Old 05-03-2013, 06:48 AM   #326
MackDaddy
Member#: 15451
2016 Accord EXL Navi
Lunar Silver
Originally Posted by beavtech View Post
Are these navigations units plug and play as well? I found a picture of the back of one and the plugs look a bit different.
http://forums.nasioc.com/forums/show....php?t=2482185
MackDaddy is offline   Reply With Quote
Old 05-03-2013, 07:07 AM   #327
Mike02z
Member#: 342283
Originally Posted by MackDaddy View Post
SVXdc can no longer get the 28 pin Toyota connector. I tried to do NAV swap from a BRZ to a 14 Forester. Without the 28 pin connector, it can't be done easily. I found one source for the 28 pin connector but they are in China and only want to sell to you if you buy in quantity. I know SVXdc is looking for another source but as of right now, he does not appear to have one. They seem to appear on eBay once but teh seller name I was given is no longer a registered eBay member.
Mike02z is offline   Reply With Quote
Old 05-03-2013, 09:19 AM   #328
MackDaddy
Member#: 15451
Lunar Silver
Bummer for those who want to do the swap. Hopefully SVCdx will have a new connector source sometime soon... Keep the faith!
Old 05-03-2013, 05:36 PM   #329
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
http://www.ebay.com/itm/OEM-Car-Radi...e164c5&vxp=mtr
Would this one work? Looks the same except for the ti/news button and its sc430 not sc630
freddy121389 is offline   Reply With Quote
Old 05-03-2013, 06:58 PM   #330
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Yes it will work. It has been posted and covered here. Here is an alternate seller that we have had success with.
http://www.ebay.com/itm/Subaru-Fores...c23862&vxp=mtr
I am personally running this exact unit in my 2011.
JSchell1309 is offline   Reply With Quote
Old 05-03-2013, 07:37 PM   #331
esmcblur
Member#: 352593
Just placed my order for the one above!
Thought about holding out for an hd version, but I don't have the time to dig and wait for one.
esmcblur is offline   Reply With Quote
Old 05-04-2013, 03:07 AM   #332
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
Sweet, and did yours come with all the additional wires like the subwoofer outputs etc.?
Old 05-07-2013, 02:17 AM   #333
SidecarScoobie
Member#: 335561
2011 WRX 5dr Limited
Mine came with all the pictured connectors. I'm not sure if any of them are functional since I just swapped out my 2011 WRX stock unit with this one. I tried to use the 8 Pin rear view camera connector, but I ended up breaking it when I tried to modify it to tap into the head unit's 6 volt power. I ended up buying one from svxdc instead.
SidecarScoobie is offline   Reply With Quote
Old 05-07-2013, 11:37 AM   #334
JSchell1309
Member#: 321321
Tuxedo Black
Well that answered my question. I was going to try to modify the rear view camera harness it came with to tap the head unit power too. I'm assuming it is not easy, what pin does SVXdc use?
Also Freddy, mine only came with the extra wires because there was an exterior blemish on my radio. So they threw those in for free. They are completely unnecessary though as the install uses all the existing plugs in the vehicle. It is 100% plug and play.
Old 05-07-2013, 11:38 AM   #335
JSchell1309
Member#: 321321
Tuxedo Black
Stupid double post.
Old 05-07-2013, 12:03 PM   #336
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
but doesn't it come with aux outputs for a subwoofer?
Old 05-07-2013, 12:49 PM   #337
JSchell1309
Member#: 321321
Tuxedo Black
Sorry cant help you there. I don't have a subwoofer. Maybe someone else can chime in.
Old 05-08-2013, 03:46 PM   #338
sgriffith
Member#: 355741
2013 XV Crosstrek
Anyone have any leads on a Cm631UD? The Chinese import is a nice alternative but I'm looking for the original HU with HD radio.
sgriffith is offline   Reply With Quote
Old 05-08-2013, 04:09 PM   #339
esmcblur
Member#: 352593
There is one on ebay located in MASS. They are asking ~$500 and won't budge.
Old 05-08-2013, 04:12 PM   #340
sgriffith
Member#: 355741
2013 XV Crosstrek
Another one on ebay is asking for $500 w/ buy it now, bidding starting at $350. Tempting to bid however $500 is too much.
Old 05-08-2013, 08:36 PM   #341
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
The USDM Forester HU model CP635U1, and AUDM Forester HU model CP235K1 are confirmed to include the line-level mono subwoofer output on the 16-pin socket. You can add a female RCA jack and amp remote turn-on wire to your car's 16-pin aux harness to access that sub out (e-mail me for more info).
I have not confirmed whether the EDM Forester model CP435L1 has the sub out (but it probably does, since that Chinese eBay vendor includes the sub RCA on their harness). It's easy to check: Look for +12V on pin #5 -- that is the amp remote turn-on. Viewing the rear of the HU, the pins are numbered:
8 7 6 5 4 3 2 1
16 ... 9
Aux input is on pins 3, 4, 11, 12. Mic input on pins 1, 2, 9, 10.
The Impreza/Crosstrek model CM631UD does not have the sub out.
SVXdc is offline   Reply With Quote
Old 05-10-2013, 07:37 PM   #342
esmcblur
Member#: 352593
I'm extremely happy w this radio, except I do have a question.
What in the hell is this wire, and were does it go? I'm not 100% it was plugged into the old, but I certainly don't see where it goes in the new.
Everything works 100% as far as I can tell. And the sound is much much better than the old!
Tia!
Old 05-11-2013, 03:20 AM   #343
SidecarScoobie
Member#: 335561
You're looking at the stereo chassis redundant ground. It plugs onto the connector sticking out in the middle of the back of the head unit chassis just above the 16 pin connector.
Old 05-11-2013, 06:37 AM   #344
esmcblur
Member#: 352593
Please excuse my ignorance.
What is the redundant ground?
And regarding its plug location, do I need to remove the screw that's pictured?? I don't see any opening where it fits pictured.
Old 05-11-2013, 09:36 AM   #345
flyers25
Member#: 352532
2013 Impreza Sedan
No need to remove any screws.
It should slide onto the metal tab that's sticking out horizontally from the back of the radio.
flyers25 is offline   Reply With Quote
Old 05-11-2013, 09:49 AM   #346
esmcblur
Member#: 352593
Ah! I gotcha. Thanks
Safe to use without it for a few days until I can get back in there?
Old 05-12-2013, 03:51 AM   #347
MaddMax
Member#: 9264
2016 BMW M235i 6MT
I can confirm that USB, Bluetooth, and CD's sound a hell of a lot better. The old radio would distort around 30 volume level. This one sounds great in the louder range.
I can confirm that this is a true statement. I just installed the same $179 eBay headunit and I'm blown away by the improvement in sound quality, especially after turning off Loudness and the preset EQ. I left SRS on, set Treble to 5, Bass to 1, and Midrange at 0. The unit is definitely pushing more power and is heavier than the OEM unit by about 7 ounces.
It's exactly what I was looking for. More robust, deeper sound; easy install and OEM fitment; and cheap.
MaddMax is offline   Reply With Quote
Old 05-12-2013, 07:21 AM   #348
esmcblur
Member#: 352593
How did you turn off loudness? I attempted the same way as the oe hu, but no dice.
Old 05-12-2013, 11:18 AM   #349
MackDaddy
Member#: 15451
Lunar Silver
"OEM 4.3" HD Radio Hidden Menus
Radio off, ignition key to accessory, or on (radio shows "Audio Off")
Hold down "6" key
Spin the tune knob to the right at least 30 clicks
Note that on the 4.3" unit, there are more menus "behind" the first one; in other words, repeating the same sequence after you are in the version number menu takes you to factory test menu 2 (Loudness ON-OFF), and then repeating it again takes you to factory test menu 3 (Eq ON-OFF)"
Old 05-12-2013, 12:56 PM   #350
esmcblur
Member#: 352593
Hold down "6" key
Thanks!
So reported best sound comes w loudness and eq off?
I am very pleased w this unit right out of the box, just what this car needed.
FS : 04-07 STi Turboback with hardware/new OEM Subaru gasket SubeDooS SCIC Private Classifieds 1 04-14-2011 03:05 PM
FS : OEM Radios, LW Crank Pulley, Forester Armrest and Rims johnpaulm1208 Tri-State Area Private Classifieds 1 04-06-2011 10:32 PM
Default Brand new never been installed Cobb/Stoptech 332mm BBK for sale mug23 Suspension/Brakes/Handling 3 06-26-2008 12:35 PM
Problems installing 07 radio with aux input and sat radio tuner into an 04 WRX? ScoobyNubieToo! Car Audio, Video & Security 3 02-11-2008 08:26 AM
FS:NY EGT Guage, Rims/Tires 4x100, Rims 5x100, OEM Radio, Forester Tires singincanary Private 'For Sale' Classifieds 5 08-30-2005 08:50 PM
