Old 04-13-2011, 08:49 AM   #1
orangeman510
Member#: 275892
2004 Subaru
Black Java Pearl
Default 04-05 WRX/STI Grill Pillar Delete Tutorial
Hello, I went ahead and made another tutorial for a popular mod. It's the emblem pillar delete from your grill. This is a very easy mod, just take your time. You'll need patience, the more time you put into something the better it'll show in quality.
Tools you need include: Dremel(OPT), Hack Saw (I found is the best way to cut it), Long #2 Flat Head Screwdriver, File, Sand Paper (180,320,400grit), Bondo Body Filler w/ Hardener (OPT)
Paint: I chose VHT Black Wrinkle Paint.
1 by orangeman510, on Flickr
2 by orangeman510, on Flickr
3 by orangeman510, on Flickr
4 by orangeman510, on Flickr
DSC00718 by orangeman510, on Flickr
Go ahead and remove the grill. If you need help check out my tutorial on blacked out headlights. This step is super easy
DSC00700 by orangeman510, on Flickr
DSC00701 by orangeman510, on Flickr
orangeman510 is offline   Reply With Quote
Old 04-13-2011, 08:49 AM   #2
orangeman510
Member#: 275892
2004 Subaru
Black Java Pearl
Now with your Flat Head gently pry up on four retaining clips that hold the mesh insert in. Use your needle nose to assist if necessary. It should look like this when your done.
DSC00702 by orangeman510, on Flickr
Now that you've taken the clips off go ahead and remove the mesh insert. This will take a little finagling but you'll get it. This is what you want.
DSC00705 by orangeman510, on Flickr
DSC00703 by orangeman510, on Flickr
So far so good. Now take your hack saw or dremel and cut off the emblem pillar. Don't try to cut to close to the bottom or top of the pillar you'll run the risk of cutting the actual grill. Hints why we have a file. :roll: You should have a similar result.
DSC00710 by orangeman510, on Flickr
DSC00711 by orangeman510, on Flickr
Old 04-13-2011, 08:51 AM   #3
orangeman510
Member#: 275892
2004 Subaru
Black Java Pearl
Here's the fun part, take your file and goto town. Use a deep grooved knurl file first to eat it away fast then use a finer one to get it close.
DSC00714 by orangeman510, on Flickr
DSC00716 by orangeman510, on Flickr
DSC00715 by orangeman510, on Flickr
Old 04-13-2011, 08:52 AM   #4
orangeman510
Member#: 275892
2004 Subaru
Black Java Pearl
Not so hard see!!! This part truly is optional folks. I'm not a body person nor have I been doing work like this for years I'm 20. This part is easy and worth it so try it out. Get some body filler and hardener read the mixing instruction (for a golf ball size of filler use a 1/4" line of hardener) Mix till it's a consistent color, for me it was a bubble gum color. Rough the area around the filing and apply filler. Should look like this or better.
DSC00717 by orangeman510, on Flickr
Do the same to the top if you wish, you don't have to. It's not like someone is going to lay down and look up at it.
Sand it down take your time to get it as smooth as possible. The Wrinkle Coat is very forgiving so you don't have to get OCD about it. Like this is perfect
DSC00720 by orangeman510, on Flickr
Easy Peezy!!!! Okay now here's the time consuming part. They're 2 ways to do this. One way will save you time if you have the luxory. The other way takes awhile. Again paint is your choice. If you decide to do wrinkle here it goes. Spray Wrinkle coat as directed on the back of the can. 3 Coats (Vertically, Horizontally, and Diagonally) with 3 minutes between each coat. Once you get a solid look leave it alone!!!!!! This stuff takes forever to dry. It takes 2 hours to setup and 24 hours to cure/dry. But there is a way to cheat this if you have an oven large enough to house this grill. Set the oven to 200F and set it in there for an hour on a cookie sheet. The end result is sick. It's dry and the wrinkles are much tighter and more uniform. If you can BAKE IT!
DSC00722 by orangeman510, on Flickr
DSC00721 by orangeman510, on Flickr
Now it's finished install and enjoy guys :spin:
DSC00723 by orangeman510, on Flickr
Old 04-13-2011, 09:20 AM   #5
outlaw_inferno
Member#: 265519
2005 RS Wagon
That looks awesome. Great writeup mate.
outlaw_inferno is offline   Reply With Quote
Old 04-13-2011, 04:04 PM   #6
gunk100
Member#: 224810
05 WRX
Looks good
gunk100 is offline   Reply With Quote
Old 08-26-2011, 12:28 PM   #7
djtoone
Member#: 285097
2004 WRX
Java Black Pearl
Excellent step-by-step directions and pics. Exactly what I am looking to do. Thanks!
djtoone is offline   Reply With Quote
Old 08-26-2011, 02:25 PM   #8
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
Good job!! Looks nice and neat.
scooby_wooby is offline   Reply With Quote
Old 05-02-2012, 05:13 PM   #9
allison_scout
Member#: 318758
2004 Impreza 2.5RS
Java Black Pearl
Anyone have after pix without the bondo?
allison_scout is offline   Reply With Quote
Old 05-02-2012, 06:20 PM   #10
05subysti
Member#: 268190
2005 STi
hmm the plastic grill wont melt? ive always wanted to do this! +1 for vht paint
05subysti is offline   Reply With Quote
Old 05-03-2012, 06:34 AM   #11
SubieMonte
Member#: 264803
2005 WRX Wagon
Very nice. Been wanting to do this for a long time. I'm not a body shop guy either. So the hardener is optional? How does the filler stay in place when it's drying...do you need some type of backer? Excellent write up.
SubieMonte is offline   Reply With Quote
Old 05-11-2012, 04:07 PM   #12
djtoone
Member#: 285097
2004 WRX
Java Black Pearl
Has anybody done black grille paint on a JBP WRX? I have a textured grey, and might try some black... I’d like to see how it looks. Pics would be great, Thanks.
Old 05-20-2012, 07:37 PM   #13
SubieMonte
Member#: 264803
2005 WRX Wagon
I used black on my ODP and it looks great! I didnt do the pillar delete yet but do plan on it soon. I don't have any pics but it looks good. I don't know if I'd use grill paint though.
Old 05-20-2012, 07:43 PM   #14
djtoone
Member#: 285097
2004 WRX
Java Black Pearl
Thanks. I just sprayed mine black, directly over the textured grey from when I deleted the pillar. I did not sand it down far enough, so if you look closely, you can still see the base of the pillar. Someday I may fix that...
I like the all black look a lot better. Makes the red Hella Super Tones stand out really well.
Old 05-20-2012, 07:44 PM   #15
SubieMonte
Member#: 264803
2005 WRX Wagon
Thanks. I just sprayed mine black, directly over the textured grey from when I deleted the pillar. I will post a pic soon...
Just like mine will. Lol
Old 05-20-2012, 08:46 PM   #16
djtoone
Member#: 285097
2004 WRX
Java Black Pearl
Nevermind the rock chips and bugs...
Here is my pillarless grille, after spraying the textured grey to be black.
Old 07-19-2012, 07:07 PM   #17
the silver subie
Member#: 216662
05 STI
Thanks for the write up! I used it today
the silver subie is offline   Reply With Quote
Old 10-02-2012, 10:20 PM   #18
geo301
Member#: 293561
2005 Wrx Vf39ing
Thanks for the write up i am going to use it this weekend!
geo301 is offline   Reply With Quote
Old 12-06-2012, 09:06 PM   #19
PJH203
Member#: 325800
2004 Impreza WRX
JVP
great write up. My only concern when baking, make sure plastic doesnt loose shape. It melted at tad on one side so the clips didnt line up as well when reinstalling. I would just let it air dry.
PJH203 is offline   Reply With Quote
Old 08-25-2013, 08:07 PM   #20
krisr33
Member#: 361871
lol tried this DIY today and put it in the over for no longer than 20mins and it completely melted FML
krisr33 is offline   Reply With Quote
Old 08-26-2013, 11:02 PM   #21
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
You did it wrong then
danny_d19 is offline   Reply With Quote
Old 03-25-2015, 09:02 PM   #22
LESSthanDan
Member#: 358897
05' WRX Wagon
Thanks for the write up! I did mine yesterday and it looks awesome. Used Krylon texture black paint.
Untitled by daniel.stockard, on Flickr
LESSthanDan is offline   Reply With Quote
FS : 04-05 WRX/STi Rallitek License Delete JDMcarBoy91 Exterior/Styling 4 03-04-2011 05:35 PM
04-05 wrx sti grill raw323 SCIC Private Classifieds 20 08-20-2010 09:09 PM
WTB 04-05 wrx/sti grill Steve Dallas Private 'Wanted' Classifieds 0 04-11-2009 01:46 PM
NEED:04-05 wrx/Sti grill and 04-05 wrx A pillar Rwu00313 Private 'Wanted' Classifieds 6 09-24-2006 09:33 PM
WTB: 04-05 WRX / STi grills ninjaboy76 Private 'Wanted' Classifieds 0 11-18-2005 11:19 PM
