Old 05-18-2011, 03:15 PM   #26
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
I'm thinking about this turbo although that spool curve is way quicker than any other 18g-xt I've seen and with the 8cm2 housing?
Do you think the 3port EBC/MBC hybrid setup helps with that? It's almost like EWG numbers.
If so, please let me know how you have your boost control setup, is it just like the hybrid setup explained in the sticky?
Incredible stuff!
BrandonDrums is offline   Reply With Quote
Old 05-18-2011, 03:33 PM   #27
rallyracersti
Member#: 147522
2015 wrx
Wrb
with numbers like these,im reconsidering buying a 20g xt and fmic.im stage 2 now with the stock cobb flash.i want more and found a great dea lon the above items.if i could save money and just buy a turbo i'd do just that. nice numbers.
rallyracersti is offline   Reply With Quote
Old 05-18-2011, 03:42 PM   #28
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
^^^Keep in mind that the actual HP numbers are a little high since this Dyno tends to read a bit high. However, you can't fake that curve.
From what I can tell from the thread, this car is making around 310 whp as most awd dyno's would read (at least the ones we have locally). I could care less about the number being inflated or deflated, I'm just crazy about that there torque curve! For me, anything over 300 whp with spool below 3.5k is a winner.
I really would wait to get feedback on his boost control setup first though. I think there's some awesomeness to learn from there.
Old 05-18-2011, 10:56 PM   #29
abehanna
Member#: 249152
2012 ForesterTouring
Super Silver
The quick spool is likely a combination of an awesome tune, the GrimmSpeed EBCS being a high quality solenoid / run intercept style, and also just the new billet wheel spooling a bit faster than the older wheels... The manual controller in my hybrid setup shouldn't have any effect on spool as it is simply staying shut until there is a need for it to open if there is a boost spike beyond what the EBCS is controlling.
Cant wait to get some injectors and see what this turbo can put out. Just waiting to save enough to build my 5 speed FTW!
abehanna is offline   Reply With Quote
Old 05-19-2011, 12:21 AM   #30
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
we use a manual inbetween the turbo and wastegate and put Ts in the lines and run those to the elec and cap off the 3rd port.
cant wait to get my 20gxt on my girls fxt.
NW2TONE is offline   Reply With Quote
Old 05-19-2011, 05:11 PM   #31
roccer
Member#: 113674
2006 WRX Limited
WRB, 358whp/387wtq
i should be able to give ya numbers with upgraded injectors (93 pump gas) after next tuesday i picked up some 750ccs and those along with the turbo and grimmspeed ebcs are going on sunday/monday. ill be sure to post results after the tune tuesday night (Tune will be on TurboXS's dynapak dyno.).
downside: temps expected to be in the 80s on that day & my tune isnt till the late afternoon/early evening.
roccer is offline   Reply With Quote
Old 05-19-2011, 05:21 PM   #32
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
Well the 3 port still can't run 100% wgdc, it's fast response so you can get more stable boost control with more agressive turbo dynamics tables but it still doesn't allow you to get the waste gate 100% closed when you're spooling.
However, You CAN run 100% wgdc with the hybrid manual boost controller. Basically you max out the wastegate duty during wot in the low rev-ranges basically making the system run 100% on the manual controller set for max boost. For everything else you tune as if it's a 3 port.
That's at least what I can tell from reading that sticky on the hybrid boost setup. Am I misunderstanding something? I tuned my own boost with my 3 port and it's a trade off between fast spool and stable boost, I don't think a Grimspeed alone would allow you to spool an 18G of any type under 3500rpm. If I'm wrong I'd looooove to know what your turbo dynamics tables look like!
And as I said before, ragardless of my above mess, I'm going to be getting the 18g-xt!!
Old 05-19-2011, 06:14 PM   #33
abehanna
Member#: 249152
Super Silver
You're better off talking to Dom at Maxwell Power. I have no experience tuning my own duty cycles so i have fairly limited knowledge. My understanding is that 100% WGDC with intercept means the wastegate is seeing full boost pressure = no spool? Maybe someone else can chime in here?
I had about 2 hours of sleep the night before my tune so i was kind of brain dead at the time and didn't get to learn as much as i would have liked during the tuning session.
Old 05-19-2011, 10:19 PM   #34
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
Just the opposite I believe, you have to set a Max Wastegate Duty Cycle because it's a safety net for preventing overboost. I had to 0 out my wgdc for break-in on my new engine, my turbo only spooled to WGA pressure since 0% of the compressor nipple pressure was being diverted away from the waste gate actuator (WGA) aka 100% of the boost pressure gets to the WGA.
The flip-side being 100% WGDC means 100% of the pressure is being diverted from the WGA AKA 0% of the boost gets to the actuator.. I guess it's like a train which has pneumatic air-brakes. Energy has to be applied to the system to turn the brakes off, that way if the compressor fails the train stops rather than becomes a runaway. For our Boost-Control systems, energy has to be applied to allow the turbo to see exhaust energy, if the system fails the turbo reaches only Waste-gate pressure thus preserving the turbo and engine and allowing the car to be safely driven to rest.
However, with your hybrid setup, you can set initial off-idle wastegate duty cycle extremely high allowing the Wastegate to stay nearly completely shut since the manual boost controller's valve will only begin diverting pressure to the WGA when it reaches target (a good one will, others will leak a bit along the way).
I've been researching all day so that's the best I understand the situation. I'm no expert though. However, whatever the mojo is you have going on I want to know, it's a hell of a lot easier to buy a couple t-fittings and a MBC than to do a EWG setup IMO. This is the first real proof of application I've seen honestly. I'm enthralled.
Any word DOM?
Old 05-22-2011, 02:26 AM   #35
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
higher WGDC = WG shut more = more air through turbine = higher boost
When i run these i simply run 95% in the intial and max wgdc maps at all times. Turbo dynamics become irrelevant.
The ebcs doesnt do anything in the hybrid setup until you overboost....well thats the way most people utilize it (95-100% wgdc at all times = mbc is in control). You could lower the wgdc to prevent partial throttle full boost on smaller turbos.....and you can use it to taper boost at high rpm...well theoretically anyway...i have never personally tried that.
Even though the mbc is controlling boost the WGDC will start pulling if your target boost table doesnt match what the MBC is hitting.
Otherwise the EBCS doesnt do much unless you go into limp mode and your wgdc goes to 0....then the ebcs "opens" and the mbc is bypassed.
Old 05-22-2011, 11:55 AM   #36
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
Makes perfect sense, thanks for the info!!
I'm ordering a MBC today...Hopefully I can get some tuning time in this week.
Old 05-24-2011, 01:44 PM   #37
abehanna
Member#: 249152
Super Silver
Thanks for clearing that up Phatron!
Old 06-09-2011, 02:40 PM   #38
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
Sorry to re-open this, but with the 8cm^2 housing, does the 18gxt self-scale it's boost so to speak at partial throttle?
I wonder what the partial throttle boost numbers and power delivery looks like. I'm really having a hard time deciding on a 7cm or 8cm housing for my turbo. Either way I'm running a hybrid boost control setup.
Old 06-09-2011, 02:54 PM   #39
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
If running hybrid boost control, you can tune partial throttle boost lower than it's threshold if you like (no lower than wastegate spring, of course). Like at 20% throttle you can set WGDC to 5% (essentially wastegate spring), then ramp up to 95% WGDC at 50% throttle (now you're on the Manual ball + spring boost controller). You pretty much don't cruise above 50% throttle, so this works out well for controlling part throttle boost.
I drive up a hill on the way to work every day, and if I used cruise control in 5th, my TD04 would push up to 8-9psi (wastegate boost). Once I swapped to an FP 18g / 7cm, it dropped to around 5psi. More flow at lower boost. You will not have the same issue with part throttle boost with a larger turbo.
Regardless, there's no reason to cruise up that hill in 5th. I get better fuel economy by downshifting to 4th to go up that hill, and then the boost required to maintain speed drops even more.
Downshift like you should and you never have to worry about part throttle high boost.
Concillian is offline   Reply With Quote
Old 06-09-2011, 02:58 PM   #40
Nuke209
Member#: 108089
2003 WRX
NF Performance
I like!
Nuke209 is offline   Reply With Quote
Old 07-12-2011, 12:46 PM   #41
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
Very nice. I made 359.6whp and 350whtq on a low reading mustang 1100 w this Turbo w a 7cm exhaust. Excellent spool characteristics and 4th gear is rediculous.
boostmasterflex is offline   Reply With Quote
Old 07-12-2011, 05:57 PM   #42
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
I guess I no longer need a Dom 1.0XT-R (or 20G-XT-R), Topspeed dynoed the Dom 1.0 at 250wtq / 3,250rpm (20psi), your beast (understood is a different dyno) 325wtq / 3250rpm (16psi), wow. Even after subtracting differences in dyno the 75wtq difference is significant, especially considering you are running stock injectors and TMIC and only tuned at 16psi.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 07-12-2011, 08:54 PM   #43
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
Originally Posted by V8 GTFO Lesbic WGN View Post
... only tuned at 16psi.
16psi @ redline, maybe. Look at the graph, peak boost is closer to 18.5psi or so by my eye.
LatentWagen is offline   Reply With Quote
Old 07-13-2011, 10:51 AM   #44
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
oh yeah it says 17.8psi at the bottom left corner of the plot
Old 07-13-2011, 11:24 AM   #45
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
Are you using a hybrid boost control setup as well?
Old 07-14-2011, 03:11 PM   #46
jesse bear
Member#: 233450
2004 forester XT
Hey not meaning to thread jack but is there any way you could throw a picture up of the location where you put the mbc on th line so we get a solid idea where we'll need to put ours?
Thanks!
-Jesse
jesse bear is offline   Reply With Quote
Old 07-14-2011, 03:38 PM   #47
Phatron
Member#: 36033
CEO PhatBottiTuning
Old 07-14-2011, 04:25 PM   #48
boostmasterflex
Member#: 237447
2002 Impreza WRX
WR Blue
I am using grimspeed 3port bcs, opensource tuned w Tial 38mm wastegate
Old 08-31-2011, 09:59 AM   #49
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
I still can't get over how awesome that torque band is. I'm still saving for an 18g!
Old 08-31-2011, 09:11 PM   #50
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Can't wait for the upcoming 18G-XT-RRRRRRR
from vf39 to blouch 18gxt alphaomega0 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 41 06-28-2012 03:45 PM
Blouch 18gXT housing size Whoa!ShutItDown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 04-28-2011 02:20 PM
06 WRX Blouch EVO 3 w/ 8cm vs TD05-18G XT which one? konmann Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 06-14-2010 12:39 PM
Precision Tuned: 06 WRX FP 20G/93oct... 361/392TQ JMS77 Proven Power Bragging 33 02-05-2008 09:43 PM
