Old 07-18-2002, 09:45 AM   #1
BIGSKYWRX
Member Sales Rating: (102)
Member#: 7958
09 GH B+
Default Motive power bleeder
Just bled my brakes w/ the Motive power bleeder. While getting the clamp portion sealed over the master cylinder was rather a pain (very tight quarters) after that it worked great. It is definitely a nice way to bleed brakes- especially by yourself. I think it is much superior also than pumping the brakes (seems like it's hard not to induce air w/ that method). You simply pump up some pressure in the holding tank (I used 18psi) then simply go to each brake and bleed off what you need- the pressure does it for you. It comes out at a very steady (rather light) rate. It'd be real handy when doing a full flush. If the pressure goes down- just pump the handle a couple of times.
Like I said the apparatus that seals off the master cylinder could be better designed (ie like the oe cap, just screw it down). Maybe a guy could buy a spare cap and drill a hole into the top of it. You also have to siphon off the excess brake fluid in the cylinder when done- it's filled to the top.
All in all a very worthwhile investment.
You can look at their site here:
www.motiveproducts.com
Big Sky
Old 09-07-2002, 05:07 PM   #2
blubaru
Member#: 13001
This is how the pros do it. This thing makes bleeding brakes so easy it's almost fun! Simple, well made, and only $45! Blows pedal pumping and vacuum methods away!
As Big Sky stated, the only problem with our Subarus is the necessity of using a universal clamp-on adapter to seal at the reservoir (my previous usage was on a VW with screw-on cap adapter.) As suggested by Big Sky, I think the fix is a second cap with a fitting siliconed on or maybe an o-ringed tire valve with core removed. This should work for the clutch as well.
blubaru is offline   Reply With Quote
Old 07-19-2004, 10:53 PM   #3
waveskidude
Member Sales Rating: (3)
Member#: 17007
MBP
Cool
Just picked up the Motive Power Bleeder. The adapter that fits the WRX is actually the Ford 3-prong. Works beautifully. This thing is a bargain for pressure bleeding the brake system.
CUSTOM FORD POWER BLEEDER. Comes with everything you need to bleed your late model Ford hydraulic brake or clutch system and our full 1 year warranty. (See our Application Guide for vehicle compatibility.) Please choose adapter. (Model 0106-7)
Motive Products
I give it five bananas.
waveskidude is offline   Reply With Quote
Old 07-22-2004, 12:38 PM   #4
bcristea
Member Sales Rating: (12)
Member#: 11343
2008 STi
I bought one for my STi and ended up sending it back.
The adapter looked like to much of a pain to deal with. I'd rather just bleed the manual way.
Thats just my opinion.
bcristea is offline   Reply With Quote
Old 07-25-2004, 01:31 AM   #5
waveskidude
Member#: 17007
MBP
Ya the Universal Adapter is worthless. It took me 45 minutes of screwing around with that thing to get a seal. Then I found out the Ford 3-prong adapter fits. Not sure if the WRX reservoir is the same as the STI.
Old 04-28-2005, 02:01 PM   #6
WRXRgr
Member#: 54942
2004 WRX
Another thumbs up for the Motive Power Bleeder!
Just got thru bleeding my MY04 WRX...first time ever that I can say that bleeding brakes was fun. Used the "Ford 3-Prong" cap, as above; looks like it would be easy enough to gin up a new cap with a fitting to fit any application, however. The device is very good quality and construction. I purchased mine for less than $60 shipped, from Apex Performance; that's less than the labor charge alone to have the system bled, either from a dealership or independent...wish I had got hold of one of these twenty years ago!
WRXRgr is offline   Reply With Quote
Old 09-05-2006, 05:23 PM   #7
DJ_Swammi
Member Sales Rating: (2)
Member#: 15004
2002 WRX Sedan
"Stock"
+1 Again, good things to say about the bleeder
- 1 Billion and an endless stream of curses for the universal adaptor.
The universal piece is absolutely worthless, stay with part number 1107 as mentioned above and you'll be loving life.
DJ_Swammi is offline   Reply With Quote
Old 09-05-2006, 08:09 PM   #8
racekar
Member Sales Rating: (5)
Member#: 107988
i use the ford 3 prong adapter works great, its not that hard to get it on.. as for the oem cap and drilling a hole i dont think it will hodl the pressure tried it on other honda screw on caps. so i dont think that way will work.
i rather just do the ford adapter, it was easy to get it on my car on/off maybe you just have to get the right angle etc..
racekar is offline   Reply With Quote
Motive power bleeder cap DocWyte Brakes, Steering & Suspension 3 03-26-2009 08:29 PM
Motive power bleeder BIGSKYWRX Brakes, Steering & Suspension 18 06-09-2008 10:28 AM
Cheapest place to get Motive Power Bleeder? garface Brakes, Steering & Suspension 2 11-23-2006 09:08 PM
Can I flush my clutch fluid with a motive power bleeder? jet8300 Service & Maintenance 5 10-06-2006 05:04 PM
Help. Can't get brakes bled using motive power bleeder wadejg Brakes, Steering & Suspension 11 08-30-2004 02:33 AM
