Old 11-26-2013, 12:02 PM   #1
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Default Are all fuel filters equal?
Hey guys,
I replaced my in tank filter with one that goes in the engine bay. I was just wondering if most filters are the same, or if I need to order a high performance filter due to the amount and pressure of fuel passing through the system.
Thanks !
BeastianSTI is offline   Reply With Quote
Old 11-26-2013, 01:45 PM   #2
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
How did you do that?
Bacon117 is offline   Reply With Quote
Old 11-26-2013, 02:06 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Not to hate but.....this is such an inane topic that it has been researched by zero people and even if there was a difference, the amount of delta between filters could not be a factor of causation between MPG, HP, or reliability factors.
Cliff Notes: stahp
Old 11-26-2013, 02:25 PM   #4
BeastianSTI
Member#: 310506
2005 WRX STi
I didn't mean it as a "what oil is best" kind of situation, but literally...
If I go and buy a 5$ fuel filter from Advanced Autoparts, could it potentially restrict the flow of fuel, which consequently could cause performance issues? That's the real question. I'm having issues with a fuel pressure gauge reading crazy numbers after the sender was installed for a week or so. The sender is good, so i'm wondering if the fuel filter is clogged.
I didn't want to buy another fuel filter while still potentially uninformed.
Old 11-26-2013, 02:47 PM   #5
181stLeader
Member#: 184183
1995 Impreza RSTi
Ver.8 EJ207 Bright Blue
When I did my swap on my GC I did the same thing(stock the GC has an engine bay filter, and the 06 sti gas tank I installed had the tank filter. I didnt want two fuel filters so I gutted the in tank filter(the two halves unscrew then the filter media can be removed). Then I replaced the engine bay filter with a new one.
181stLeader is offline   Reply With Quote
Old 11-26-2013, 02:51 PM   #6
BeastianSTI
Member#: 310506
2005 WRX STi
Yup yup! ^
Old 11-26-2013, 04:07 PM   #7
supafastR
Member#: 161335
My guess is, outside of a potential quality issue, they're all basically the same. Fuel is pretty clean to start with, unlike an engine oil filter where it is much more imperative for engine life to get a quality filter if you plan to go more than 3-5k oil changes...
supafastR is offline   Reply With Quote
Old 11-26-2013, 07:03 PM   #8
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
If you are buying a $5 filter to troubleshoot an apparent issue, there is not need to ask about detrimental affects as you shouldn't be wailing on your car whilst troubleshooting. Having a new filter in your car should be one step in the troubleshooting procedure that will bear fruit within .000035 seconds of installation. And one cannot make an internet determination on failure without knowing more facts...you've started to ask a question backwards as you have a wonky fuel pressure gauge problem....start there and work your questions back to the problem rather than trying to lead us forward to your projected solution. Your troubleshooting is assbackwards.
Old 11-26-2013, 08:14 PM   #9
BeastianSTI
Member#: 310506
2005 WRX STi
Right. I've actually got another post for that issue in a different section of the forum. Ya really don't know where I'm at in my troubleshooting process. All I needed to know is if there are specific fuel filters for performance cars. It was suggested that a clogged filter could be clogging up my injectors and fp sensor. Nobody said I'm wailing on the car while troubleshooting lol...
You're just as bad as uncle Scotty.
Old 11-26-2013, 08:19 PM   #10
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Nice, good luck to you.
Old 11-26-2013, 09:45 PM   #11
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 11-27-2013, 07:04 AM   #12
vicious_fishes
Member#: 158864
2003 SOHC destroker
in answer to your question OP: they're basically all the same/the differences are trivial and won't effect performance.
/thread.
vicious_fishes is online now   Reply With Quote
Old 11-27-2013, 08:11 AM   #13
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
http://www.google.com/gbproducts/...FeU5Qgodc3YAmg
what makes you think you or your filter is special
