Old 07-18-2002, 11:26 AM   #1
Blitzer
Member#: 21495
2002 WRX Wagon
white
Default Boostmonkey vs. MBC: Nothing but the Truth!
Hi WRXXXers,
I have tried to get a concentrated picture from the forum about the Boostmonkey (Boost Monkey), but there is really no such thing.
OK, guys, the ones WHO HAVE ONE, please respond to this thread and let us know if this is really the "yellow of the egg" since it makes perfect sense how they prove NOT TO USE a MBC.
Real life questions:
1.) What are the disadvantages to use the Boostmonkey?
2.) Are dealers giving you a fit on warranty when they see it?
3.) Can you remove it easily before going to the dealer? (if so, how to install best?)
4.) Is your Rex's performance constant and where it should be?
5.) What boost pressures are you running day in and day out?
6.) Are you CONVINCED that the Boost Monkey is the right thing and the MBC is NOT THE WAY to go?
7.) What blew up so far on your Rex relating to higher boost?
Let's make this a valuable technical feddback thead with FACTS. It sure will help many fellows now and in the future.
Thanks,
Blitzer
"WRXXX; For Adults only."
Blitzer is offline   Reply With Quote
Old 07-18-2002, 11:49 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
cutting wires at ecu/silanoid(dam i can't spell today)..i have a turboxs pass through harness.. so i havn't cut my harness
perhaps they have course to, read the magnusson-moss act though
due to having connections at the silnoid and at the ecu there is two place to unhook it
yes ..
.95 bar
i like the cabin adjustability.. still havn't figured out where to mount it yet
nothing? .. not higher constant...
Old 07-18-2002, 11:50 AM   #3
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
Default Re: Boostmonkey vs. MBC: Nothing but the Truth!
Here's the best I can do - hope it helps -- these are IMHO!!!!!! READ MY .02c YMMV - and all those other acronyms
Originally posted by Blitzer
[b]
I don't like cutting or splicing of wires into my ECU. You have to cut and splice 1 wire to the boost solenoid. Yes it's very easy, but on a car with a 3 year warranty, I would rather not cut wires, but I weighed the decision and decided to anyway.
Have not (knocking on wood) had the need to get warranty servicve since installing.
I don't know how this would be possible - it depends on how stupid the tech is, I guess. It also depends on what you're taking the car to the dealer for. If you are getting an alignment, or an oil change, nobody is ever going to notice. If you're having electrical problems, only a blind tech on crack is not going to notice wire taps hanging off the ECU and a big cut in the boost solenoid wires -- I don't care if you do a real "stealth" install, if they need to look for things, somebody will eventually run across it. It depends on how badly the dealer wants to be a prick about it.
No, but it never was. Living on eastern PA, I saw temps last week in the low 70's with humidity in the 50's. Yesterday, it was 90+ with humidity in the 99's+ -- so last week, I was getting a nice 14.5-15.0psi consistently (with the monkey) but today and yesterday I get 13.5-14psi if I'm lucky. That's not the monkey's fault, just a "fault" with turbo cars and lousy weather
I don't have an EGT gauge or any other mods, and I'm a wuss, so I have mine set to engage at 90%+ throttle. The highest I've seen (without restrictor mod) has been 15.3psi and that was on a perfect night - cool + dry, and the car pulled HARD!!!! On partial throttle, I typically see between 5-7psi depending on engine speed/climate.
I did the research and the only thing I'm convinced about is that there is nobody that can prove (to me) one way or the other a solid conclusion. Person A would have you believe your engine is going to go into critical meltdown at the hint of 1600F -- Person B goes into a dissertation of how 1600F is no big deal for a short time, proper conditions, etc... Person C says 1600F is barely warm. You make the call. How will this effect engine longevity. *shrug* Dunno. Haven't had them long enough to find out. Somebody says for $15 you can build your own 2 part MBC that will take care of partial throttle EGTs - I dunno. I thought $120.00 was a fair price since I hated the "randomness" of boost prior to the monkey, thought it was an easy install, clean and simple, and had 2 blinky lights. Blinky lights are always good. Never had an MBC, but I did consider it. Don't have an EGT gauge and I would NEVER use an MBC without one, and I'm a little nervous without one now, but still monkeying anyway. Just my personal feelings.
(more knocking on wood) nothing so far, but I think Anna Kournikova is hot. (sorry - since i had nothing valuable to add, I figured I'd add something completely unrelated)
I think Dick Cheney is actually a robot. I don't know that for sure, but that's what I heard. I'm also the princess of Canada, but I can't back that up with paper work.
CirrusWRX is offline   Reply With Quote
Old 07-18-2002, 02:49 PM   #4
gotsol
Member#: 17346
08 Cayman S
gotsol is offline   Reply With Quote
Old 07-24-2002, 11:31 AM   #5
thejean
Member#: 17763
Default Re: Re: Boostmonkey vs. MBC: Nothing but the Truth!
Don't believe anything he says - I'm the princess of Canada and I do have the paperwork to back it up. I also work part-time as the Prime Minister to make ends meet and fund my WRX obsession.
JC
thejean is offline   Reply With Quote
Old 07-24-2002, 11:56 AM   #6
WRXPTY
Member#: 19015
2002 wrx impreza
white
Has anybody tried the boostmonkey with the Vishnu's Stage 0? pros vs cons. I ordered both and I'm a little concerned about the performance.
Appreciate your replys
WRXPTY is offline   Reply With Quote
I have nothing but the utmost respect for those deploying to overseas. Mud Pig Off-Topic 58 10-20-2009 04:05 PM
Nothing But The Best_Prodrive_KW_Ohlins-Brake Packages for All Budgets Gruppe-S Suspension/Brakes/Handling 19 02-11-2009 08:07 PM
Itís the Truth, but Not the Whole Truth (Class Action Suit Settlement CarFax) NYCshopper Non-Subaru News & Rumors 0 05-07-2007 09:19 AM
A Subaru vs. A Hurricane, but the Hurricane is named Subaru... Celly South East Region Forum 5 10-20-2005 10:21 PM
Nothing but the Unichip MyRuRex Engine Management & Tuning 3 02-13-2003 09:18 AM
