Old 05-23-2011, 06:52 PM   #26
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Seeing that these are almost $500, what is the benefit vs (see link)
http://cgi.ebay.com/ebaymotors/GODSP...Q5fAccessories
BeBop86 is offline   Reply With Quote
Old 05-24-2011, 01:26 PM   #27
Storm
Member#: 5218
96L Most Over-
Developed Beater
I assure you that I don't have $500 into mine......which are the ones pictured that aren't CAD drawings.
Jay
Old 05-24-2011, 01:33 PM   #28
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
The idea was to make full pillow ball for cheaper then you can buy them where as the godspeeds have clevis mounts on the rear links. Mine are a lot easier to adjust with 3 different points as well as having a lot more adjustment.
Those godspeeds have gotten pretty good reviews actually and is probably what I will get but with the trailing links as well since its only 100 more.
KOJAK-02-WRX is offline   Reply With Quote
Old 05-24-2011, 02:07 PM   #29
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Storm, how much are into yours?
Old 05-24-2011, 03:23 PM   #30
Storm
Member#: 5218
96L Most Over-
Developed Beater
About $120.....but I had the aluminum on hand to make the reducer bushings (myself), and I had the 14mm bolts and nuts to secure them to the subframe.
From Speedway Motors:
4x 3/4 shank/hole LH pro 1 rod ends at 15.99ea.
4x 3/4 shank/hole RH pro 1 rod ends at 15.99ea.
4x 1" OD 3/4-16 aluminum threaded tie rods, 12" long at 12.99ea.
1x 3/4-16 LH jam nuts at 3.99 for bag of 6
1x 3/4-16 RH jam nuts at 3.99 for bag of 6
Jay
Old 05-25-2011, 06:31 AM   #31
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
You also have to remember that he isn't using a rear sway bar so it doesn't matter if he has the endlink mounts. If you are going to use a sway bar you need to tack on 169 dollars for poltec box mounts. I tried to see if megan racing would sell their box mounts separately from their rear lateral links but I never got a reply. Looked like it would have been around 100 for them if they would do it.
Old 05-26-2011, 07:41 AM   #32
Storm
Member#: 5218
96L Most Over-
Developed Beater
When you're DIY-ing enough to fabricate lateral links, there's absolutely NO reason to pay $169 for endlink mounts. Looking at the picture of the old Whiteline kit is all you need to do.
My .02
Jay
Old 05-26-2011, 07:46 AM   #33
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
What whiteline kit? I'm talking about this part not the endlink itself:
I guess it comes with the endlinks but I don't think you can get the box without them. Guess it wouldn't be too hard to make them but not without some measurements and not with common hand tools like the rest of my DIY is geared toward, hell all you have to do is screw the parts together really. You will need to a mill to make this part.
Old 07-10-2011, 02:13 PM   #34
Burnman
Member#: 218087
95 Legacy
That ugly 'spruce' green.
I'm in the middle of making some for my Legacy.
I used solid 6061-T6 solid 1 inch round, and 5/8" QA1 chrome-moly left and right teflon/kevlar slot injected rod-ends. Spacer inserts were 303 stainless.
I've got the non-anti roll bar ones done, but am trying to figure out how to do the other ones. A machining 'sketch' of what I'm thinking of:
Done on a manual lathe.
Burnman is offline   Reply With Quote
Old 05-11-2012, 10:40 AM   #35
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Kojak, did you remake them with the adjustment in the middle? Any updates or pictures?
Out of curiosity, are these noisy?
Old 05-11-2012, 10:52 AM   #36
biknman
Member#: 47915
2003 GG HC TT
GG-RC 08STI 16OB 96GC2dr
Here is what I used to attach the endlink to the lateral link on mine. Also plan on using them on my front custom LCA. It's a panhard bar mount for circle guys.
http://www.ebay.com/itm/400282917940...84.m1438.l2649
biknman is offline   Reply With Quote
Old 05-11-2012, 10:53 AM   #37
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
I haven't made either one actually, just made up some drawings to make them in the future, never had time and wifes approval to make them myself so I posted my drawings to help others.
It was also brought up that the aluminum rod ends may not be strong enough and that zinc plated steel ones would be ideal and still do well in aspect of corrosion which was one of the reasons I used aluminum in the first place the other being weight.
Old 09-13-2012, 11:01 AM   #38
Swagon_Wagon
Member#: 294424
1999 RSti
white as ****.
Bringing this back.
What if a guy wanted to keep the stock bushing setup but just up grade to Tic bushings or the like.
then just cut the links in half(2 cuts, remove about 2 inches from the rod in the center)
then tap the inside of the stock piping and get double ended studs to adjust the length?
then all a guy would need are studs, jam nuts, and poly bushings of your choice? sorry if this has already been done. i found this thread via google.
Swagon_Wagon is offline   Reply With Quote
Old 09-13-2012, 11:13 AM   #39
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
Aren't the factory links hollow? If they are you need to make sure they are thick enough to support being threaded. Another thought against is that the factory links are skinnier than this setup so it would only support a very small double ended stud which wouldn't be strong enough.
Old 09-13-2012, 09:39 PM   #40
Storm
Member#: 5218
96L Most Over-
Developed Beater
^^^ What he said. I don't think they would be strong enough without going to a larger threadsize. Gotta consider wall thickness before and after cutting threads into it.
FWIW, I'm about 6 months into the lifecycle of my setup that sees more than 1.5g lateral accelleration. My aluminum bushings have in fact developed a little more play as time has progressed. Interestingly, the play is on the OD of the bushing, where it slips into the spherical bearing. It is still the same as new where the bolt passes through the ID. For a quick fix, I used a center punch to dimple and burnish the OD and take up the slop. Worked like a charm for now. The next set will be of a harder material for longevity.
I could not be happier with the performance of this setup. Alignments are super easy, they stay put, and allow the dampers to completely work on the wheel and not have to work against bushings flexing and rebounding.....
Jay
Old 09-14-2012, 12:58 AM   #41
Swagon_Wagon
Member#: 294424
1999 RSti
white as ****.
that what i was thinking folks were gonna say. not thick enough. on that note i did find these while searching.
http://www.fmpracing.com/product_inf...roducts_id=504
Old 09-14-2012, 02:27 PM   #42
sdmideas
Possible Scammer - Buyer Beware
Member#: 280920
2003 wrx
white
those are cheap...looks like the ebay versions...
sdmideas is offline   Reply With Quote
Old 09-14-2012, 11:28 PM   #43
Swagon_Wagon
Member#: 294424
1999 RSti
white as ****.
yea most likely. but i cant anyway. i cant get my lat links of the car. that bolt that goes though the rear knuckle and both lat links is never coming out. ever. been sittting for days with liquid wrench on soaking it and nothin.
anyone have any old knuckles laying around that dont have 250 thousand miles on them?
Old 09-15-2012, 05:45 AM   #44
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
I have a disc brake conversion from either a legacy or forester don't remember that has the knuckles and all.
Old 09-15-2012, 10:36 AM   #45
Swagon_Wagon
Member#: 294424
1999 RSti
white as ****.
does it all come apart?
Old 09-15-2012, 01:04 PM   #46
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Youre going to have to cut the links/bolts.
Those look like crap, I wouldnt touch them with a 10 foot stick. That inner-most lock nut is going to be impossible to tighten/loosen on the car.
vision.dynamix is online now   Reply With Quote
STi pillow ball lateral links rbahr Suspension/Brakes/Handling 3 04-25-2009 11:00 PM
Stock STI 06 rear lateral links - do they have pillow balls? FAST-1 Brakes, Steering & Suspension 23 01-03-2008 09:23 PM
Tein Camber Plates full pillow ball mounts for WRX and STI zroom tsuchiya Private 'For Sale' Classifieds 0 07-26-2006 10:00 PM
are lateral links with pillow ball bushing streetable? scobaru Brakes, Steering & Suspension 1 06-27-2006 05:55 AM
We can have the new STi pillow ball sway links too- but it will cost BIGSKYWRX Brakes, Steering & Suspension 3 09-23-2003 12:22 AM
