Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 06-12-2013, 10:02 PM   #426
DeadGeneration
Member#: 313753
2012 WRX
Dark Gray Metallic
Yeah, I think the only option for customizing the look of the radio is in the form of a screen saver that turns on after 30 seconds without touching any dials. You can adjust the volume and the screen saver will remain on, but anything else returns you to the normal display.
I found the max resolution to be very high, dimensions for the original image I uploaded were 4912 x 3264. I stretched the picture a bit to make it fit. I think the screen is more in the ballpark of 5700 x 3800 but don't quote me.
DeadGeneration is offline   Reply With Quote
Old 06-12-2013, 11:43 PM   #427
bry03cobra
Member#: 204371
Here is the pics of the rydeen duo cam. My car is black, so I Also snapped a pic of it on my Wife's Crosstrek, easier to see on silver.
bry03cobra is offline   Reply With Quote
Old 06-13-2013, 12:25 AM   #428
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
Originally Posted by Suba_WRX View Post
Is HD Radio and SAT the only thing that is lost by going with the Chinese unit? They seem to sell for about $100 to $150 cheaper.
Yes, if you can live without those two functions then it is identical.
You are confusing resolution with aspect ratio. You had to stretch your image because the radio is a different aspect ratio. There is no way the resolution on this radio is near a 4k resolution TV
I have a nice STI background that is crystal clear on my laptop, and on the radio you can clearly see the pixels around the curves on the "S"
JSchell1309 is offline   Reply With Quote
Old 06-13-2013, 08:04 AM   #429
tsigeoff
Member#: 314721
2012 WRX Limited
[/IMG]
How is the rear image on the screen? I was looking at the same camera but saw a few people making a wedge under the camera to adjust the angle correctly.
tsigeoff is offline   Reply With Quote
Old 06-13-2013, 09:28 AM   #430
bry03cobra
Member#: 204371
I have never used a backup cam before, pic seems fine to me. I set it without guide lines. Really only us it as an guide. Will try to take a pic after work.
Old 06-13-2013, 10:19 AM   #431
ScoobyFreak86
Member#: 338329
2013 WRX Hatch
Looks great man. Thanks for the pics! Definitely something I'll be doing in the near future.
ScoobyFreak86 is offline   Reply With Quote
Old 06-13-2013, 03:13 PM   #432
tsigeoff
Member#: 314721
2012 WRX Limited
thanks
Old 06-13-2013, 04:08 PM   #433
nubsub
Member#: 313575
2012 Impreza 2.0i HB
i actually ended up keeping the guidelines on (for my Impreza). i set them up so that i know where my tires are (for parallel parking) and bumper. while not as pretty, the guidelines can be pretty handy. (mine is set up so the lines are about 3" wider than my car, and the red marks are 2 feet from my bumper...things get nonlinear any closer...the halfway point between the bumper and red marks is not 1 ft... (my brain is freezing on me right now, it was either 16" or 8" ) )
nubsub is offline   Reply With Quote
Old 06-13-2013, 05:16 PM   #434
dsn112
Member#: 332561
2015 Legacy LTD
Twilight Blue
I ordered mine from China and got it in about 5 business days. Sorry for the picture quality, took this with my "insurance camera". Looks better in person and I am now considering the 3M vinyl for the trim.
Does the am/fm work fine? I don't care about sat or HD, just want the better screen and the readout for bT audio from my iPod
dsn112 is offline   Reply With Quote
Old 06-13-2013, 06:19 PM   #435
esmcblur
Member#: 352593
Yup, works perfect. Better than stock.
esmcblur is offline   Reply With Quote
Old 06-14-2013, 01:32 PM   #436
foxonwheels
Member#: 329372
2013 WRX Hatch
Can someone with the China unit verify that the subwoofer output works? You could probably do this by going through the audio menus to see if there is a separate subwoofer level adjustment in addition to the standard bass and treble.
foxonwheels is offline   Reply With Quote
Old 06-14-2013, 03:19 PM   #437
Rymar
Member#: 310672
2012 Impreza Ltd 5Dr
Dark Gray Metallic
For the US spec models, the subwoofer output is NOT available for the CM631UD; the pins are there, but the internal components are not stuffed on the main circuit board. I believe it is available on the CP635U1.
There is no menu I'm aware of on either one associated with subwoofer output; it is simply available as an output signal.
Rymar is offline   Reply With Quote
Old 06-15-2013, 12:54 PM   #438
foxonwheels
Member#: 329372
2013 WRX Hatch
But what about the unit from China everyone is buying from eBay?
Old 06-15-2013, 10:12 PM   #439
DeadGeneration
Member#: 313753
2012 WRX
Dark Gray Metallic
My AM signal is just a bunch of static and engine noise. My FM sounds only half as good as the $170 kenwood excelleron single DIN radio I used to have in the car.
Old 06-17-2013, 11:43 PM   #440
BellyUpFish
Member#: 357348
2010 Limited WRX
Where is everyone finding the CP635U1? I've been looking for over a month and am having zero luck. If SAT worked on the China version, I'd be all over that, but it doesn't...
BellyUpFish is offline   Reply With Quote
Old 06-18-2013, 07:18 AM   #441
JaTe
Member#: 48815
2013 WRX STi Sedan
Check the forester forums and ebay. Occasionally they pop up for sale. I found mine on ebay a couple weeks ago.
JaTe is online now   Reply With Quote
Old 06-18-2013, 11:51 AM   #442
dsn112
Member#: 332561
2015 Legacy LTD
Twilight Blue
I found by searching the online parts databases a CM631UD which is near identical, it doesn't have a sat button, but does allow for it by changing a setting in the firmware. I have a portable sat unit anyway, just want the better screen, backup camera and HD radio should be cool.
Old 06-18-2013, 11:52 AM   #443
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I searched for 10 months
Old 06-18-2013, 11:52 AM   #444
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
The output signal is much better too
Old 06-18-2013, 11:55 AM   #445
burnurass
Member#: 176557
2013 Impreza WRX
I got to SAT feature by using the steering wheel controls.
Only downside is that you need the SAT button to swap between sat1, sat2, sat3 presets.
So you can only use sat1 and 6 presets instead of 18 possible presets.
burnurass is offline   Reply With Quote
Old 06-18-2013, 11:56 AM   #446
ElwoodBlues
Member#: 333648
2013 WRX
WR Blue Pearl
How do you get the image to go full screen? Mine will only display an image in the center of the screen (black border around entire image) no matter what resolution the picture is.
ElwoodBlues is offline   Reply With Quote
Old 06-18-2013, 11:59 AM   #447
BellyUpFish
Member#: 357348
2010 Limited WRX
Yeh.. Patience, virtue and all that...
Old 06-18-2013, 01:43 PM   #448
dsn112
Member#: 332561
2015 Legacy LTD
Twilight Blue
Cool, I went to the lc2i and a JL class d 4 channel amp a while back, fixed the signal issue right up. I really want the back up camera and the iPod screens most.
Car-part.com was searching for a week. Looked at the forester and impreza 12-14 models for it
No sat needed for me, have my sportster that was deactivated 3 years ago. It still works and I don't pay so I will keep this one forever
Old 06-19-2013, 02:45 PM   #449
DeadGeneration
Member#: 313753
2012 WRX
Dark Gray Metallic
The China unit plays BT audio very well. It is a better source than the USB input which is just OK. I haven't tried a CD. The FM is pretty garbage. AM is just static and engine noise.
In short, it's BT or bust for me.
Old 06-19-2013, 02:51 PM   #450
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
A LOT of the white noise that was present in the other head unit is gone, not entirely, but I have the gain set low enough now on the 445u that it isn't audible. Normal volume for sat is 23, for bt or usb is 15.
FS : 04-07 STi Turboback with hardware/new OEM Subaru gasket SubeDooS SCIC Private Classifieds 1 04-14-2011 04:05 PM
FS : OEM Radios, LW Crank Pulley, Forester Armrest and Rims johnpaulm1208 Tri-State Area Private Classifieds 1 04-06-2011 11:32 PM
Default Brand new never been installed Cobb/Stoptech 332mm BBK for sale mug23 Suspension/Brakes/Handling 3 06-26-2008 01:35 PM
Problems installing 07 radio with aux input and sat radio tuner into an 04 WRX? ScoobyNubieToo! Car Audio, Video & Security 3 02-11-2008 09:26 AM
FS:NY EGT Guage, Rims/Tires 4x100, Rims 5x100, OEM Radio, Forester Tires singincanary Private 'For Sale' Classifieds 5 08-30-2005 09:50 PM
