Old 04-14-2011, 07:56 PM   #1
cobler19
Member#: 279108
2011 Impreza WRX
Dark Grey Metallic
Default Check engine, traction control, blinking cruise control lights
I started my car today and noticed the check engine light and traction control off lights were on while the cruise control light was blinking, but there wasn't any whining noise or anything. The car is a brand new 2011 WRX with only 270 miles on it...obviously it needs to be taken in, but what could cause a problem like this in such a new car?
cobler19 is offline   Reply With Quote
Old 04-14-2011, 08:48 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
this is an example of the kind of thing that is 100% impossible to tell...and a waste of time.
Without a code to tell us what is unhappy, there is NO answer to this.
Get the code = get the answer
Old 04-15-2011, 03:49 AM   #3
Daijoubo-yo
Member#: 252612
2010 WRX 5dr
97 Lude Sh,99 Durango 5.2
People have had this issue and discussed it extensively on the IWSTI forums. I think it had to do with a brake switch or the like. Go check it out and it should be an easy fix courtesy of that warranty you have.
Daijoubo-yo is offline   Reply With Quote
Old 04-18-2011, 01:37 PM   #4
jlklegacy
Member#: 176006
1997 Legacy GT
Spruce Pearl Metallic
when the check engine light comes on in newer subies, it also makes the cruise inop, and traction control inop, that is why they all blink. so you neeed to pull the codes.
jlklegacy is offline   Reply With Quote
Old 04-18-2011, 01:50 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
I think that before you post anything you shouldnt
unless you KNOW...and you dont
NOBODY does without the C O D E
and that was discussed in the second post
Old 04-18-2011, 02:34 PM   #6
MikePiper1
Member#: 206162
2013 STI Sedan
ISM
Check your gas cap. Make sure it is seated properly (tighten it and then go a few "clicks" past)
MikePiper1 is offline   Reply With Quote
Old 04-18-2011, 03:51 PM   #7
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Bottom Line:
It's a new car - take it to the dealer. The will check the code that initiated/caused the CEL (Check Engine Light) and it could be the result of a variety of things, from the Gas Cap mentioned, to a misfire, bad plug wires, or a variety of other more serious maladies. Best bet - see the dealer!
G-
G-Omaha is offline   Reply With Quote
Old 04-20-2011, 12:32 AM   #8
Daijoubo-yo
Member#: 252612
2010 WRX 5dr
True, just pointing out that it was an issue that has occurred with others even if the code wasn't related.
Old 04-20-2011, 12:57 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
no code = guess
guess = dont DO it
Old 07-29-2011, 01:29 AM   #10
SmokescreenWRKS
Member#: 276040
2011 WRX Hatch
Rally Blue
I got the exact same problem! Crazy. But i've got 12k miles on it already.
Had my check engine light come on, traction control wouldn't turn off and cruize control wouldn't work but light blinked on and off.
Hah. I did the gas cap test too. It wasn't the gas cap.
Dealer found it's a bad mass air flow sensor in the exhaust system (can't really confirm exactly where? I forgot what he said mostly becuase he seemed unsure. He mentioned a sensor on the exhaust, past the cat) Anyone have this problem?
Engine's been sputtering for the past 2 months now. I'm not sure if it's becuase of the heat? Humidity? bad Freestate fuel (is F-state really that bad)?
What did the dealer find out Cobler19?
SmokescreenWRKS is offline   Reply With Quote
Old 08-03-2011, 11:04 AM   #11
terrynh
Member#: 274941
97 5-Speed Coupe
Any updates for this? my friend had a similar problem
terrynh is offline   Reply With Quote
Old 08-03-2011, 11:40 AM   #12
Rymantas
Member#: 264225
2011 WRX Sedan
I had it happen because I unplugged wire on top of the airbox to change air filters on my 2011 wrx and when i plugged it back in it didnt seat all the way. Have you done any maintenance or change anything recently?
Rymantas is offline   Reply With Quote
Old 08-05-2011, 10:37 PM   #13
rugger17
Member#: 248147
2010 WRX
I'm having this problem too! Just went out to my car after not driving it for two weeks and this started happening. The care was perfectly fine before i drove it.
Anyone know if this will be bad to drive on for a while? I will not be able to get to the dealership for a long time.
Thanks.
rugger17 is offline   Reply With Quote
Old 08-06-2011, 02:52 AM   #14
subaru_sti_steve
Member#: 289798
94 Ranger Truck
world rusty blue
Its called blocking codes depending on your codes certain programs/features need the information on from that sensor to run if its not working then you get flashing lights and nothing works! my buddy O2 heater wire melted on his 2001 wrx and same problem simply scan the vehicle with obd2 scanner and your car computer will tell you exactly where to start looking simple fix
subaru_sti_steve is offline   Reply With Quote
Old 08-06-2011, 10:05 AM   #15
rugger17
Member#: 248147
2010 WRX
Thanks man, i hope i can drive on it a little longer before getting it fixed. My car sat outside in the 100 degree heat for 2 weeks, and when I came back, the problem started.
Old 08-07-2011, 12:53 PM   #16
rugger17
Member#: 248147
2010 WRX
Fixed. I opened the hood and jingled the sensor on the intake, also tightened my gas cap. The next time i started my car, the blinking cruise light and engine light went off.
Old 10-22-2011, 07:21 PM   #17
Marvicamog
Member#: 220183
2010 WRX
Black Errthang
you guys are the best! i swear without nasioc, i'd just be a lost scooby nooby
so i had this problem except i was ripping it down on 2nd and shifted pretty badly to 3rd and my subie shook pretty vigorously and then the lights came on.
Check engine light, Traction Control, and the blinking cruise.
I started to freak out and I came across this page on the forum.
I read about the o2 sensor and stuff cuz I just got a invidia downpipe and mxp headers installed with a o2 bypass thingy. Sounded too complicated so i looked for another solution.
and then i read about what you could do with the intake wire + gas cap. I just wiggled around with the air intake wire + open then tightened the gas cap and then the lights were gone!
ITS A MIRACLE.
Marvicamog is offline   Reply With Quote
Old 12-05-2011, 07:04 PM   #18
wongjonsilver
Member#: 262683
2011 WRX base
Hmm.. I just had the issue arise. I was on the freeway, and in 5th gear and WOT while lane changing. I have a feeling it was an overboost given the nature of the cold temperature (1:30a). I did see it go to about 19psi on my Defi gauge. Can anybody chime in on what could be the issue?
- - - P.S. The recapping of the gas cap didn't help. Neither did the unplug/plugging of the connector to the intake.
Mods:
- COBB Stage II CA/91 OTS map
- INVIDIA Catted Downpipe
- INVIDIA Q300 Catback System
wongjonsilver is offline   Reply With Quote
Old 12-18-2011, 03:40 PM   #19
08STI206
Member#: 261145
2008 STI
^^ Pretty sure you overboosted.
Clear the code with your AP. You can also try using the LWG map since Cobb recommends using this if youre exceeding the target boost. The ECU reacted and cut off the fuel and automatically goes into "limp" mode.
Another thing I should add/recommend, especially if this happens to you alot or even if this was the first time, is to get protuned. A good tune will go a long way.
08STI206 is offline   Reply With Quote
Old 12-18-2011, 08:41 PM   #20
stisland
Member#: 283414
2008 STi
Mods:
Have an 08 sti with those same mods. Same exact thing has been happening to me as I'm ripping through 5th. The car almost stutters for a split second, then come the lights.
I'm assuming it's overboosting? Need to get the code checked. What exactly could fix it if that ends up being the issue?
stisland is offline   Reply With Quote
Old 12-19-2011, 04:03 AM   #21
08STI206
Member#: 261145
2008 STI
A good tune will fix it. What kind of DP are you running? Normally happens more if it was catless.
Old 12-19-2011, 12:04 PM   #22
stisland
Member#: 283414
2008 STi
Yeah it's a catless invidia dp, magnaflow exhaust, stock intake cobb stage 2 map.
Unfortunately, I won't be in a city that has a subie dealership for a couple weeks. Do you think I could get my codes checked elsewhere? or does it have to be at subaru
Old 12-20-2011, 01:08 PM   #23
wongjonsilver
Member#: 262683
2011 WRX base
I have a hi-flow catted downpipe, but that might be negligible. I haven't run into the problem since then. It went away after a few days of normal driving. I also have been driving in even colder weather than when I had experienced the over-boosting, yet my boost gauge (Defi) has not shown any overboosting (25-35 deg F).
Old 12-20-2011, 01:44 PM   #24
Uncle Scotty
Member#: 16200
OK buy Nates beans
advance auto checks codes
bet it is p0244....wastegate solenoid out of range
Old 12-26-2011, 08:37 PM   #25
nashcarr
Member#: 131897
2010 STi 05 FXT
SSM
Ding ding! Uncle Scotty wins!
This happened to me today during some very spirited driving during low 30's temps.
Invidia catted DP
Borla 3" exhaust
Cobb stage 2
I checked and cleared the code with the AP. first time it has ever happened. I blame the cold temps and the Cayenne Turbo!
nashcarr is offline   Reply With Quote
Whining noise, check engine light, Traction Control, Blinking Cruise jcoble Newbies & FAQs 21 05-14-2011 12:52 AM
09 Impreza - CEL and Traction Control light, blinking Cruise Control CrotchMonster Service & Maintenance 4 10-17-2010 03:38 PM
Blinking Cruise Control, CEL, Tire Pressure, AND Traction Control Lights ALL on The Database Electrical & Lighting 5 03-14-2010 03:32 AM
Check engine, traction control, cruise control lights tantric rex Service & Maintenance 0 07-08-2009 08:33 PM
Already get CEL, no traction control light, and blinking cruise control! Shohin Newbies & FAQs 17 02-04-2008 01:08 PM
