Old 04-12-2011, 05:38 PM   #1
abehanna
Member#: 249152
2012 ForesterTouring
Super Silver
Default Maxwell Power Tuned: 06 WRX Blouch 18GXT 8cm
First off, just wanted to say thanks to Dom and the guys at Maxwell Power. Needless to say you were super helpful throughout the upgrade process helping with my parts research all the way up to the tune... The car feels great! Also need to give major thanks to my buddy Trevor (Red02) for his help and knowledge with all of the installs! I wanted to post these results to help people get a feel for what you can do with the stock injectors... Obviously I was limited by the injectors with this setup but i didnt want to go much beyond 300WHP for safety reasons... 362tq is a little scary but will just be an excuse to build a motor and upgrade the tranny down the road.
Event: Dyno Pull
Ambient Temp: 58.7F
Elevation: 100ft ASL
Weather: N/A
Tires:SS595 215/50ZR17
Car: 2006 WRX
Tuner: Dom
Dyno Info: Dynocom AWD
Transmission: Stock 5 Speed, stock clutch
Peak HP at RPM: 332.6 @ 5750 RPM
Peak Torque at RPM: 362.9 @ 3600 RPM
Baseline hp/tq for a stock on same dyno: Unknown (Dom help me out here!)
Target Boost: 16PSI
Target AFR: Unknown
Fuel: 92 pump gas
Power Mods
Blouch 18GXT 8cm hotside
06 USDM STi TMIC
Grimmspeed EBCS / MBC Hybrid Boost control
Perrin V2 2.4" Inlet
Invidia catless V2 DP
Borla Hush Catback
Walbro 255lph
Suspension Mods:
Coming soon...
Uploaded with ImageShack.us
abehanna is offline   Reply With Quote
Old 04-12-2011, 07:26 PM   #2
subiegirl151
Member#: 279705
09 WRX
Default Awesome.
Thats some great power, keep it up!
subiegirl151 is offline   Reply With Quote
Old 04-12-2011, 07:31 PM   #3
moosecakes
Member#: 136098
07 35r WRX
Maxwell Power
HolyInstantPowerBatman!!!
Must be a blast to drive.
moosecakes is online now   Reply With Quote
Old 04-12-2011, 08:04 PM   #4
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Looks like a fun ride. Deff some nice lowend midrange grunt.
rexworx is offline   Reply With Quote
Old 04-12-2011, 09:12 PM   #5
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
very quick spool and nice #s on 16psi. nice to see what can be done on the stock injectors, but im sure its begging for more!
wrxtremeWGN is online now   Reply With Quote
Old 04-12-2011, 09:32 PM   #6
Seventh
Member#: 263223
2011 WRX 5dr
SWP, 332ti
That torque curve is phenomenal.
Seventh is offline   Reply With Quote
Old 04-12-2011, 09:50 PM   #7
abehanna
Member#: 249152
Super Silver
Thanks for the good comments so far!
332whp @ 16psi is one of the great things about this turbo (things to think about when comparing this to the HTA68)... Dominic thinks it will be good for somewhere around 50 more hp with injectors .
Old 04-12-2011, 10:16 PM   #8
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
Trust in Dom !
cindergarden is offline   Reply With Quote
Old 04-13-2011, 08:08 AM   #9
JRizzy24
Member#: 215468
2013 STi
Crystal Black Silica
I have a very similar set up to you, running very similar #'s...I too had the tune kept safe/reliable until I can save for a new tranny...then retune!
Congrats, it's a fun ride isn't it?
JRizzy24 is offline   Reply With Quote
Old 04-13-2011, 10:18 AM   #10
Loubaru
Member#: 155489
07 STi
Great numbers and torque curve, looks like that boost hits right hard/fast. Once my turbo finally ****s out this is one that I was looking at upgrading to. Are you having any issues with boost creep?
Loubaru is offline   Reply With Quote
Old 04-13-2011, 10:41 AM   #11
abehanna
Member#: 249152
Super Silver
Nope... That's the great thing about the hybrid setup; the MBC controls your peak boost...
Old 04-13-2011, 11:50 AM   #12
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Great looking curves! Looks like a really solid tune
Does this dyno read higher than a Dynojet? 332whp is already impressive, almost hard to swallow when considering stock injectors, exhaust manifold and stock STi TMIC. Another 50whp with larger injectors would make this 18G produce 30R numbers.
Steve.804 is offline   Reply With Quote
Old 04-13-2011, 12:21 PM   #13
abehanna
Member#: 249152
Super Silver
Yeah it was higher than i expected too... Not really sure about the dynocom i would have to see stock run comparisons between different dynos. MPS guys were guessing the guy after me with an STi with the typical stage 2 DP/catback to get about 325WHP if that helps. I didnt stay long enough to see the results, but that seemed to be the normal number on that dyno for a stage 2 STi with a vf48
Maybe the guys at MPS can enlighten us...
Old 04-13-2011, 07:25 PM   #14
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
if your talking about the guy with the sti hatch, the new one with the super loud gymkana exhaust he made 340 wheel with just cai and turbo back.
NW2TONE is offline   Reply With Quote
Old 04-13-2011, 07:36 PM   #15
NW2TONE
Member#: 212509
your **** go faster
For reference, bone stock STi on the bone stock tune makes 235 (04-06)-245whp (08+). The 2011 STi's are freaky because they'll break 300whp bone stock with a good tune. 08-2010 won't break 300 without a CAI and TBE.
One reason our room produces higher numbers is because we actually have a ventilation system and supplies the engine with fresh air that's not loaded with carbon monoxide. We have a dyno cell with big fans that keep pressure on the front of the car for superior cooling. This provides a tuning environment that is closer to what the car will experience on the street. Most shops have their dynos in a big open shop with some fans sitting in front. Some have almost no ventilation whatsoever. Heat soak is a smaller factor in our dyno cell compared to other dynos. This means our runs are more repeatable, more accurate and the tunes are more precise.
But really, why bitch about numbers? Just compare other cars on our dyno if you want to do comparisons. For reference, we typically get numbers lower than a dynojet and higher than a mustang.
My RS ran 11.4's at BOTI with a slipping clutch and bad launches on street tires at 470whp.
Abe is happy with his tune, that's all that matters to me.
-Dominic Acia
MPS
Old 04-13-2011, 07:53 PM   #16
abehanna
Member#: 249152
Super Silver
Haha yeah that thing was crazy loud!!!
You are certainly right about the hp numbers too... I could care less as long as its fun to drive
Old 04-14-2011, 04:06 PM   #17
roccer
Member#: 113674
2006 WRX Limited
WRB, 358whp/387wtq
these results make me very happy as your goals/parts are very similar to my planned setup (same turbo, stock injectors, etc). congrats and enjoy!
roccer is offline   Reply With Quote
Old 04-14-2011, 04:30 PM   #18
lk86fire
Member#: 270572
2008 WRX
Wow.
I think you just found my turbo for me.
what are the specs, is it a td05 or td06?
lk86fire is offline   Reply With Quote
Old 04-14-2011, 05:27 PM   #19
roccer
Member#: 113674
2006 WRX Limited
WRB, 358whp/387wtq
Originally Posted by lk86fire View Post
Wow.
TD05H
Old 04-14-2011, 07:58 PM   #20
abehanna
Member#: 249152
Super Silver
^^^ Correct its the TD05 turbine wheel with the new billet awesomeness compressor wheel...
Old 04-14-2011, 08:35 PM   #21
roccer
Member#: 113674
2006 WRX Limited
WRB, 358whp/387wtq
is this car your daily driver btw? mine is and will continue to be so im just also gauging stability/reliability
Old 04-14-2011, 08:39 PM   #22
abehanna
Member#: 249152
Super Silver
Yup sure is... Reliability is all in the way you drive it but i also have enough in the bank for a motor right now and a second car (forester) in case something happens.
Old 04-14-2011, 08:52 PM   #23
roccer
Member#: 113674
2006 WRX Limited
WRB, 358whp/387wtq
cool. yeah i drive relatively conservatively and never launch. i guess i personally am more concerned about the transmission going before the engine. that said, im planning to start saving for PPGs down the road since at those power levels im factoring its a matter of when rather than the if regarding possible gear failure (even if it doesnt fail, doesnt hurt to be ready incase). but as ive said, your setup, results and overall info are making me very confident/impatient to get all my parts bought installed and tuned for
Old 04-14-2011, 09:01 PM   #24
moosecakes
Member#: 136098
07 35r WRX
Maxwell Power
Take your time shifting, don't launch, don't slam the gears, change the fluid regularly and it will last. I was running my gt35r (on WG pressure only) and before that a 20g with a pretty strong tune and my gearbox was just as good as the day I bought the car. Eventually I got a 6sp and turned the boost up, but the stock transmission will live long enough for you to save up for a new one if you treat it right.
Old 04-15-2011, 07:08 AM   #25
JRizzy24
Member#: 215468
2013 STi
Saving up for PPG right now, but the stock tranny is so-far-so-good
from vf39 to blouch 18gxt alphaomega0 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 41 06-28-2012 03:45 PM
Blouch 18gXT housing size Whoa!ShutItDown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 04-28-2011 02:20 PM
06 WRX Blouch EVO 3 w/ 8cm vs TD05-18G XT which one? konmann Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 06-14-2010 12:39 PM
Precision Tuned: 06 WRX FP 20G/93oct... 361/392TQ JMS77 Proven Power Bragging 33 02-05-2008 09:43 PM
