![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#26 |
Member#: 252790
Vehicle:06 WRX TR WRB |
Nothing real crazy here...
2006 WRX TR Lifted with: -04 STi OE springs -06 WRX Struts(soon to be replaced with D-Specs) -STi Hats -Jackson Rally Strut Top Spacers, 1" -OBX Adj. Trailing Arms and Lats(still in a box in the garage) -Custom RSB mount/spacer -Custom adjustable FSB endlinks(next week or so) -205/60/16 Winterforces -Sport Edition CD 16's 7.5" wide, 48 offset Other Crap: -Ported VF43 -EBay TMIC -Samco hoses/inlet -Grimmspeed Upipe -44mm EWG -Grimmspeed BCS -HKS DP -Cutom Catback -Walboro FP -SPT Clutch/flywheel -Kartboy shifter/Knob -ProCar Seats -Cage, hydro handbrake, R180, and 6spd swap in progress -Co driver wiper/washer controls -DRT Components Flaps Underbody: -Primitive Front Skidplate, 1/8" with "stinger tail" -Primitive Uparmored Mini Rear Diff guard, 1/4" Total thickness Lights/lightbar: Hella 500 foglights on custom light bar, 5k HIDs ![]() ![]() ![]() RSB bracket spacers(not pretty, but they work. I may make a better looking set when I can TIG them): ![]() ![]() ![]() ![]()
#27 | ||||
Member#: 118141
Vehicle:95 'lifted' legacy |
Putting 2nd gen Fozzie strut assemblies on a legacy "L" would push it up like 3-4 inches, thus higher than the warned 2" > stock... That's when you should consider all the other drive line dropping stuff, which you've given great photos of in here. Quote:
good compilation!! |
#28 |
Member#: 236081
RMIC
Vehicle:2001 Outback |
Any outback gurus that can help with a 2001 Outback lift?
#29 |
Member#: 118141
check here... http://www.subaruoutback.org/forums/...ack-wagon.html
but in short, King springs from Australia, but they're spendy, strut spacer like Subtle solutions (http://www.subtle-solutions.com/prod...roducts_id=140) or jackson rally (http://www.jacksonrally.com/?page_id=17), or Baja springs in your OB struts... I hope that helps or gives you direction. . . |
#30 | |
Member#: 190502
International
Vehicle:2005 VF36 WRX |
I also have about 180lbs weight reduction which has lifted my car ~8mm. ![]() |
#31 |
Member#: 130346
the '06-'07 has an issue with the height and length of the front bumper. A few of the guys over at dirty impreza trim the bottom of the bumper off. Previous generation imprezas have a little more approach clearance. That built in lip tends to get folded over a lot.
#32 |
Member#: 181375
Vehicle:2010 Impreza 2.5i |
Nice information, just bought a 2010 impreza 2.5i hatch
#33 | |
Member#: 252790
FWIW, the only interior pieces in the car in those pics is the dash, part of the center counsel, and the Drivers seat. Diggin the wheels btw! |
#34 |
Member#: 147776
NWIC
Vehicle:'02 Impreza WRX '85 Toyota Corolla |
Is that 1/4" spacers front and rear?
#35 |
Member#: 112278
Vehicle:2003 Sonic wrx wagon 2005 blue "wrx" Wagon |
I went the cheap route before realizing all of what would be affected.....
Used my KYB AGX wrx struts and switched from Prodrive lowering springs back to stock wrx springs, talked Shane at Paranoid fabrications into making 1" versions of their spacers. 215/75r15 tires on Team Dynamics 15" ProRally wheels (stripped and repainted a nice metallic burnt copper...looks 10x better in person than what I can get in the pics) ![]() ![]() This thread has some great info in it though, answers to all the problems I've come across (rsb, cv joints, back tires just barely clearing the front of the wheel well, etc) Thanks for all the info! |
#36 |
Member#: 190502
International
#37 |
Member#: 163162
RMIC
Vehicle:2006 WRX wagon WR Blue |
So, for all you guys with the serious lifts (e.g. Forester suspension), have you had to replace your stock flexible brake lines? Are they too short at full droop?
#38 |
Member#: 153751
South East
Vehicle:2002 Mazda Miata The Darkness |
very cool guys, I'd love to take the suby into the wilderness one day, but for now she is a street bitch
#39 |
Member#: 118141
#40 |
Member#: 152042
NWIC
Vehicle:2002 WRX WRB |
Hey that's my tire pic. The stock tire was a 205/60-16 IIRC.
#41 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
#42 |
Member#: 163162
RMIC
words
#43 |
Member#: 163162
RMIC
words
#44 |
Member#: 276027
Vehicle:1997 Impreza Mystic Blue |
Ok, so say I get the 215/65r16 grabbers obviously I'll need 16" wheels, but what offset would be the most functional?
#45 |
Member#: 276027
For a 1997 Impreza L wagon, that is :P.
#46 |
Member#: 276027
With '99 Forrester struts/spring and imp rear tophats...sorry.
Is tired. ;( |
#47 | |
Member#: 259245
the lift looks great i must say. i have been interested in getting a few more inches of clearance for my 06 wrx but i am worried about ride quality and raising the center of gravity... how has the ride handling i.e. cornering changed. or what other pros cons have you experienced... any info would be awesome.. also im sorta new to the forums and this place is great source of info |
#48 |
Member#: 237184
hi i'm kind of new to the Nasioc forum but i wanted to ask some questions cuz i think there are more people here with lifted subarus than anywhere else. So right now i've lifted my car 1" the front and 1.25" the rear. I was thinking of fabricated 1" spacers for the sway bar mounts, trailing arm brackets, F/R subframe braces, and the diff mount spacers out of HDPE. what else would need to be spaced in order to keep the geometry of the car? and would 215/65r16 clear the F/R spring perch? I'm thinking of order bridgestone dueler H/T 689, 684.
#49 | |
Member#: 118141
*EDIT* but with 83 pages here, http://forums.nasioc.com/forums/show....php?t=1228188 I guess it's a growing occult movement within NASIOC ![]() What have you "lifted" you car (1" front and 1.25" rear) with and what car is it? And forgive my memory, but what is HDPE again? ![]() You really don't need to space down the drive line until you get over 2" of lift. The axles will be able to handle the added angle just fine, but once you lift more than 2" you should start considering the subframe spacers (engine mounts, tranny x-member, rear diff hanger, etc. etc. and so on... keep on keepin' on! and let's see it ![]() Last edited by skunkman; 08-06-2011 at 09:07 AM. |
#50 |
Member#: 249129
Vehicle:2002 WRX wagon WRB |
Subscribed.
| Thread Tools | |
| Display Modes | |
| The "How to spend your 4-day weekend w/o your girlfriend" thread | MK19_ | Off-Topic | 44 | 04-16-2007 01:18 PM |
| The Official "How old are you?" thread | wrxpeed | Off-Topic | 49 | 04-19-2006 04:09 AM |
| The official "How much of your bumper did you have to cut for your FMIC" thread. | lawn boy | Interior & Exterior Modification | 0 | 04-17-2005 11:56 AM |
| The The Unofficial What front lip is that? Thread. post and tell.... | mmmprza | Member's Car Gallery | 3 | 04-11-2004 02:14 AM |
| re-reading "how to make your car handle" last night | jmott | Texas Impreza Club Forum -- TXIC | 18 | 08-18-2002 06:02 PM |
