Old 07-18-2002, 10:33 AM   #1
dead-eye
Member#: 43
1999 2.5RS no T
RBP
Default Exhaust header with only 2 bolts; what are the dangers?
I was trying to install the STi engine mounts and in the process of re-installing the nuts to the exhaust headers, one of the nuts got stuck. I assumed I had started to cross thread it so as I tried to remove it, the entire stud and nut assembly came off. I couldn't force the nut off for fear of damaging the stud so I attached the exhaust header with only 2 nuts instead of 3. How long can I drive like this (I'm waiting for replacement parts)? What are the dangers in driving the car in this condition? Any help would be GREATLY appreciated.
dead-eye is offline   Reply With Quote
Old 07-18-2002, 12:32 PM   #2
STiTuner
Member#: 5778
09 135i
Jet Black
I doubt you'll warp anything if its just fro a few days.
you'll probably get a pretty nice leak. just make sure your gaskets are in good.
Brad
STiTuner is offline   Reply With Quote
Old 07-18-2002, 01:44 PM   #3
dead-eye
Member#: 43
1999 2.5RS no T
RBP
Brad,
Thanks for the info. The gaskets looked like they were in good shape. Would there be any noticeable loss in boost due to the leakage? I've been keeping an eye on my boost gauge and haven't noticed anything yet.
Old 07-18-2002, 02:12 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
exhaust leak, which if it gets bad enough will burn a valve.
jeremy
Old 07-18-2002, 03:32 PM   #5
Surboo
Member#: 8721
1999 2.5 RS
Rally Blue
I drove my car like that for a good 10,000 miles before i found it. I knew i had an exhaust leak somewhere because it was horribly loud, but i couldnt find where it was. Even the Subaru shop around here said they looked for it and couldnt find it... I finally noticed a missing nut when i was working under there. Hmm, what are the symptoms of a burned valve??
Surboo is offline   Reply With Quote
Old 07-18-2002, 04:14 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Why don't you get a bolt that fits in there? Make sure it's grade 10.9.
Old 07-18-2002, 05:07 PM   #7
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Why not just screw the stud back in, nut and all?
blaster88 is offline   Reply With Quote
Old 07-18-2002, 05:57 PM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
blaster - I think it wouldn't seal it cause the nut is locked on the stud at one place.
Old 07-18-2002, 06:26 PM   #9
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
If you screw it back in, if the stud bottoms out, then the nut should start screwing back down.
Old 07-18-2002, 07:07 PM   #10
dead-eye
Member#: 43
1999 2.5RS no T
RBP
blaster88,
That's exactly what I thought but when I tried it there was this awfully screeching noise; I stopped after a few seconds because I thought I might strip the threads. I'm going to Pepboys tonight to see if they have a comparable stud.
2.0L or 2.5L what are the ups and downs thewannab2002 Newbies & FAQs 28 05-27-2010 12:18 AM
2001 2.5RS what are the widest tires on a stock body? LunaticDriver Normally Aspirated Powertrain 7 09-10-2005 02:47 PM
What are the dangers of high oil temps? root Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 01-02-2005 03:30 PM
thinkin about a 2.5rs...what are the prices on some 02,03 and 04's?? btn_turtle Alaskan Impreza Club Forum -- AKIC 46 11-17-2004 04:37 AM
What are the dangers of lowering the car with Ground Controls? WRXTACY Brakes, Steering & Suspension 0 05-04-2002 05:24 PM
