Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 06-05-2013, 09:21 PM   #401
JaTe
Member#: 48815
2013 WRX STi Sedan
Originally Posted by SenorDucK View Post
which model do you have? can yours tune 87.7 while on HD radio?
EDIT: To clarify, I understand that not all stations are broadcast in HD and that some will and won't have this feature, I'm just wondering if you can indeed toggle the HD function on or off if it changes what range the radio has as far as frequency.
I have the CP635U1 and yes it can tune to 87.7
JaTe is offline   Reply With Quote
Old 06-05-2013, 09:33 PM   #402
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
thanks a lot.
SenorDucK is offline   Reply With Quote
Old 06-05-2013, 09:50 PM   #403
c3ywut
Member#: 226603
2009 WRX Premium
Satin White Pearl
Do you guys know if this unit will function properly with the non blue tooth wrx? Like the 2008 and 2009?
c3ywut is offline   Reply With Quote
Old 06-05-2013, 11:13 PM   #404
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by BellyUpFish View Post
[Rball333 asked if his steering wheel controls would work in his 2008 Impreza if he were to transplant one of these HUs with the 4.3" screen, and I answered "no"]
Ok, so Sat wont work and I'm also going to loose the steering wheel controls?
I guess I need to find a US model.
The SWC issue is not US vs. non-US. It's installing into a car without or with the BT buttons on the wheel.
When installing into a non-nav 2008-2010 (and also some later years that got the "base" radio without USB and without BT -- meaning it looks like and is wired like a 2008):
* Most of the "main" features will work (AM/FM radio, HD, CD, BT audio streaming). The 20-pin power/speaker harness and antenna will be plug-and-play (except for SWCs). There are a few more subtle differences. See my post here.
* If you have an OEM sat radio tuner, that will work completely with the Forester CP635U1. It will work marginally with an Impreza CM631UD that has the 20-pin socket. It won't work at all with the Impreza model that deleted the socket.
* The non-BT style SWCs will not work (see my previous reply).
* If your car has the OEM aux jack, your aux harness at the back of the HU won't fit (old = 8-pin, new = 16-pin). You would need an adapter to make that work. (I can build one for you).
* For BT phone calls to work, you'll need to add an appropriate 2011-up OEM mic, and some custom wiring. The mic from a car with the OEM Kenwood Navi will not work properly.
* For USB, you'll need a USB harness with the OEM plug (to fit the Hirose socket on the back of the new HU). An OEM USB harness is extremely expensive. The parts may be available from Mouser Electronics, but I haven't determined exactly what you would need to build one yourself, or how difficult that would be.
SVXdc is offline   Reply With Quote
Old 06-06-2013, 12:16 AM   #405
BellyUpFish
Member#: 357348
2010 Limited WRX
Excellent reply.
I've got the CZ641U6 in my car currently - non-Bluetooth, but I do have factory satellite.
I just didn't want to lose the functionality of the SWC I do have.
BellyUpFish is offline   Reply With Quote
Old 06-06-2013, 01:22 PM   #406
SenorDucK
Member#: 327511
13' WRX 6 Speed
can anyone with the CM631UD verifty if you can toggle HD on and off as well?
Old 06-06-2013, 01:51 PM   #407
fiatlux
Member#: 340639
2013 WRX STi Sedan
WR Blue Pearl
I have one, and yes you can, but not easily on demand. You have to go into the secret menu and disable HD across the board, so you can't just flip HD on and off for individual stations.
Just curious, any reason why you'd rather turn HD off?
EDIT: Had a brain fart. You can toggle HD on or off in the normal menu, not in the secret menu.
fiatlux is offline   Reply With Quote
Old 06-06-2013, 02:19 PM   #408
SenorDucK
Member#: 327511
13' WRX 6 Speed
Thanks,
I just wanted to know in the rare event I prefer it off due to a station constantly switching back and forth on me. I have this issue in my 2000 civic with a kenwood HD headunit. I imagine it is a mixture of the station's signal strength, the poor antenna on my civic, and the head unit... I'm guessing I'd leave HD on, just nice to know if I have control over it.
Old 06-07-2013, 08:47 PM   #409
bry03cobra
Member#: 204371
Just got done installing rear camera in my 13WRX. Turned out great. Used the Rydeen Duo (as recommended by David/SVXdc). Used his camera harness and rev wire. Mounted camera left of plate, OEM camera location. The DUO looks OEM. Hardest part was removing some of the panels without breaking them.
bry03cobra is offline   Reply With Quote
Old 06-08-2013, 03:05 PM   #410
arod15
Member#: 304906
2015 STI
CWP
Anyone with the chinese unit off of ebay able to confirm whether or not the oem satellite works with these? Pretty much that's all I listen to. I don't see a button for SAT either.
arod15 is offline   Reply With Quote
Old 06-08-2013, 06:45 PM   #411
c3ywut
Member#: 226603
2009 WRX Premium
Satin White Pearl
Pics!!!! Please?
Old 06-10-2013, 02:13 PM   #412
bry03cobra
Member#: 204371
Pics!!!! Please?
I didn't take any pics. What do ya want pics of? I can pull panel and show where I tapped in for rev trigger.
Old 06-10-2013, 02:30 PM   #413
BellyUpFish
Member#: 357348
2010 Limited WRX
I've spoken with one individual who said no.
Old 06-10-2013, 10:52 PM   #414
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
My Chinese unit does NOT work with my Sirius satellite radio in my 2011 STI. I even tried the steering wheel mode button but it does not cycle to sat. Not a big deal for me, but you may want to still try and source a US model if that is all you listen to.
JSchell1309 is offline   Reply With Quote
Old 06-11-2013, 01:34 PM   #415
campanozzi
Member#: 336415
2011 Impreza limited
Does the chinese one have a rear view camera input? The one from ebay ?
campanozzi is offline   Reply With Quote
Old 06-11-2013, 01:41 PM   #416
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
I personally have not hooked one up yet, but I am 90% sure that yes there is a rear camera input.
Old 06-12-2013, 11:01 AM   #417
ScoobyFreak86
Member#: 338329
2013 WRX Hatch
Just got and installed mine yesterday. Huge improvement over stock! Really happy with it. I am going to take a stab at installing a back up camera in the near future. Also have a spot for the SAT plug, but I don't have SAT radio, but it's nice to know I have to option to install it if I so please.
I can't figure out when adding phone numbers to the phone book, how to type in their names. When someone calls, just the number shows up. I would like the name to show up. Anyone know how to do that? Also, here is the owners manual for the HU http://techinfo.subaru.com/proxy/695...203Aall_13.pdf
Here is my review (with more pictures) from my journal http://forums.nasioc.com/forums/show...&postcount=929
ScoobyFreak86 is offline   Reply With Quote
Old 06-12-2013, 11:21 AM   #418
BellyUpFish
Member#: 357348
2010 Limited WRX
From what I can see, it does..
Old 06-12-2013, 11:53 AM   #419
bry03cobra
Member#: 204371
Hey scoobyfreak? Where in NJ are ya? I'm in south jersey if ya want to check my backup cam out.
Bryan
Old 06-12-2013, 12:11 PM   #420
ScoobyFreak86
Member#: 338329
2013 WRX Hatch
Bryan
I am up in central NJ. What camera do you have? I saw a few options that seem fairly simple.
Old 06-12-2013, 12:31 PM   #421
bry03cobra
Member#: 204371
I went with the Rydeen Duo. I can post some pics tonight if ya like?
Old 06-12-2013, 12:41 PM   #422
ScoobyFreak86
Member#: 338329
2013 WRX Hatch
I was looking at that same one. Yeah sure. I would be interested in seeing how it looks mounted up. Thanks!
Old 06-12-2013, 06:18 PM   #423
Suba_WRX
Member#: 332185
2013 WRX
Is HD Radio and SAT the only thing that is lost by going with the Chinese unit? They seem to sell for about $100 to $150 cheaper.
Suba_WRX is offline   Reply With Quote
Old 06-12-2013, 09:34 PM   #424
DeadGeneration
Member#: 313753
2012 WRX
Dark Gray Metallic
I ordered mine from China and got it in about 5 business days. Sorry for the picture quality, took this with my "insurance camera". Looks better in person and I am now considering the 3M vinyl for the trim.
DeadGeneration is offline   Reply With Quote
Old 06-12-2013, 09:50 PM   #425
SenorDucK
Member#: 327511
13' WRX 6 Speed
is that your custom background on it?
FS : 04-07 STi Turboback with hardware/new OEM Subaru gasket SubeDooS SCIC Private Classifieds 1 04-14-2011 04:05 PM
FS : OEM Radios, LW Crank Pulley, Forester Armrest and Rims johnpaulm1208 Tri-State Area Private Classifieds 1 04-06-2011 11:32 PM
Default Brand new never been installed Cobb/Stoptech 332mm BBK for sale mug23 Suspension/Brakes/Handling 3 06-26-2008 01:35 PM
Problems installing 07 radio with aux input and sat radio tuner into an 04 WRX? ScoobyNubieToo! Car Audio, Video & Security 3 02-11-2008 09:26 AM
FS:NY EGT Guage, Rims/Tires 4x100, Rims 5x100, OEM Radio, Forester Tires singincanary Private 'For Sale' Classifieds 5 08-30-2005 09:50 PM
