
The AccessPORT is the device that enables recalibration of sensors and manipulation of data on the factory ECU. It provides the capability to reflash select segments of information that are stored in the computer that control engine function. These segments of data that are written to the ECU are collectively referred to as maps. Our engineers and calibration specialists create maps that modify sensor calibrations, lookup table values and algorithms to ensure that the ECU is receiving accurate information and responding in an appropriate way.
COBB Tuning provides Off-The-Shelf (OTS) maps for the most common modifications made by performance enthusiasts. These OTS maps recalibrate the appropriate sensors and modify tables with more aggressive settings. The result is increased power output, improved response and better driveability, since all of the components are working together in harmony. It is the ultimate integration of performance and sophistication as the manufacturer's complex and precise engine management logic and ECU data integrity is retained.
The beauty of the AccessPORT is that it can continue to grow with additional modifications beyond the scope of the OTS maps. For more extreme modifications, COBB Tuning AccessTUNER software can be used to create custom tuned maps that match the modifications perfectly. COBB's extensive network of professional tuners are available to custom dyno tune any modification configuration. For those that want to take on the challenge of tuning their own vehicle, AccessTUNER Race is downloadable software with all of the tuning capabilities as used by our professional tuners.
PM me for more info, to schedule a remote or dyno tune, or to order your Cobb access port!
Motion Lab Tuning is also proud to offer AEM Engine management systems. We are working closely with AEM and plan to use the EMS-4 in our GC8 track car. We are very familiar with tuning both series 1 and series 2 EMS.
Series 2:
AEM’s Series 2 Programmable Engine Management System is more powerful than its predecessor. In addition to more robust hardware, there are several improvements over the original EMS, noted in the chart below. Like its predecessor, AEM's Series 2 Plug & Play EMS plugs directly into a vehicle's factory ECU harness and requires no additional wiring or hardware. Windows™ compatible software (XP, Vista, Windows7) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. Our new AEMTUNER software is infinitely adjustable software and allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition.
Key Features:
  • Plugs directly into the factory harness. No rewiring necessary.
  • Uses all the factory sensors.
  • Includes start up calibrations.
  • System is fully enabled and unlocked - Never pay for upgrades!
  • Context sensitive help eases tuning process.
  • Runs on Windows-compatible software.
  • Up to 12 peak and hold injector drivers.
  • Up to 8 direct-fire coil outputs.
  • Up to 16 general-purpose outputs.
  • Up to 8 definable switch inputs.
  • Up to 4 EGT inputs with fuel trim.
  • 1MB of internal data logging.
  • Electronic boost control.
  • Full idle control.
  • Programmable traction control.
  • Software definable knock control.
  • Two step launch control.
  • User configurable soft-cut rev limiters.
  • Wet or dry nitrous control.
  • Tune using new USB communication port or serial port.
  • Works with all AEM gauges
AEM EMS-4:
AEM’s EMS-4 Universal Standalone Programmable Engine Management System is the ideal standalone Engine Management System for modified Powersports and four-cylinder race car applications. The EMS-4 was created using AEM's powerful Series 2 hardware and includes all of its advanced features without the unneeded ancillary components.
KEY FEATURES
  • 4 Saturated Injector Drivers
  • 4 Coil Triggers
  • 8 General Purpose Inputs/Outputs
  • Mag or Hall Cam and Crank Inputs
  • O2 Input
  • Knock Input
  • 8 MB Internal Data Logger
  • VSS Hall Input
  • Can Data Stream
  • USB Comm Port
  • Compact (4.8" x 4.55" x 1.44"), weather/shock proof enclosure
  • Utilizes AEMTuner Interface Software
  • System is fully enabled and unlocked – Never pay for Upgrades
  • Context Sensitive Help Eases Tuning Process
PM me if for more info, schedule a remote or dyno tune, or to place your order!
Alex
__________________
Performance tuning, fabrication, diagnostics, performance parts, and repairs.
4500 Nations Crossing Rd.
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Motion Lab Tuning is online now
Old 04-13-2011, 05:25 PM   #2
Motion Lab Tuning
Member#: 228856
Bump. Great engine management options available from Motion Lab Tuning!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-14-2011, 10:13 AM   #3
Motion Lab Tuning
Member#: 228856
Get your Cobb with free overnight shipping from Motion Lab Tuning! Great pricing on AEM! We are using the EMS-4 on our track car!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-15-2011, 10:33 AM   #4
Motion Lab Tuning
Member#: 228856
Great prices on the Cobb AP and all AEM!!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-16-2011, 10:29 AM   #5
Motion Lab Tuning
Member#: 228856
COBB and AEM for great prices! Some of the best names in engine management software! Free overnight on COBB til the end of May!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-18-2011, 09:31 AM   #6
Motion Lab Tuning
Member#: 228856
Free overnight on COBB!! Pm for best price!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-19-2011, 09:10 AM   #7
Motion Lab Tuning
Member#: 228856
AEM has some of the best standalone EMS on the market!
Free overnight on COBB why wait to go stage1??!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-19-2011, 01:31 PM   #8
Motion Lab Tuning
Member#: 228856
Mid-day bump.
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-20-2011, 10:04 AM   #9
Motion Lab Tuning
Member#: 228856
Don't miss out on FREE OVERNIGHT shipping on COBB AP!! Great prices on the AEM EMS.
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-20-2011, 01:50 PM   #10
Motion Lab Tuning
Member#: 228856
Mid-day bump, we're here til 6pm!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-21-2011, 09:08 AM   #11
Motion Lab Tuning
Member#: 228856
Don't miss out on the free overnight shipping!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-21-2011, 06:25 PM   #12
Motion Lab Tuning
Member#: 228856
End of the day bump! If you ordered your COBB today it'll be there tomorrow!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-22-2011, 09:29 AM   #13
Motion Lab Tuning
Member#: 228856
Free overnight! Order today and flash stage1 tomorrow! Best pricing on the net for AEM!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-25-2011, 10:48 AM   #14
Motion Lab Tuning
Member#: 228856
Free overnight on Cobb until the end of may! Don't wait longer then you have to to get off the stock tune and get more power!
Best pricing available on all AEM!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-25-2011, 10:49 AM   #15
Motion Lab Tuning
Member#: 228856
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-25-2011, 04:20 PM   #16
Motion Lab Tuning
Member#: 228856
Mid day bump! Here till 6est!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-26-2011, 10:52 AM   #17
Motion Lab Tuning
Member#: 228856
Free overnight still going! Don't miss out! Lowest pricing available on AEM
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-26-2011, 05:04 PM   #18
Motion Lab Tuning
Member#: 228856
Let me know what you need we're here til 6!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-27-2011, 09:53 AM   #19
Motion Lab Tuning
Member#: 228856
Don't miss out on FREE OVERNIGHT! Have your COBB AP tomorrow! Best prices around on everything AEM.
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-27-2011, 12:53 PM   #20
Motion Lab Tuning
Member#: 228856
Mid-day bump here til 6EST let me know what you need!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-28-2011, 10:46 AM   #21
Motion Lab Tuning
Member#: 228856
Free overnight on COBB AP til the end of May! Great AEM stand-alone and piggy-backs available!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-28-2011, 04:48 PM   #22
Motion Lab Tuning
Member#: 228856
Lowest pricing available and we will match competitors price if we get beat! Let me know what you need!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-29-2011, 09:16 AM   #23
Motion Lab Tuning
Member#: 228856
Great price shipped overnight on COBB AP! Low price on AEM EMS-4.
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-29-2011, 12:48 PM   #24
Motion Lab Tuning
Member#: 228856
Mid-day bump. Here til 6EST to assist you!
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Old 04-30-2011, 10:18 AM   #25
Motion Lab Tuning
Member#: 228856
Free overnight on COBB accessports! Low pricing on AEM EMS.
Alex
__________________
Charlotte, NC 28217
Phone: 704-527-0100
Email:
Facebook:
Closed Thread
***Today Sale Only! Free Overnight Delivery For Saturday on COBB AP!*** Motion Lab Tuning Engine Management 0 10-22-2010 11:21 AM
Great pricing on STRI, Defi, OEM parts and Accessories, AEM!!!!! subaruwrxparts.com Gauges & Electronics 7 10-29-2009 12:50 PM
Free Next Day Shipping on Cobb AP / Free Ground Shipping on Tactrix Cables! IAG Performance Engine Management 1 01-05-2009 02:59 PM
FREE OVERNIGHT SHIPPING ON COBB ACCESSPORTS!! TurboXS UTEC on Sale Dont Miss Out!! Spun Autosports Gauges & Electronics 88 07-17-2008 07:17 AM
Message Board Statistics All times are GMT -4. The time now is 02:16 PM.
