Old 05-25-2011, 11:51 AM   #26
nonoywrx
Member#: 274337
2011 WRX 5D Limited
Satin White Pearl
So I brought my car to the dealer this morning. For whatever reason, the blinker was normal when I arrived at shop. But I have them check anyway and it'll take longer. Any comments anyone?
nonoywrx is offline   Reply With Quote
Old 05-25-2011, 12:05 PM   #27
beast464
Member#: 58149
2011 WRX
Originally Posted by AndrewtechAutomotive
Mines the front left blinker...I'll look at it tomorrow.
What did you find on the left side? Mine is the left also.
beast464 is offline   Reply With Quote
Old 07-18-2011, 01:31 AM   #28
zamboniman87
Member#: 279437
2011 WRX 5-door
Did anyone get a CEL after installing everything? I got codes P0102 and some other one related to air intake temp. I assume this has something to do with the removal of the maf sensor plug... anyways, I cleared the light and I'll see if it comes back tomorrow.
zamboniman87 is offline   Reply With Quote
Old 07-25-2011, 03:11 AM   #29
David920
Member#: 168092
2011 WRX 5-Door Prm
Obsidian Black
Just noticed the passenger side blinker issue with my 11wrx (@17200 miles). Will have a go at this fix tomorrow.
David920 is offline   Reply With Quote
Old 07-25-2011, 03:35 AM   #30
wrx~god
Member#: 58755
satin white pearl
Don't need to take off airbox and ram. Turn tires to the left, pull clips on inner fenderwell. Reach inside and loosen the wire tension on plug. Wiggle and I think I unclipped one clip while behind there. Less than 10 minutes.
wrx~god is offline   Reply With Quote
Old 08-11-2011, 05:31 PM   #31
Raptor89
Member#: 285405
2013 WRX Hatch
I was recently having this problem with my 2.5i and finally fixed it today. I have less than 3000 miles and it had been doing it off and on for a few weeks. I went to Pep Boys and bought a new bulb and it works. I did remove the Box and scoop to get at the bulb. I had to unplug the MAF sensor, so the Check Engine and Traction lights came on, and the Cruise light was blinking. A simple ECU reset fixed that though...works great now! *knocks on wood*
Raptor89 is offline   Reply With Quote
Old 11-22-2011, 12:10 AM   #32
Entreri22
Member#: 301395
2008 WRX, Sedan
will this fix work with a 08 wrx as well? I am having the same issue.
Entreri22 is offline   Reply With Quote
Old 12-17-2011, 03:15 PM   #33
03WRXMA
Member#: 35081
2012 WRX
Will likely work for other years as well.
I just did this on my 2012, driver's side bulb, as stated - pull the wiring from the 'guide' molding into the back of the headlight housing and instant slack, YMMV.
03WRXMA is offline   Reply With Quote
Old 12-18-2011, 04:49 PM   #34
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
I had the spastic blinker on my '11 WRX, front passenger side. It was intermittent for a few weeks before going full retard.
I had the car at the dealer to switch out tires and asked them to look at it. They said it was a known issue, and said they re-routed the wire to give it more slack. That worked for a day or two, then it went back to the fast-blink. I tried messing with the wire with the hazards running but couldn't get the bright filament to light up. I was going to wait until the first oil change to let them have another go at it, but one day on the way home from work it got on my nerves so I stopped and bought bulbs.
I took out the air cleaner box (hadn't heard about the fender-well approach, or I'd have gone that route), replaced the bulb, and it's been fine in the week since. I looked at the bulb I removed and I didn't see any break in either filament, but I couldn't get it to work no matter how much I messed with it or the socket or the wiring when I had everything taken apart.
I had the same constellation of lights as Raptor89, but reflashed the ECU and all's well.
So it seems that the issue can be tight wiring, or a bad bulb, or both.
Dale2011WRX is offline   Reply With Quote
Old 01-09-2012, 07:54 AM   #35
gixxerjoe
Member#: 260335
2011 WRX
Hey all,
Love my subie but I have both sides blinking full blast, and I'm embrassed to use my blinkers on a new car... This could be dangerous.
Im going to attemp this, and If I trip any of the senors how do I reset ECU to clear the lights on the dash board?
Thx.
gixxerjoe is offline   Reply With Quote
Old 01-09-2012, 11:34 AM   #36
03WRXMA
Member#: 35081
2012 WRX
Originally Posted by gixxerjoe View Post
Hey all,
Thx.
No sensors to worry about! Really, take the battery out on the drivers side to get more access there, on the pass. side pop out the intake 'funnel' and you'll be good to go. Once you have access you'll see where to adjust the wires to give them more slack. Have fun!
Old 01-09-2012, 01:49 PM   #37
pakbot
Member#: 284229
2011 WRX Hatch
Satin White Pearl
So glad I found this thread today. I have the same problem. Passenger side front blinker on a 2011 WRX hatch. Thought I might have clipped something taking off the bumper cover installing the hella horns, but I'll take a look at this now instead.
Explains why it worked sometimes and not others.
pakbot is offline   Reply With Quote
Old 01-09-2012, 05:04 PM   #38
gixxerjoe
Member#: 260335
2011 WRX
Ok, so I just did this and both my blinkers work normally now - hurray!
Wish I found this write up sooner cause its simple to do and saves me time to the dealer.
Old 01-23-2012, 08:24 PM   #39
Entreri22
Member#: 301395
2008 WRX, Sedan
Is there a write up with pics anywhere on fixing the drivers side front blinker?
Old 01-23-2012, 08:38 PM   #40
03WRXMA
Member#: 35081
2012 WRX
No pics needed but the long and short is disconnect both battery terminals (negative first), pull the battery out after taking out the tie down, and then pull thru wire out of the 'guides' for it built into the housing. Get those hangs dirty and you'll see
Old 02-26-2012, 07:36 PM   #41
RockyMtnGT
Member#: 127953
2016 STI Limited
Lapis Blue
Just wanted say thanks! My 2012 with 850 miles has horny blinkers...
I will attempt this fix when it gets a little warmer outside.
cheers!
RockyMtnGT is offline   Reply With Quote
Old 04-30-2012, 11:46 AM   #42
waltah
Member#: 317856
Thank you, this is the exact issue I was having with my 11 STi. All fixed now and canceled my appt with the dealer
waltah is offline   Reply With Quote
Old 09-18-2012, 07:22 PM   #43
oharao2
Member#: 229802
2008 WRX STI
My problem wasn't with tension on the line. It seemed that the wire harness is going bad. I put some black tape on the wires at the base of the harness so that more pressure was on the contact point and that seemed to fix the problem. The next time i bring the car into the dealer i will have them fix it properly.
oharao2 is offline   Reply With Quote
Old 10-25-2012, 02:38 PM   #44
bluewrx42
Member#: 336104
2015 STi
Default 2011 WRX Blinker issues cont.
I would like to make sure owners take a close look at the bulb when this happens, The blinker/parking light has two elements in it. So it might appear that it isn't burnt out cause you see the parking light element still working, but the blinker element IS burned out
I've replaced burnt out left blinker 3 times, and the right blinker once now.
The last left blinker I replaced I used a NAPA BP1157NA bulb, it only lasted 1,400mis and less than a month. Let's see how long the second one lasts?
Also I've checked my wiring and it doesn't appear tight, the left did have bit of a kink to it near the battery, so I worked that out. But I really dislike dealerships so I would like to fix this issue if possible myself.
bluewrx42 is offline   Reply With Quote
Old 10-27-2012, 09:49 PM   #45
scx89
Member#: 269388
2011 Impreza WRX
obp
I had the same thing
I brought it into the dealers and they said it was because of tension in the wires and they loosened it by taking it off the clips.
However, after driving the symptoms appeared again. So I tried to fix it myself and I moved the wires around and only when i turned the bulb socket clockwise all the way, the blinkers became normal. I'll see how long this lasts.
Btw, I did this all through the wheel fender
scx89 is offline   Reply With Quote
Old 10-29-2012, 09:12 PM   #46
scx89
Member#: 269388
2011 Impreza WRX
obp
Failed within 1 day
Old 10-29-2012, 09:30 PM   #47
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
This is what I did as well. Front right was going out, so I unclipped the front of the wheel liner and reached up in there. Unscrewed the whole bulb and replaced and made sure it was tight. I then moved the wires as I felt them tangled and being pulled up.
Havn't had a problem in about 6k miles.
JSchell1309 is offline   Reply With Quote
Old 10-29-2012, 11:52 PM   #48
RM_2
Member#: 163058
'16 BRZ Limited WRB
'06 Saab 9-2X 2.5i NGM
Man, I still need to do this. Thing is that....both my blinkers do this. I guess it's time to get under the wheel wells then.
RM_2 is offline   Reply With Quote
Old 11-04-2012, 03:51 PM   #49
RM_2
Member#: 163058
'16 BRZ Limited WRB
As stated in the previous post, both my passenger and driver side signals blink like crazy and neither of the bulbs are out. I've already taken my car into the dealership to get this fixed and they ended up replacing the whole headlight assembly on my passenger side. It worked for as long as it took to get on the highway from the dealership, which was about 2 minutes. Instead of going to the dealership again, I followed a separate set of directions from another NASIOC member that is pretty straightforward and included a picture guide for it.
Apparently, if you have messed up, twisted wiring like I did, it's a lot easier to go through the fender liner than removing the airbox or doing anything crazy on the driver's side like removing the battery. I started with the passenger side and tried removing the airbox first and well, that's a pain in the butt because of numerous things like loosening a bunch of things, prying tubing off clips and removing that bottom bolt that you need an extension for.
First, open your hood and turn your wheel towards the inside of the side of the car you're working on. If you're working on the driver's side, turn the wheel towards the passenger side. Open the hood for visibility when you're getting into the wheel wells.
Second, remove the three retaining clips in the front portion of the fender liner and remove the larger retaining clip at the bottom of the car.
You will need a Philips and two flathead screwdrivers for this. Once they're loosened, just pop them off.
Once popped off, you can pull the fender liner away from the fender.
After you pull enough of the liner away from the fender, you can look inside and find the signal bulb socket. If yours was like mine, it would be all mashed up somewhere (especially on my passenger side), doing 360 degree loops and twisted a bunch.
Third, twist and unplug the bulb socket, make sure the bulb is properly seated in the socket, straighten the wires to the best of your ability, tug a bit to give it some slack and then put the bulb back into the socket.
Fourth, test the turn signal you just fixed. If it's still freaking out, then you might have an issue that is not described here (dead bulb, maybe?). If this fixes it, then success! Go get yourself a beer!
At last, reassemble the fender liner and push the clips in.
Repeat these instructions for the other side, if your passenger side signal is freaking out.
Good luck!
I drove my car around for a good 20 miles or so after doing this and so far so good.
Old 11-04-2012, 06:24 PM   #50
veener79
Member#: 204304
2008 WRX 4D Stage 2
Might have to give this a try. Mine just started to act up again.
veener79 is offline   Reply With Quote
Just picked up 2011 WRX..will dealer fix rattles? mesarec Newbies & FAQs 33 01-04-2012 01:14 AM
2011 WRX with upgraded suspension that I can check out? boudy New England Impreza Club Forum -- NESIC 11 04-22-2011 08:52 PM
2011 wrx exhaust question agarr19 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 04-14-2011 03:28 PM
FS : GA: **SOLD**2011 WRX OEM Wheels & Tires $900 shipped to the 48 Kontankerous Wheels/Tires 9 04-02-2011 12:37 PM
02 WRX 4EAT Issue: Car won't move in Drive or Reverse when cold. Loud humming too. YinUCSD Transmission (AT/MT) & Driveline 2 10-30-2007 10:02 PM
